Terrible Experience with Rokblokz Customer Service
Discussion in 'Wheels & Tires' started by Ryanb343, Oct 29, 2024.
  1. Oct 29, 2024 at 8:46 AM
    Ryanb343
    Ryanb343 [OP] New Member
    2024 Tundra TRD Off Road
    "3 factory lift kit, "35 Toyo Open Country Tires, Diamondback SE Cover
    Purchased a set of Rokblokz XL Mud Flaps for my 24 Tundra with the "3 factory lift kit and "35 Toyo Open Country Tires. I was having some issues with rubbing between the front tires and mud flaps (even after trimming them) and I was told Rokblokz could help.
    After installing the Rokblokz front flaps I noticed that the screws stuck out a decent amount past the flap. I did not drive the vehicle but simply cranked the wheel to both sides to confirm clearance. The wheels very slightly rubbed against the screws. I immediately removed the flaps and contacted Rokblokz. I told them the truth that I did install the flaps to test the clearance however I did not drive the vehicle and the hardware was in perfect condition. Rokblokz told me because I installed the flaps on my vehicle I had lost the ability to return the product, regardless of the condition. They told me that I should attempt to sell them on Facebook Marketplace. Everyone knows that Rokblokz is overpriced, for that you would think they would have better customer service and a better return policy.
    The issue of rubbing between tires and front flaps is common for Tundra owners who opt to upgrade their tires. I wanted to post this as warning for Tundra owners that are looking for a fix for this issue. Looks like Rokblokz is not the answer and I made a $200 mistake.
    TLDR: Purchased Rokblokz XL flaps for my Gen3 Tundra to alleviate occasional rubbing between front tires ("35s with a"3 factory lift) and trimmed factory flaps. Flaps did not fix the issue and when I tried to return them (in perfect condition), Rokblokz told me good luck on FB marketplace. I regret trusting a company with such an awful return policy.
  2. Oct 29, 2024 at 8:56 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    This is not any issue with Rokblokz. Their return policy clearly states the item can not be installed and then returned.
    Problem is that you were not aware of that, didn't look it up, before purchasing. So this is on you unfortunately.
    From their website
    RETURNS
    Products sold by ROKBLOKZ are covered by this Standard Return Policy and must be returned within 30 days of the original invoice date for a refund or exchange. All returns require an RMA (Return Merchandise Authorization) Number, and freight charges are strictly non-refundable. Return shipping is the responsibility of the buyer. Items are eligible for return only if they are unopened and in NEW condition. This means that items that are mounted, partially mounted or assembled are not eligible for return. Products received without an RMA # will be refused.
    GODZILLA, Fotnot and PolishedTRD like this.
  3. Oct 29, 2024 at 9:14 AM
    Ryanb343
    Yes Frank, I am aware. The purpose of my post was to warn other Tundra owners that have a similar issue, that Rokblokz is not the solution. I am also pointing out that it is a terrible return policy. How many customers try to return their product after a week? Do you think that materially cuts into their bottomline, if so the problem is not with me. I'm sure they appreciate you rushing to their defense though, hopefully they send you a 5% discount code. Have a nice day.
  4. Oct 29, 2024 at 9:55 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Hot damn. Here we go. Those darn first year pledges. :stirthepot::smash::popcorn:
  5. Oct 29, 2024 at 10:05 AM
    frichco228
    Frank
    Virginia
    chill. I am not defending the company. I know nothing about them or their products or business. I only checked them based on your post and I easily found their return policy in a .03 second google search.
    Nor am I discounting your pain/experience.
    Just stating facts. Can't expect them to return installed parts when they specifically state they will not accept installed returns. Ill stay clear of your posts going forward.
    GODZILLA likes this.
  6. Oct 29, 2024 at 10:07 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    He's trying to blow up Reddit too...
    Come on, you put bigger tires on your truck and replacement parts don't fit with them?
  7. Oct 29, 2024 at 10:11 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    these are fun first timers' posts.
    hi, i'm here to b!tch about a vendor because of their policies stated.:wave:
    :popcorn:
  8. Oct 29, 2024 at 10:32 AM
    TaquitoBandito
    Joel (AKA Bif)
    I think it's kinda genius. 48 more complaints/posts and he can sell them on here. :pccoffee:
    hagrid, kirkb, jewsNbrews and 5 others like this.
  9. Oct 29, 2024 at 10:34 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    i thought about that. idk if i can hang around that long. i want to buy them for my sequoia. if they don't fit, i'll just see if he'll take them back
  10. Oct 29, 2024 at 10:43 AM
    TaquitoBandito
    Joel (AKA Bif)
    Doublecheck his return policy before you do. A lot of dumbasses don't think to do that and then they get online and bitch about it.
  11. Oct 29, 2024 at 10:46 AM
    Ryanb343
    Yeah, sorry if I'm new here. 35s are not uncommon for Tundras with lift kits. Just trying to warn Tundra owners with a similar issue that Rokblokz did not work for me and their return policy makes it an expensive gamble to try. Why is that a problem?
  12. Oct 29, 2024 at 10:47 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    We can start with you starting off your first experience like this....
  13. Oct 29, 2024 at 10:48 AM
    TaquitoBandito
    Joel (AKA Bif)
  14. Oct 29, 2024 at 10:48 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    we can also go with you putting it in the "wheel & tires" thread instead of....oh, i dunno....
  15. Oct 29, 2024 at 10:49 AM
    Ericsopa
    Ericsopa Old man and the sea
    Seems the world is full of 'em these days ..... whiners, I mean.
    jewsNbrews likes this.
  16. Oct 29, 2024 at 10:49 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    also, for what it's worth.....
    i like your truck. looks good with the lift and 35s
  17. Oct 29, 2024 at 10:50 AM
    PolishedTRD
    PolishedTRD Lorem ipsum dolor sit amet
    CO
    Supercharged 2011 DC
    Magnuson's Finest Whine
    This thread says more about you than it does RokBlokz return policy, or their customer service.
    You voided the possibility of a return.
    They wished you good luck on FB marketplace. That was pretty nice of them.
  18. Oct 29, 2024 at 10:51 AM
    Ryanb343
    Guess I didn't see it. I appreciate you pointing it out to me. I feel so welcome here lol.
  19. Oct 29, 2024 at 10:52 AM
    TaquitoBandito
    Joel (AKA Bif)
  20. Oct 29, 2024 at 10:52 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
  21. Oct 29, 2024 at 10:54 AM
    TaquitoBandito
    Joel (AKA Bif)
    Be thankful @hagrid hasn't sniffed you out yet. That dude is brutal.
  22. Oct 29, 2024 at 10:54 AM
    PolishedTRD
    CO
    You came here to shit on a vendor, whom many of us have used (myself included). What did you expect?
    TaquitoBandito and Fotnot like this.
  23. Oct 29, 2024 at 10:55 AM
    Ryanb343
    First kind reply, thanks Fotnot, I may stick around after all.
  24. Oct 29, 2024 at 10:56 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    we've got a lot more to offer than sarcasm and hazing.
    but you should be aware....those 2 are the main dish. so filling up on sides may be a better option if you so desire. but there's always room at the table
  25. Oct 29, 2024 at 10:57 AM
    AZBoatHauler
    So.Arizona
    That charm is how you ended up with 9 kids.
  26. Oct 29, 2024 at 11:00 AM
    TaquitoBandito
    Joel (AKA Bif)
    That he knows of.
  27. Oct 29, 2024 at 11:00 AM
    TaquitoBandito
    Joel (AKA Bif)
    And 45...
    kirkb, RainMan_PNW and jewsNbrews like this.
  28. Oct 29, 2024 at 11:03 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    the tax people and wife only know about 5 though. so keep your damn voice down
  29. Oct 29, 2024 at 11:04 AM
    Ryanb343
    I'll be here all week.
  30. Oct 29, 2024 at 11:06 AM
    TaquitoBandito
    Joel (AKA Bif)
    I expect him at any moment. He's probably still setting up his traps for Halloween.
    hagrid, RainMan_PNW and jewsNbrews like this.
