Jackery unit question
Discussion in 'Off-Topic Discussion' started by Tundra234, Oct 14, 2024.
  1. Oct 14, 2024 at 6:35 PM
    Tundra234 [OP] New Member
  2. Oct 14, 2024 at 7:27 PM
    des2mtn
    On the Scenery, Looking at the Road
    2004 Black DC Limited 4x4
    Tonto cover
    Jackery, Anker, Ecoflow etc are typically rated in watt-hours to measure how much energy they will be capable of storing. This article will help guide you through the math
    https://www.jackery.com/blogs/buying-advice/what-can-jackery-1000-plus-run
    Your humidifier draws 130 watts, so it should consume 130Wh in one hour of non-stop runtime. If you got a Jackery 1000 (1264Wh), it would operate for for just over 8 hours on one charge. 1264Wh x 0.85 discharge efficiency ÷ 130 watts = 8.26 hours
    Mater likes this.
  3. Oct 31, 2024 at 4:30 AM
    I did my first test last night. I ended up getting the Ecoflow Delta 2 that is 1800 watts and 1024 watt hours. I started the unit at 8 pm at 95% battery charge. When I got up at 530 it was at 7%. The air dryer actually pulled 122 watts. It cycles on and off every few minutes. 400 watts of solar should be able to get it through the night until the sun returns. Keep in mind that this dryer is for 1000 cubic feet. I'm considering a 500 cubic foot model for the travel trailer and that one only pulls 76 watts. I'll have to measure my open space in the trailer when it's closed up but I beleive it's right around 430 cubic feet as a guess.
