Should there be rust here?
Discussion in '3rd Gen Tundras (2022+)' started by mrlittlejohn, Oct 31, 2024.
  1. Oct 31, 2024 at 6:26 AM
    mrlittlejohn
    mrlittlejohn [OP] New Member
    Michael
    2022 Toyota Tundra Limited
    I was out looking for a light switch near my OBD port, as I am looking for a place to tap power for some cabin lighting I would like to add to my truck. While under the dash looking for it, I observed rust on the brake pedal assembly. I looked around more and found rust on metal under the drivers seat also. For a truck that is only 2 years old... I am shocked by this. Should I consider this normal?
    Thanks for your inputs,
  2. Oct 31, 2024 at 6:29 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    There are a few other posts about this, & yours looks good compared to a few I've seen. It just bare metal, so any moisture will start some surface rust. If you live in a damp or salty area especially.
    mrlittlejohn[OP] likes this.
  3. Oct 31, 2024 at 6:33 AM
    Seems like poor quality control to me. Curious what others have to say. :popcorn:
    Fobroader and mrlittlejohn[OP] like this.
  4. Oct 31, 2024 at 6:37 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Not normal... I live 500' off the ocean, and my '21 does not have any interior rust (at least that's visible). I wonder if the truck sat somewhere w/windows cracked or open for an extended time prior to being put into service!?!?
  5. Oct 31, 2024 at 7:06 AM
    DRP
    DRP Old Member
    Dave
  6. Oct 31, 2024 at 7:38 AM
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    I saw something like this on my old 2010 Camry, the brake pedal assembly had some surface rust like this, I didn't worry about it then, if it really bothered me I'd just hit it with some fine sandpaper, some rust converter, and paint it flat black.
  7. Oct 31, 2024 at 8:56 AM
    The Dutch Man
    The Dutch Man New Member
    Mine has the same rust
  8. Oct 31, 2024 at 9:36 AM
    Spartanfam
    Spartanfam New Member
    West Michigan
    2024 Tundra Limited TRD Off-Road
    Having worked for a very large automotive interior supplier for 2 decades... this is common. Adding paint or coatings is a cost that OEMs typically choose to not pay for. The environmental testing (salt spray, etc) is often N/A for interior steel components that are not Class A surfaces... ie: Floor Console brackets, IP crossbeams, seat frames, etc.
    Raven67 and mrlittlejohn[OP] like this.
  9. Oct 31, 2024 at 11:06 AM
    Use some of this…
    I went through the same ordeal two decades ago when I bought my Tundra new. Rust was existing on the backside of the front bumper coming through the fog light openings.
    Got rid of it pretty quickly but because it was an exterior item, I had to reapply it every 2/3 years.
  10. Oct 31, 2024 at 11:31 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Every Toyota I've torn down that far had rust like that. Looks like nothing has changed in 30 years.
