WIRING GRILL LIGHTS
Discussion in '3rd Gen Tundras (2022+)' started by Coronerrpm, Oct 28, 2024.
  1. Oct 28, 2024 at 12:12 PM
    Coronerrpm
    Coronerrpm [OP] New Member
    Bob
    22 tundra red sport
    Non yet
    Ordered two led lights for the grill on my 2022 Tundra. Followed instructions and tap a fuse to the INJ (injector) as stated. Well, I find out every 6 hrs or so the truck does a system check or something like that when not running and the lights come on. Where can I tap into where the lights are on with the truck all the time when running? ING (ignition) or will that also system test every few hours? Thanks
  2. Oct 28, 2024 at 1:18 PM
    22TXAG
    22TXAG New Member
    One option is to use the 7.5 amp fuse labeled TOWING-IGN
  3. Oct 28, 2024 at 1:27 PM
    Coronerrpm
    Bob
    22 tundra red sport
    Non yet
    Thanks, under the hood fuse box?
  4. Oct 28, 2024 at 1:41 PM
    22TXAG
    22TXAG New Member
    Correct. Passenger side under hood. Not sure if you have the hybrid or not but this is the non-hybrid fuse box.
  5. Oct 28, 2024 at 3:08 PM
    Coronerrpm
    Bob
    22 tundra red sport
    Non yet
    OK thank you
