Wheel size
Discussion in 'New Member Introductions' started by Brityoda02, Oct 25, 2024.
  1. Oct 25, 2024 at 10:36 PM
    Brityoda02
    Brityoda02 [OP] New Member
    Britany
    2007 Toyota tundra crewmax limited
    4 inch lift
    I have a 2007 tundra going to put in a 4 inch lift and found some rims for good deal. The offset is 0 I’m worried they won’t fit and will be to wide. I want to find 295. IMG_4467.jpg
  2. Oct 25, 2024 at 11:43 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    @Brityoda02 Look on the forum in ‘Tundra Garage - Wheels & Tires’
    Post this there, that will get you best answer
  3. Oct 26, 2024 at 12:33 AM
    blenton
    blenton New Member
    I hate to tell you this, but if those are the actual wheels you are looking at, they ain't gonna fit. Those wheels are 6 lug; your 2007 tundra is a 5 lug... You want wheels with a 5x150mm lug spacing.
    As to 295's on a 0mm offset, from what I've seen they will typically rub in some places. You would usually need to remove some mudflats and bend some inner fender plastics with a heat gun. Might even rub on a the body mount depending on your lift, tire tread, and driving habits. I'm assuming you are after something like a 295/70R17? Which would be a tall 33" tire? If so, you shouldn't have an issue with the body mount but will prolly run in to some plastics. I can’t speak from personal experience as the biggest tire I've run is a 275/70R18 which is the same height as a 295/70r17, but on a stock wheel.
    RobertD and pvn.beluga like this.
  4. Oct 26, 2024 at 1:28 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    You can technically use those if you get a wheel adapter.
    5x150 to 6x139.7
  5. Oct 26, 2024 at 2:45 AM
  6. Oct 26, 2024 at 3:20 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    Which will push offset even more negative. 0 becomes -24, for example.
  7. Oct 26, 2024 at 7:03 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  8. Oct 26, 2024 at 8:33 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    There's so many used wheels and new even to consider adapter just cause 'it's a deal'
    Rodtheviking likes this.
