  1. Oct 29, 2024 at 4:13 PM
    bfunke
    bfunke Tundra Curmudgeon
  2. Oct 29, 2024 at 4:16 PM
    bfunke
  3. Oct 29, 2024 at 4:24 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    We do it right, because we do it thrice.
  4. Oct 29, 2024 at 4:26 PM
    Sirfive
    Sirfive Working on pavement
    ‘02 Limited AC TRD
    Bassani cat-back
    So my cap would hinge on the passenger side, and lift like the green arc. A cab height cap (blue) would hinge on the driver side and lift to follow the red arc. If done smart, the ends fold out making a door & mostly weather tight.
    found it.
    G_unit3000 and FrenchToasty like this.
  5. Oct 29, 2024 at 4:37 PM
    JakeJake
    2000 Tundra AC 4X4
    I have this one saved in my extensive collection.
    https://newatlas.com/outdoors/flip90-vw-truck-camper-rotates-roomy-backcountry-cabin/#gallery:1
    You're gonna need some 12v linear actuators so that set up is just a press of a button.
  6. Oct 29, 2024 at 4:43 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
  7. Oct 29, 2024 at 4:58 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    With a 2ur & 4-spd t-case.
    G_unit3000 likes this.
  8. Oct 29, 2024 at 5:07 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Thanks. I know my 06 has panic, I think my 03 does as well. Come to think of it I think my 03 has an LED, but I know my 06 doesn't. I'll have to look when I get home.
  9. Oct 29, 2024 at 5:13 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    We are also supposed to get rain for the next week or so. Ugh. Really puts a cramp on my foot miles. I guess I'll either be walking Walmart or I might finally get a gym membership. My right arm still ain't right. But I could stand to do some leg workouts with weights.
  10. Oct 29, 2024 at 5:26 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I noticed at work last night that my passenger front tire was low. Looked like I had aired it down. I tried to check it with my Slime brand digital gauge and it said Lo.B (low battery). I would've had the Firestone next door fill it up, but I walk that parking lot 50x a night and I see tons of tire penetratibg debris. So I drove it home 20mins while low. Wouldn't be the first time (T2S).... Paid $15 for that slime gauge like 6 years ago. Two new batteries for it was $15. What a rip off. Insult to injury, the POS was a PITA to put back together, then with the fresh batteries it still said Lo.B. I messed with it for like 30 mins, then finally went and got an analog tire gauge. 15psi... Yep that's what I air down to off road. Sketch. Aired it up before work tonight and sent it. I figure if I made it this long/far since it had 40psi Sunday when we left Merus, it'll be fine till I can have Discount Tire fix it for free Thursday on my day off. I put it at 45psi just to be safe though. If they can't patch it, I'll just pay the $45 for a new certificate and get a brand new tire. Just sucks I'll have to waste my time going there and then they'll have to order it and then waste more time when it shows up. Ugh
    bmf4069[QUOTED] likes this.
  11. Oct 29, 2024 at 5:31 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Pretty sure that's a compliment. You gotta learn Caseyese. But don't feel bad, even those of use that have been hanging with Casey for years aren't fluent yet. But we're getting there. :D
    bmf4069, SAGE63[QUOTED] and Sirfive like this.
  12. Oct 29, 2024 at 5:34 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You gonna add some leafs? I need to order longer flipped u-bolts and center pins, so I can stick Beau's Deaver AALs onto my Alcan packs. I'm supposed to be picking up a hard top Thursday, so I'll also need to swap the SOS 0.5" lowering block onto the 03 and swap it's current 1" lift (lowering) block onto the 06 as well. Then I'll likely add a 0.5" of preload to the coil overs
  13. Oct 29, 2024 at 5:37 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Been a while, but yes I think they were the tiny NEO 4.2
    I wasn't happy with the light output from the LED, because it didn't shine out towards the switch face.
    So I ended up stuffing one of the old fat incandescents in there.... hasn't melted yet:notsure:
  14. Oct 29, 2024 at 5:51 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    1. nice flex pic
    2. I am slack jawed that all that BARE metal hasn't flash rusted!
    @JakeJake Did you coat that with something?
  15. Oct 29, 2024 at 5:51 PM
    Dually
    G_unit3000 and JakeJake like this.
  16. Oct 29, 2024 at 5:56 PM
    JakeJake
    2000 Tundra AC 4X4
    baby flex, some asshole didn't provide enough wheel well clearance ;)
    She got a quick wipe with the secret sauce, but that's mostly just west Texas for ya.
    *not proven in the great white north
  17. Oct 29, 2024 at 6:00 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    In another thread we were talking about why a 10 or 15 year old truck, in the 90s, felt so old, when our 20+ year old Tundras feel so modern. And `shifty bringing up how fast things changed back then. No matrix moment necessary, it's just that technology really was so arcane back then. But a 2006 truck is pretty modern. Anyway, as much as I'd rather have a Chinook grafted onto the back of my Tundra, taking the 1970's pickup they originally came on, and making it a 4x4, is definitely appealing.
    I loved just sitting in Chinook in the driver seat, looking at the dash. It was so damn cool.
    Unfortunately I somehow didn't keep my full-resolution photos. But you get the idea. The dash pad, the knobs, the choke...
  18. Oct 29, 2024 at 6:03 PM
    MT-Tundra
    Montana
    Most (but not all) Toyota motorhomes were "foolies". They just welded another wheel onto a 1/4 ton axle. Which instead of making it stronger, actually made it weaker somehow that I can't remember anymore...but somehow putting more leverage and stress on everything.
    There were a few built on true duallys, and you can find some old one-ton axles on former U-haul Toyota pickups to swap onto a motorhome, but the true duallys were rare.
    G_unit3000 and shifty`[QUOTED] like this.
  19. Oct 29, 2024 at 6:16 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    What i'd give for an early 90's e-brake handle. Not sure i can afford custom wing vent windows.
    when i swap to a diesel, i'd like a knob so i can adjust between 50hp worth of fuel to 300hp worth of fuel and could set a flat-footed cruise control.
  20. Oct 29, 2024 at 6:30 PM
  21. Oct 29, 2024 at 6:54 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  22. Oct 29, 2024 at 6:58 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Although i'm all about running (because i'm a runner), (compound) lifting weights will mostly likely burn way more calories and be more beneficial. Walking mostly just gives you exercise, not burning very much calories whatsoever. In order to burn them walking, you would need to find a real steep up hill and (like a couple miles long) and attack it at 3~4mph...and that's with both arms pumping. Strolling along with a cell phone in one hand while google searching tundra builds is only going to get you run over by an inattentive driver. Cardio is excellent for the heart, lifting weights is what's excellent for loosing the weight. When you build up muscle from lifting weights, the muscles will burn calories while you're at rest. That means when you're sleeping, you would still be burning calories! That's why it's important to have as much of a muscle content % (opposite of body fat content). After you start building up the muscles, then you can start relying on them to do their job. It's pretty crazy how the Creator designed the human body. It's designed to be active, and when it is, it excels. When it's inactive, then the body tends to fall apart and go to the crapper.
  23. Oct 29, 2024 at 7:04 PM
    I stubbed the shit out of my toe putting a buddy to bed in big bear, he had it staked down like a tornado was headed our way!!! It took over a year to grow a new toenail. I’m a firm believer in no stakes!!!!!
    BroHon, bmf4069 and whodatschrome like this.
  24. Oct 29, 2024 at 7:06 PM
    whodatschrome
    lots of dents
    I was very heavy into both in-line skating and boarding for about 20 years. I was big into handrails. Of course many fails. After than many years of smacking my shins on rails and concrete ledges, they became impervious to pain. Literally hundreds of scars on my shins (i never wore shin guards). Pretty sure that's the same way jean claude van damme trained.
    BroHon, JakeJake, bmf4069 and 3 others like this.
  25. Oct 29, 2024 at 7:36 PM
    https://www.youtube.com/watch?v=1A3f-bUmUas
    You ever seen this guy? Videos of him occasionally pop up on Reddit. Watch it all the way thru. There's another dude I see from time to time that kicks thru rebar and all kinds of stuff. It's nuts.
  26. Oct 29, 2024 at 8:02 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    IIRC the manual trucks used the tacoma/4runner style parking brake handle. So you may be able to convert your foot brake to handle.
  27. Oct 29, 2024 at 8:20 PM
    whodatschrome
    lots of dents
    VERY impressive! No way could my shins hold a candle to his. Plus his 360 windups looked super rad with his accuracy. Training like that will make your bones a lot more dense. While he purposely trains his shins, i didn’t make that my goal. Getting a shinner was just instant punishment for not getting a good “lock” onto the handrail and banging the shin. Even though my shins became just about impervious to pain, undoubtedly my tibia bone would snap like a toothpick if i purposely tried to kick a telephone pole down. I’d probably tear the posterior and anterior cruciate ligaments along with too!
  28. Oct 29, 2024 at 8:40 PM
  29. Oct 29, 2024 at 8:59 PM
    whodatschrome
    lots of dents
  30. Oct 29, 2024 at 10:29 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Ok suspension experts, I'm thinking about combining the Solo LCAs with the Total Chaos uniball LBJs, because I want to keep the OEM tie rods and this is the most cost effective combination. Any obvious reason this wouldn't work that I may be overlooking? I already have new Toyota brand inners and outters waiting to be installed. Just waiting for the Black Friday deals to place orders.
    Mixing and matching would save me $1027 from TC current prices, then I could sell my new in box OEM LBJs (2004+).
    Or mixing and matching would save me $564 from Solo current prices, but would include heim tie rods. So I'd be looking at selling my new in box OEM inner and outter tie rods and LBJs (2004+).
    TC uniball LBJs $1086 (without heim tie rods)
    https://www.chaosfab.com/product/2004-2006-Toyota-Tundra-Lower-Uniball-Conversion-OE-Tie-Rod
    VS
    Solo uniball LBJs (only sold with heim tie rods now) $1650
    https://solomotorsports.com/shop/parts/toyota-parts/steering-toyota-parts/toyota-lower-ball-joint-uniball-conversion/?attribute_select-kit=4WD+Kit&attribute_select-vehicle=Tundra+00-06&attribute_suspension-application=Mid-Travel+(Stock+Width)
    TC LCAs $2307
    https://www.chaosfab.com/product/20...eries-Stock-Length-Lower-Control-Arms-97554-E
    VS
    Solo LCAs $1280
    https://solomotorsports.com/shop/su...a-sequoia/?attribute_variation=Big+Ball+Joint
    Definitely going to get these alignment cams and poly steering rack bushings. I need to get the billet steering rack clamp from 333 Fab.
    https://www.energysuspensionparts.com/8.10104
    https://solomotorsports.com/shop/parts/toyota-parts/suspension-toyota-parts/toyota-alignment-cam-tab-upgrade-kit/?attribute_kit=Octagons,+Bolts,+and+Cam+Tabs&attribute_vehicle=1st+Gen+Tundra
    https://333fabrications.com/products/hd-billet-rack-clamp
