For those that carry: is capacity a major factor in what you carry?
Discussion in 'Guns & Hunting' started by Bought2Pull, Oct 28, 2024.
  1. Oct 30, 2024 at 9:45 AM
    #61
    AZBaldy
    AZBaldy Bald, James Bald, 000...
    Z
    Kaliforniastan
    2008 SR5 4Runner
    Range vs carry ammo really depends. Since I carry a handgun with a shorter barrel I am using +p 124 gr JHP 9mm, typically winchester ranger, federal hst or speer gold dot. For the range, I typically use 124 gr fmj nato spec ammo which runs hotter than your typical 115 gr fmj range ammo most places sell.
    I will shoot a box of each of the carry loads (50 rounds per box) to ensure I don't have any issues with feeding or extraction at the range. But after that, I typically will stick with the nato spec 124 gr fmj 9mm for range practice.
    One thing I will do is shoot through ammo I was carrying in the magazine at the end of the year and cycle in fresh rounds. I'll also replace rounds that have been chambered multiple times but not fired as you sometimes get bullet setback that can lead to higher than expected pressures due to the bullet being driven deeper into the shell casing compacting the powder more or just impacting the overall cartridge length to the point it could impact reliability.
    For the longest time I carried "Israeli" with a loaded mag but empty chamber but now I keep one in the pipe.
  2. Oct 30, 2024 at 9:54 AM
    #62
    PermaFrostTRD
    Northern NY
    • I will shoot my carry/SD mags (3) first at the "range" (Speer Gold dot 124gr). Just so the barrel is cold and I'm "rusty" as that's how it will be in a SD scenario.
    • 50-150 rds of range ammo depending how I'm feeling/shooting; 115-124gr mixed.
    • finish with 20 rounds (2 mags) of carry/SD ammo to see if I learned or changed anything.
    • reload the 30 rounds/3 mags of carry/SD ammo and be on my way.
  3. Oct 30, 2024 at 11:09 AM
    #63
    Bought2Pull
    Bought2Pull [OP] New Member
    Greg
    WV
    2006 Tundra 4 door
    I need to shoot more.....
    Jackstraw likes this.
  4. Oct 30, 2024 at 11:19 AM
    #64
    rustbucket60
    rustbucket60 New Member
    W.V.
    2023 1794 blueprint blue
    Taurus 357 revolver . Inherited from father
    Bought2Pull[OP] likes this.
  5. Oct 30, 2024 at 12:04 PM
    #65
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Oh shit, we're talkin' race-gun now!! :bananadance:
    Czechmate "Parrot"
  6. Oct 30, 2024 at 7:53 PM
    #66
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Ordered a threaded barrel for the PPQ this morning. May actually go for a suppressor on that baby.
  7. Oct 30, 2024 at 8:43 PM
    #67
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    Back in the 90s I bought a CZ52 from a coworker that shot a 7.62 x 25 he warned me ahead of time it was a hot round and would take the gun back if I didn’t like it, he was right over 1500 fps mated to a light 30 cal bullet didn’t make for an accurate gun. I later bought a Glock 20 which I liked a lot better
  8. Oct 30, 2024 at 8:49 PM
    #68
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    Capacity is a big determinate for me. Being overprepared is always better than being under prepared.
  9. Oct 30, 2024 at 9:10 PM
    #69
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Apparently, that round, FMJ, can defeat soft body armor.
    After the Aurora, CO movie theater massacre, upon learning the attacker wore body armor, I considered the carry of Tok Yugo in 7.62x25 in case I ran into such an outfitted attacker. I ended up buying my first 1911 and working on head shots.
    The Tok isn't safe to carry with a round in the chamber and getting a 1911 made to shoot 7.62 x 25 was out of my price range.
  10. Oct 31, 2024 at 10:11 AM
    #70
    kevine0001
    kevine0001 New Member
    Kevin
    Mag capacity is a concern depending where I'm going. However, 99% of the time, I just pocket carry my Ruger LCP (gen1), that only has 6 round mag. I usually carry an extra mag. I've been on this earth for over 50 years and never needed. If (and that's a big IF), I need more than 12 rounds in a shoot out, I'd be looking for ways to avoid or get out of the situation first, or at least when I reload that second mag.
    I have an M&P9c, holds 10, but it's much bigger and uncomfortable IWB. Honestly, best defense is to just stay out of trouble and areas where you can get into trouble.
  11. Oct 31, 2024 at 10:41 AM
    #71
    BuzzardsGottaEat
    BuzzardsGottaEat New Member
    '16 Tundra DCLB
    Round Tires
    Being over prepared would be educating yourself and training and entirely independent of capacity.
  12. Oct 31, 2024 at 10:43 AM
    #72
    Backslider
    Tooele, UT
    All due respect, which at this point seems to be very little, you know nothing about me. I am trained. I am educated. The idea that you will only ever need 6 rounds or you're fucked regardless is and old and broken fairlytale.
    I can refer you to several professionals who have and will publicly agree with me. Had you been appropriately training, you would understand without the need for me to inform you that there are a thousand variables, and the limited, fantasy scenario you are training for is likely not what you will experience.
    ETA: I do agree, however, that training and knowledge are also great forms of overpreparedness.
    17+1 > 6
    6 > 0
    Knife > fork
  13. Oct 31, 2024 at 10:51 AM
    #73
    Backslider
    Tooele, UT
    On the topic of being prepared with knowledge; in a single attacker situation, unless you hit an airway or vital organ, which no matter how often you train may prove difficult for various reasons (heavy clothing, partial or full cover, poor aim due to being in an unfamiliar and stressful situation, body composition, etc) an attacker may remain conscious and able to continue an attack until they have ~40% blood loss.
    Further, consider a catastrophic event. Perhaps the situation is so large that no one is coming to help you and it's several hours or even days until you make it back home. Is it particularly knowledgable to assume that you will only ever need a firearm to deal with a single attacker? I'm personally more concerned about this scenario than a single attacker, as my situational awareness is phenomenal and I practice avoidance above all else.
  14. Oct 31, 2024 at 11:18 AM
    #74
    Kung
    KG, VA
    Indeed. As I've heard many times, "Best way to handle an armed confrontation is to avoid getting into one in the first place."
    Sonicbluerider and kevine0001 like this.
  15. Oct 31, 2024 at 12:02 PM
    #75
    BuzzardsGottaEat
    '16 Tundra DCLB
    Round Tires
    More prepared > more rounds, and almost all common/popular CCWs since most of us were born range from 7-10 (+1) up to 15-17 (+1) rounds.
    I’ve never once trained for some dumb made up scenario, can’t stand “gun guys” who do, and got most of my experience from exchanging fire with peeps hunting me on their turf.
    Deep breath, pops :wave:
  16. Oct 31, 2024 at 12:44 PM
    #76
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    The closest I came to having to defend myself with lethal force happened 20 feet from my front porch. The attacker was a man I'd never spoken with but have helped his family out of a tight spot twice.
    I had no idea he was going to do that or I'd have stayed inside all day. You just never know.
    As for "disengaging," not possible. He rushed in unannounced and literally backed me up against a rail with a 12 foot drop to the ground.
    In my case, carrying pepper spray saved his life and saved me a lot of expense. I have no doubt I would have prevailed in court had lead been loosed but it would have made the news, maybe nationally.
    So, talking about training and preparedness, how many of my fellows here carry pepper spray?
  17. Oct 31, 2024 at 2:30 PM
    #77
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I find pepper gel better due to wind.
  18. Oct 31, 2024 at 2:34 PM
    #78
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    <scratching in my notepad>
    get some pepper spray
    fox labs, right?
  19. Oct 31, 2024 at 2:36 PM
    #79
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    I keep some in the trailer, but otherwise no.
    Tripleconpanna likes this.
  20. Oct 31, 2024 at 2:52 PM
    #80
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Fox Labs and Sabre Red are my go to's, but Fox Labs has to go into a belt case.
    From what I've read and seen used, gel is a bit slow to work. Stream for me and mine. Just be aware of wind direction and reposition before deployment if necessary to keep the wind on your side. I prefer the Mark VI container so I can use the pocket clip, Fox Labs doesn't appear to offer that. I think the attacker dyed green for a month is a nice touch.
    The attacker I spritzed, well, it really made an impression on him. Definitely "stopped what he was doing." LOL
    Pepper spray goes on weak side, every time. Not much good if you don't have it.
  21. Nov 30, 2024 at 4:05 PM
    #81
    Solid Snake
    Solid Snake The Anciet of Mu Mu
    West TN
    2006 AC 4x4 V8
    I'm pretty much in this camp. I carry a Ruger Speed-Six (2.75 in barrel) in .357 mag with six additional rounds on my belt. I like the gun, I'm proficient with it, I trust it, its comfortable. And one advantage revolvers have is that they don't spit "evidence" all over the place....just in case.
    MadMaxCanon[QUOTED] likes this.
  22. Jan 22, 2025 at 9:10 PM
    #82
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    The pistol that I had in mind, the one that led me to start this thread, came into my hands today!
    Money is tight, I literally paid for this thing on a layaway plan, three certified checks. Local FFL got it in a couple weeks ago and today I was over to town anyway, picked it up.
    IT'S AN UGLY GUN! It really does "look like a Hi Point." :rofl:
    Sights are pretty good though and are easy to pick up both lights on and in the dark. Have to shoot it. Came with the reversible mag release, extra backstrap, and case. May have to do something to the grip, it is indeed "a bit slippery" as I have seen online. Hiding it from the wife for the time being.
  23. Jan 22, 2025 at 9:19 PM
    #83
    Lots-O-Dogs
    Lots-O-Dogs New Member
    Mark
    Walther makes a nice gun. I have a few of them. Enjoy!
  24. Jan 22, 2025 at 9:31 PM
    #84
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    I have a P-07 and a Scorpion 3+. They make some fine weapons. Aside from that comment, I have to ask you why several of those weapons sitting in your pic are cocked?
  25. Jan 22, 2025 at 9:56 PM
    #85
    SD Surfer
    Bruce
    So Cal
    The 1911's and the SP-01 are all designed to be carried in Condition 1, or "Cocked and Locked".
    Hammer back, safety on.
    JMGmanAZ and Bought2Pull[OP] like this.
  26. Jan 22, 2025 at 10:08 PM
    #86
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    I carry my 1911's cocked and locked. In fact, my shoulder holster, will only allow cocked and locked carry.
    (Andrews Leather monarch shoulder holster---the best shoulder holster I have tried).
    Gosh, 21 or so years ago, when I first began to consider a 1911, I actually wanted a Para Ord "LDA" (light double action) so that I could carry a 1911 hammer down to keep from "scaring the sheep." Now I don't care if they are scared or not.
  27. Jan 23, 2025 at 3:56 AM
    #87
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    Me / we go heavy. Two" bond "arms Derringers 45/ 410 barrels.
    JMGmanAZ likes this.
  28. Jan 23, 2025 at 8:20 AM
    #88
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Ah the days when I could "feel safe" with a loud knife.........(derringer). LOL
  29. Jan 23, 2025 at 8:30 AM
    #89
    MARanger
    MARanger Lost in the woods
    Andy
    Home of Friendly's Ice Cream
    2017 Super White SR5 DC 4X4
    In a capacity limited state, I carry what I’m most comfortable with. It used to be a shield, now it’s a 365xl. In
    summertime in shorts it’s a smith 442 revolver. Any which way I can only have 10 max.
  30. Jan 23, 2025 at 8:44 AM
    #90
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    I carried a J-frame for years. It was what I had on me during two of the most stressful events of my life: an attack by a deranged man and standing up to what I believe was a 3-man burglary team I surprised one night.
    You'd think after the foiled burglary I'd have begun to carry something larger but no I simply put on Crimson Trace laser grips and a speed strip reload. SMH! LOL
    This PPQ I just bought came from a capacity limited state since it came with two 10-round mags when design capacity is a 12-rounder. I have already ordered three 12-rounders for it.
    Sig 365XL but only 10 rounds? Do you simply prefer the longer barrel and sight radius over the smaller 365?
    BillyB and AZBoatHauler like this.
