New error - P0705 drive start control error
Discussion in '3rd Gen Tundras (2022+)' started by Jymbeux, Oct 28, 2024.
  1. Oct 28, 2024 at 8:51 PM
    Jymbeux
    Jymbeux [OP] New Member
    James
    Washington
    2022 MGM Tundra DC limited TRD OR
    Tonight I made it two blocks away from home and had a P0705 fault with a drive start control error message. Turning off and on made no difference. Felt sluggish immediately. Checked on scanner and got the code. Reset it on a whim. Turned on , still showing reverse light no matter what gear. Turned off and checked underneath, no fluid leaks or anything - started up and all was normal. Looks like it needed to sit for a minute or two to clear. I'll take to dealership tomorrow.
  2. Oct 29, 2024 at 4:54 AM
    troutback
    troutback New Member
    2023 Blueprint SR5 CC
    that's odd. I had a similar code when I pulled into a parking spot too fast and shut it down. maybe just a warning...
  3. Oct 29, 2024 at 7:46 AM
    Jymbeux
    James
    Washington
    This happened while moving from a stop light. R lot up on the PRND lights and the rear camera activated and flashed back and forth between camera and Android Auto. I shifted to park/reverse/drive and it sounded bad and lurched.
  4. Oct 31, 2024 at 6:12 PM
    Jymbeux
    James
    Washington
    Dealership said to drive it until it happens again. So it left me stranded tonight and is being towed. Dealership said if it's anything electric/sensor it's not covered by drive train warranty. Crappy.
    WhiteSR5 likes this.
  5. Oct 31, 2024 at 6:24 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    I would double check that. Typically, powertrain warranty includes all electronics related to the powertrain.
  6. Oct 31, 2024 at 6:39 PM
    Jymbeux
    James
    Washington
    I'll definitely double check. This dealership's service department has been underwhelming. Of course, the Tundra has not been a great experience overall so far. My 2012 Tacoma was bomb proof.
    woods and 389 24/7 like this.
  7. Nov 6, 2024 at 2:25 PM
    Jymbeux
    James
    Washington
    Failed shifter/shift position sensor. They're denying warranty.
  8. Nov 6, 2024 at 2:56 PM
    Wtundra2023
    Wtundra2023 Bad Weld Aficionado
    2023 Limited Tundra, 2014 Limited Sequoia
    I'd call Toyota North America and talk with them.
  9. Nov 6, 2024 at 3:00 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    How many miles? it’s a 2022?
    that should be a relatively inexpensive repair, but damned if that isn’t some B.S.
    I might have some words for Toyota
    Jymbeux[QUOTED][OP] likes this.
  10. Nov 6, 2024 at 4:33 PM
    Jymbeux
    James
    Washington
    2022 with 48k miles. It could be inexpensive but since it wasn't drivable I had it towed to dealership. So I'm pretty stuck. I do all my own maintenance so I would have done the repair myself if I had known they wouldn't cover warranty. I should have known though, they were spinning theories of chewed wires by rodents before they even saw the vehicle. They said warranty is only for parts that touch oil/lube, no electronics. Warranty doesn't really say for sure. Only electronics I'm seeing is the engine control computer.
  11. Nov 6, 2024 at 5:01 PM
    Wtundra2023
    I feel like engine control computer could be construed as including the sensor.
  12. Nov 6, 2024 at 5:20 PM
    389 24/7 125k on the gen3
    Oregona
    2022 TRD OR
    Nada
    I had a 2013 taco
    Totally agree
  13. Nov 6, 2024 at 5:44 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    I’d definitely bring this up to Toyota N.A. IANAL… but generally speaking, a vehicle needing to be towed indicates the failure of a drivetrain component.
    woods and Jymbeux[OP] like this.
  14. Nov 6, 2024 at 6:18 PM
    Jymbeux
    James
    Washington
    Good call. I'll call them tomorrow before picking it up
  15. Nov 7, 2024 at 7:05 AM
    Jymbeux
    James
    Washington
    Called Toyota today. They said it's not covered because it's not specifically listed in the document I shared a snip of earlier.
    It dropped power while driving - you'd think that would be a safety concern too. My last two Toyotas were great and this one has been a mess. The lack of support is super surprising though.
  16. Nov 7, 2024 at 5:26 PM
    Jymbeux
    James
    Washington
    After replacing the sensor they experienced issues shifting etc. so now it's being examined for transmission issues. Apparently the tech took it on a test drive and didn't make it far. Not sure if they towed it or drove it back after they noticed the problem.
    troutback likes this.
  17. Nov 7, 2024 at 7:39 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Hope they get it figured and do you right
  18. Nov 10, 2024 at 4:11 AM
    troutback
    Sounds like it needs a transmission. Keep us posted.
  19. Nov 11, 2024 at 7:02 PM
    Jymbeux
    James
    Washington
    That's what it sounds like to me. It wasn't grinding or crunching but it's it lurched when trying to get into neutral and park.
  20. Nov 14, 2024 at 1:08 PM
    Jymbeux
    James
    Washington
    Latest update - water intrusion in the tail light assembly caused a short to ground. So now another week wait for parts.
  21. Nov 14, 2024 at 1:23 PM
    Lee.M
    Lee.M New Member
    TN
    24tundra limited 4x4
    Level/35s
    Man that’s wild my neighbor's ford did that. Except would make the trucks alarm go off randomly and the parking lights would stay on.
  22. Nov 14, 2024 at 1:54 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    Did Toyota hire Ford engineers for the 3rd generation Tundra development?
    It would explain a lot.
    Balzac and troutback like this.
  23. Nov 19, 2024 at 1:39 PM
    Jymbeux
    James
    Washington
    Just shy of 3 weeks later. I got the truck back. Left reverse/backup lamp assembly short was the issue.. from what I can tell. The story seemed to change constantly. They recreated the failure and drove it that way nothing a chirp as it tried to engage reverse while moving forward. According to the notes they repeated this unplugging lights until they figured out the cause. Hopefully no permanent damage from this. Reassembly of the shifter area they crunched a USB connector I had routed for a QI charger and they dumped everything that was in the way into the driver's floor mats and left it that way.
    Balzac likes this.
  24. Nov 19, 2024 at 3:55 PM
    Balzac
    Balzac New Member
    L
    2023 Tundra Limited CrewCab, TRD OR
    Tonneau cover, added layer of ice, mud or dust
    There are many complains about dealers on this forum. But none is named. Is it against Code of Conduct? If there any place to read about which is the best dealer in my area?
