2017 TRD Pro Bumper & Suspension
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by rtkman, Oct 23, 2024.
  1. Oct 23, 2024 at 7:51 AM
    rtkman
    rtkman [OP] New Member
    South MO
    2017 TRD Pro CM 4wd, 2013 TSS CM 4wd, 2004 DC 4wd Ltd, 2002 AC 2wd SR5
    My new to me 2017 TRD Pro has 33x12.50-R18 MTs and what appears to be a 1" leveling spacer.
    I get a little rubbing with the stock bumper, which is soon to be replaced with a Go Rhino BR6 bumper and winch combo (250 lbs+-).
    Any ideas on what suspension/tires mods would be good for this situation?
    Thanks
  2. Oct 23, 2024 at 7:01 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    All up to you.
    You can go with Bilstein 5100, 6112/5160, Eibach, Icon, King, ADS - to name a few.
    Tires can range from Toyo, Nitto, General Tires, Milestar, Atturo, Mickey Thompson, etc.
    Take your pic and start researching.
    Best bet is to also figure out what you’re planning to use your vehicle for.
    RobertD likes this.
  3. Oct 23, 2024 at 7:05 PM
    RobertD
    Robert
    DFW, Texas
    This!!!!
    Start with defining your use, and then determine what you need. Otherwise you are just throwing money at something you don't know if you need. This also keeps you from regretting your buys or having to buy again.
    Tripleconpanna likes this.
  4. Oct 27, 2024 at 7:13 AM
    rtkman
    South MO
    I should have been more specific. I was wondering what front suspension mods might be needed to help with the bumper weight and to eliminate the rubbing. Thanks
