  1. Oct 28, 2024 at 4:57 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    I might need to get one of these. I have one of the normal "fast charger" Amazon ones. It manages to overheat the phone more than it charges it...
    French Avocado and Pimpala1962 like this.
  2. Oct 28, 2024 at 5:17 AM
    zasdds
    zasdds New Member
    2021 Platinum Crewmax
    Does this work better than the SE Toyota "OEM" version? I purchased the kit and installed from Sparks Parts but performance was terrible. Would not stay charging likely due to the camera "bump" on newer iphones that prevents the phone from lying perfectly flat. The design of this version may work better
  3. Oct 28, 2024 at 5:21 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Get the phone case that's compatible with the magnetic charger and you will be fine.Phone stays in place
  4. Oct 28, 2024 at 5:39 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Supposedly, yes. But i dont have the oe version to compare to. I have a case on my iphone 12 pro max with magsafe and it charges just fine for the short test run i did. This is the case i am using and it puts the backside leveled with the camera bump.
    https://a.co/d/aOWWZ5Y
    BR73 and zasdds[QUOTED] like this.
  5. Oct 28, 2024 at 7:08 AM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Takes about 15 minutes or so. The most difficult part is removing the large piece of trim below the glove compartment since the tabs can be finicky. That allows access to the blower. The three screws holding the blower in are T20 torx heads, just an FYI.
    WFD473, Mater, BlueRibbon4x4 and 3 others like this.
  6. Oct 28, 2024 at 7:21 AM
    PermaFrostTRD
    Northern NY
    Thanks!
    bulldog93[QUOTED] likes this.
  7. Oct 28, 2024 at 7:42 AM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    You ask you shall receive. :D
  8. Oct 28, 2024 at 8:22 AM
    ToyoGood
    ToyoGood New Member
    DFW
    White 2020 Tundra TRD PRO Double Cab
    I made the switch from 0W-20 to Kirkland 5W-30. It has been said that using 5W-30 will quiet the engine and I was skeptical about that. They are right, it does make a difference.
  9. Oct 28, 2024 at 8:35 AM
    roughfisher
    roughfisher Aggressive hockey is back in town!
    JP
    Northern Minnesota
    2021 MBM CM SR5 TRD OR 4x4
    Love it! here's my grateful fred badging
  10. Oct 28, 2024 at 8:41 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  11. Oct 28, 2024 at 8:44 AM
    roughfisher
    JP
    Northern Minnesota
    I am fully aware my good man! the badge was one of my first mods and got slapped on long before I became aware of your magnificent Project "Blackhole" in my wallet ;). You are still the King! and I can certainly debadge if you like to show my reverence! :bowdown:
  12. Oct 28, 2024 at 8:46 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    LOL! Awesome badge might need one for the tool box here at home lol
    Blackhole.. fml that's more accurate.
  13. Oct 28, 2024 at 8:47 AM
    Who made the badge?
    reywcms likes this.
  14. Oct 28, 2024 at 8:48 AM
    roughfisher
    JP
    Northern Minnesota
  15. Oct 28, 2024 at 8:54 AM
    PermaFrostTRD
    Northern NY
    Nice!!
    BR73 likes this.
  16. Oct 28, 2024 at 12:44 PM
  17. Oct 28, 2024 at 1:32 PM
    713Tundra
    713Tundra New Member
    HTX
    2017 BBP Limited TRD OR CM
    Reached a milestone. Sorry for the blurry pic. I had to take the pic while driving last night. Now, time to get my sticker from Toyota!
    OHwendTrd, Ted4311, rob1208 and 14 others like this.
  18. Oct 28, 2024 at 1:34 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Nice! :thumbsup:
  19. Oct 28, 2024 at 2:31 PM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Does toyota really give a sticker for 100k?
  20. Oct 28, 2024 at 2:32 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Winter is coming.
  21. Oct 28, 2024 at 2:34 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Thought that was a tiny sweater on the middle can
  22. Oct 28, 2024 at 2:46 PM
    713Tundra
    HTX
    I do believe so. I've read it here and on other Toyota forums/reddit. You either can send an email to toyota_social@toyota.com or fill out this request form. You need to attach a pic of your odometer reading, though.
  23. Oct 28, 2024 at 3:15 PM
    woods
    woods New Member
    2021 SR5 TRD Sport
    That's cool, thanks for supplying the links!
    DPF88130 and CaptRussia253 like this.
  24. Oct 28, 2024 at 3:20 PM
    Pimpala1962
    Pimpala1962 New Member
    Kyle
    Massachusetts
    2015 double cab
    Where are you located? Is 5w-30 ok for northeast winters?
    HulkSmurf14 likes this.
  25. Oct 28, 2024 at 3:30 PM
    pkeawe809
    pkeawe809 New Member
    PK
    Westside, Oahu
    2018 Super White TRD 4x4 CrewMax
    ~Chrome Delete interior AJT/Tuff skins ~Driver side Grab handle OEM ~Revesol Leather Steering Wheel ~Front Console upgraded to Limited Leather Trim ~Switched Center Instrument panel from silver to black ~Switched black molding trim pieces to Wood grain ~Wood grain Shift Knob ~LED interior lights- meso customs ~Husky X-act Front Driver and Passenger Floor-mats ~Clazzio Seat covers ~Pedal Commander ~Front Windshield heat protection clear film ~VLEDS Footwell LED light kit-driver and passenger sides ~ESP Under Rear Seat storage bins ~4- Door Speakers- JL C1-650 component speakers ~Front Dash Hertz Speakers ~Zapco ST-4X DSP III 100Watt Component Speaker Amp ~Zapco ST-500XM II 500Watt Subwoofer Bass Amp ~1-Rear 10” Subwoofer and Box enclosure ~Sail panel speakers-Hertz tweeters ~Noico 80 mil Sound deadener on all 4 door panels ~Morimoto Headlights-amber DRL ~Diode Dynamics SS3 Pro Foglights ~OEM Tail lights Hot Tails” option A upgrade by Hot Shot Offroad ~Anytime Front and Rear Camera-Trail Grid Pro ~Precision LED lights-rear bed light, lic plate light ~Retrax Pro XR Bed cover ~Auto Rear tailgate lock OEM ~Repaired rust spot and Repainted Roof 7/22 ~De-badged and removed Stickers ~TRD Dual Exhaust w/black chrome tips ~Valhalla Cat Security Shields-Black powder coated ~Black powder coated TRD skid plate ~Red powder coated front Tow Hooks ~Coachbuilder +2 Shackles 1.25” lift ~TRD Pro Grille ~TRD Pro Skid plate ~TRD front/rear Sway Bars ~Bilstein 6112 front shocks ~Bilstein 5160 rear w/resi ~Nitto Ridge Grapplers 35x12.50R17 ~Icon Alloys Rebound Rims 17x8.5 ~Window Tint
    Just like every white Toyota truck is called Stormtrooper lol Although Darkstar is a little more less common
    woods likes this.
  26. Oct 28, 2024 at 3:40 PM
    Tundra family
    Tundra family New Member
    And some swag at 200
  27. Oct 28, 2024 at 3:46 PM
    Tundra family
    The usual VVT noises or something more? I have a lil noise at idle, been told it's common on the 3UR
  28. Oct 28, 2024 at 3:59 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Thinking about using my deck rails as a mounting point for some additional chase lights… wondering if S1 should be sufficient or if I should use S2 or Squadrons…
  29. Oct 28, 2024 at 4:03 PM
    Yep, just email them your information and a picture of the odometer.
    woods[QUOTED] likes this.
  30. Oct 28, 2024 at 4:04 PM
    Very cool
    biebs96 likes this.
