2024 SR5 voltmeter ballet
Discussion in '3rd Gen Tundras (2022+)' started by Jeff_M, Oct 29, 2024.
  1. Oct 29, 2024 at 2:27 PM
    Jeff_M
    Jeff_M [OP] New Member
    My newly acquired Tundra (10k miles) is very nice except I've noticed the voltmeter fluctuates between 12 and 15 volts pretty regularly regardless of the electric load. The needle floats up and down in an almost graceful manner. I put the Carista on and it verified that the voltage was indeed fluctuating in the same manner that the gauge indicated, probably three or four fluctuations per minute. Anyone else had this happen? I bought it over the weekend from a Toyota dealer as a Certified used car along with the remainder of the factory warranty.
  2. Oct 29, 2024 at 2:29 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    normal
    sudobash likes this.
  3. Oct 29, 2024 at 3:54 PM
    Wtundra2023
    Wtundra2023 Bad Weld Aficionado
    2023 Limited Tundra, 2014 Limited Sequoia
    I think the truck uses something similar to regenerative breaking on EVs where the alternator kicks up the volts when decelerating. It also seems to unload under acceleration.
    Raven67 likes this.
  4. Oct 29, 2024 at 6:24 PM
    Samuryan
    Samuryan Nayrumas
    Reno
    22 sr5 trd OR
    This. Smart alternator does the heavy charging when decelerating and light maintenance under acceleration to save gas
    Raven67 likes this.
