3rd Gen TRD Offroad vs. TRD Pro Wheel comparison
Discussion in '3rd Gen Tundras (2022+)' started by TundraDan723, Aug 29, 2024.
  1. Sep 9, 2024 at 9:41 PM
    nmspins
    nmspins New Member
    I’m contemplating making this change as well on my ‘23 Limited TRD OR. Can you share side profile pictures? I like that it stays within the fenders.
  2. Sep 9, 2024 at 10:30 PM
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    Ok, now I gotta know.
  3. Sep 10, 2024 at 9:18 AM
    thomez
    thomez New Member
    NE Ohio
    Silver ‘24 Tundra Platinum
    You want a side profile pic of ?
  4. Sep 13, 2024 at 1:06 PM
    TundraDan723
    TundraDan723 [OP] Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
  5. Sep 13, 2024 at 1:11 PM
    TundraDan723
    @nmspins like this?
  6. Sep 13, 2024 at 1:34 PM
    thomez
    thomez New Member
    NE Ohio
    Yeah I can also manage that if that’s what we are after here
  7. Oct 2, 2024 at 4:24 PM
    nmspins
    nmspins New Member
    Yes! Thanks to you both, that’s what I’m looking for. This looks great, going to pull the trigger on a BBS set that a buddy took off his pro.
    thomez and TundraDan723[OP] like this.
  8. Oct 6, 2024 at 3:22 PM
    nmspins
    nmspins New Member
    @thomez and @TundraDan723 i made the switch and love it. Are you running PSI @ 35 per the door plate? I believe it’s always by the car requirements and not by the tire but wanted to check.
  9. Oct 6, 2024 at 4:21 PM
    thomez
    thomez New Member
    NE Ohio
    I’m at 34 PSI so right in that range yep
    nmspins[QUOTED] likes this.
  10. Oct 6, 2024 at 4:24 PM
    TundraDan723
    I'm at 35 and like it.
  11. Oct 6, 2024 at 6:41 PM
    Leatherhead237
    Leatherhead237 New Member
    Massachusetts
    2023 1794 TRD Off-Road
    I have a 23 1794 with the TRD OR package/20's and I am running 35x12.50s with no lift and basically zero rub. The only rub on the fender liners at full lock and typically only in reverse. I feel that I could easily fix it by pinning the fender liners back a bit.
  12. Oct 30, 2024 at 8:33 AM
    241792EH
    241792EH New Member
    Quick question for @TundraDan723 , I'm trying to do the same type of swap you did, (18" TRD Pro BBS Wheels and tires on a 2024 1794 edition Tundra), but was not able to program the TPWS and get the tire pressure sensors to work. I took the truck to the dealer to have them do it since I assumed that I was doing something wrong and they are telling me that the TRD Pro sensors are incompatible with the 1794 edition since they have an identity code that is 8 digits long and my 1794 edition only allows the input of a 7 digit code in the tire monitor ECU. Did you run into any issues with using the TRD Pro sensors when you did your swap, or did you keep your original sensors and have them installed in the TRD Pro wheels? Any insight would be appreciated.
  13. Oct 30, 2024 at 8:39 AM
    Jettster
    Jettster New Member
    2023 Tundra 1794 TRD Off Road
    TRD Pro Wheels and Tires
    I smell bullshit I swapped my 1794 wheels for TRD Pro and let the dealer do it...they charged a reasonable fee and even swapped the spare
  14. Oct 30, 2024 at 6:55 PM
    thomez
    thomez New Member
    NE Ohio
    I can't imagine that they are incompatible
  15. Oct 30, 2024 at 7:23 PM
    TundraDan723
    I put the sensors from my original 20" wheels into the new BBS rims. They did not come with TPMS sensors (and I had no idea they weren't compatible)
  16. Oct 31, 2024 at 12:52 PM
    241792EH
    241792EH New Member
    Thanks @TundraDan723. Looks like I'm going to need to do the same. Based on everything I can find out the TPMS sensors seem to have changed for 2024, so I can't put 2023 TRD Pro Wheel sensors on a 2024 1794 TRD Offroad Tundra. Would not have stopped me from getting the wheels since I think they look great on the Tundra but it's always nice knowing what you're getting into when you do these things. IMG_6706.HEIC.jpg
    thomez likes this.
  17. Oct 31, 2024 at 4:21 PM
    TundraDan723
    Sorry you had to learn the hard way, but it's good info for all. Also, pretty easily remedied if you still have your original TPMS sensors.
  18. Jan 21, 2025 at 12:46 AM
    120DegreeTundra
    120DegreeTundra New Member
    2024 Tundra SR5 4x4 Magnetic Gray Metallic
    Glad I found this thread. I've got a '24 SR5 in magnetic gray metallic that I'm looking to go to 35s on (w/lift, leaning toward Westcott 3" kit). I have the silver wheels and instead of going to black aftermarkets or has occurred to me it might be cool to swap out for a set of the BBS TRD pros. Aside from being OEM, l actually like the spoke pattern better than the 20" TRD wheels. I would welcome thoughts on that.
    Tundrastruck91 likes this.
  19. Feb 10, 2025 at 6:31 PM
    thomez
    thomez New Member
    NE Ohio
    they are expensive, otherwise I have no complaints and do like the appearance better as well; it's neat to have a forged aluminum wheel (rather than cast)
    my uncle's cast Dodge wheel actually just cracked recently ...
  20. Feb 10, 2025 at 7:30 PM
    #50
    dagooaz
    dagooaz New Member
    Dave
    I have Method wheels, which are more than strong enough handle 99+% of whatever you’ll throw at them. Forged wheels are cool and all, but they’re overkill for what most people are going to do with their Tundra. I would venture to say that you’ll break Tundra before you break high quality cast wheels, IMO.
