Three 3rd Gen Tundras - two radiators
Discussion in '3rd Gen Tundras (2022+)' started by Eurodriver, Oct 29, 2024.
  1. Oct 29, 2024 at 8:24 AM
    Eurodriver
    Eurodriver [OP] New Member
    It cost me a thousand bucks to replace the radiator on my 2022 garage queen when it began to leak, but now my 24 grocery getter is leaking coolant as well. This is from the main tank not the intercooler side.
    I haven't seen this pop up much on this forum, but it seems to be a common problem with me. What's up?
  2. Oct 29, 2024 at 8:28 AM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra LB
    None
    Should be warranty work unless there is obvious damage.
    Where is the leak?
  3. Oct 29, 2024 at 9:59 AM
    Eurodriver
    I don't know, but I can smell it and the coolant level is dropping.
  4. Oct 29, 2024 at 10:05 AM
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    Did you check for bullet holes? :D
  5. Oct 29, 2024 at 10:18 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I just toss some of these into the overflow tank and no more leaks! :)
    I think the magic is the sawdust and tire sealant in a handy tablet.
