csuviper's Rock Warrior Build (VENOM) - TRADED IN
Discussion in '2nd Gen Builds (2007-2013)' started by csuviper, Jan 6, 2014.
  1. Sep 3, 2017 at 10:59 AM
    #1141
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Eclipsed & Floating likes this.
  2. Sep 3, 2017 at 2:38 PM
    #1142
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    I LOVE THOSE WHEELS!!!!
    csuviper[QUOTED][OP] likes this.
  3. Sep 3, 2017 at 3:24 PM
    #1143
    csuviper
    Broomfield, CO
    Thanks man. So do I :)
  4. Sep 3, 2017 at 10:14 PM
    #1144
    csuviper
    Broomfield, CO
    Changed over one of the fog light lenses to the wide angle ones. Can you tell which one?
    TruckyTruck likes this.
  5. Sep 4, 2017 at 8:35 AM
    #1145
    swede78
    swede78 Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    Drivers side, seems like it does not have the distance of the passenger side. I have the wide cornering/yellow, really like them and have not been flashed by other drivers.
  6. Sep 4, 2017 at 6:00 PM
    #1146
    csuviper
    Broomfield, CO
    Correct
    TruckyTruck and dcsleeper408 like this.
  7. Sep 4, 2017 at 6:43 PM
    #1147
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Truck looks GREAT Brian. Nice choice on your wheels and tires. As much as I would've stayed with the TRD RW wheels, I have no complaints with your choice :thumbsup:
  8. Sep 4, 2017 at 7:34 PM
    #1148
    swede78
    Lars
    westminster co
    Nothing yet
    Brian I think you will really like the wide cornering pattern, I drive with mine on in yellow not all the time, but haven't been flashed yet.
    csuviper[OP] likes this.
  9. Sep 7, 2017 at 3:37 PM
    #1149
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    How much lift are you running up front? Just in suspension, not including the tires...
  10. Sep 7, 2017 at 4:36 PM
    #1150
    csuviper
    Broomfield, CO
    Somewhere between 2.5-3". Probably closer to 3".
  11. Sep 8, 2017 at 7:38 AM
    #1151
    csuviper
    Broomfield, CO
    Previous Weight: RW wheels at 24lbs each and Duratracs at 61lbs each = 340lbs total
    New Weight: Icon wheels at 28lbs each and Ridge Grapplers at 75.5lbs each = 414lbs total
    Added weight: 74lbs total
  12. Sep 22, 2017 at 10:04 AM
    #1152
    csuviper
    Broomfield, CO
  13. Sep 22, 2017 at 12:50 PM
    #1153
    csuviper
    Broomfield, CO
  14. Sep 28, 2017 at 12:24 PM
    #1154
    csuviper
    Broomfield, CO
    Just ordered my black lugs from Wheelers. Went with the BLACK CHROME LUG NUTS, 14MM X 1.5, 13/16″ HEX
  15. Sep 28, 2017 at 12:25 PM
    #1155
    csuviper
    Broomfield, CO
    Sunnier and 4x4_Angel like this.
  16. Oct 4, 2017 at 7:28 AM
    #1156
    csuviper
    Broomfield, CO
    Just completed my oil change and collected the sample for blackstone lab. Hoping for good results.
    Y0TA PR0 and TRD-ROCKWARRIOR like this.
  17. Oct 4, 2017 at 7:38 AM
    #1157
    JC303
    JC303 Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    What does the blackstone lab test the oil for? I have never heard of this.
  18. Oct 4, 2017 at 7:52 AM
    #1158
    csuviper
    Broomfield, CO
    https://www.blackstone-labs.com/
    Oil analysis is a quick, nondestructive way to gauge the health of an engine by looking at what's in the oil. People use oil analysis for different reasons: to see if there are any problems developing, to see if their oil is working well in the engine, and to see if they can run longer oil changes.
    Spectral exam:
    In the spectral exam, we take a portion of your oil sample and run it through a machine called a spectrometer. The spectrometer analyzes the oil and tells us the levels of the various metals and additives that are present in the oil. This gives us a gauge of how much your engine is wearing. To learn more about the elements we look at and where they come from in your oil, go to our Report Explanation page.
    Insolubles test:
    The insolubles test measures the amount of abrasive solids that are present in the oil. The solids are formed by oil oxidation (when the oil breaks down due to the presence of oxygen, accelerated by heat) and blow-by past the rings. This test tells you how good a job the oil filter is doing, and to what extent the oil has oxidized.
    Viscosity test:
    The viscosity measures the grade, or thickness, of the oil. Whether it's supposed to be a 5W/30, 15W/40, or some other grade, we will know (within a range) what the viscosity should be. If your viscosity falls outside that range, there's probably a reason: the oil could have been overheated or contaminated with fuel, moisture, or coolant.
    Flash Point test:
    The Flash Point test measures the temperature at which vapors from the oil ignite. For any specific grade of oil, we know what temperature the oil should flash at. If it flashes at or above that level, the oil is not contaminated. If the oil flashes off lower than it should, then it's probably been contaminated with something. Fuel is the most common contaminant in oil.
  19. Oct 4, 2017 at 6:53 PM
    #1159
    csuviper
    Broomfield, CO
    Before
    After
  20. Oct 5, 2017 at 6:10 PM
    #1160
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
  21. Oct 9, 2017 at 8:37 AM
    #1161
    csuviper
    Broomfield, CO
    Rears installed. Fronts later this week
  22. Oct 9, 2017 at 8:49 AM
    #1162
    TheBeast
    TheBeast The Beach
    I see a lonely bolt ready for a TRD sway bar :)
  23. Oct 9, 2017 at 9:29 AM
    #1163
    csuviper
    Broomfield, CO
    Na, im happy with how the truck handles. Have alot of other stuff i would rather spend the money on.
  24. Oct 12, 2017 at 9:03 AM
    #1164
    csuviper
    Broomfield, CO
  25. Oct 19, 2017 at 3:26 PM
    #1165
    csuviper
    Broomfield, CO
    650h1, 4x4_Angel and MatthewPTguy like this.
  26. Oct 20, 2017 at 9:01 PM
    #1166
    csuviper
    Broomfield, CO
  27. Oct 20, 2017 at 9:46 PM
    #1167
    TheBeast
    TheBeast The Beach
    not much left from it :)
  28. Oct 25, 2017 at 12:06 PM
    #1168
    csuviper
    Broomfield, CO
  29. Oct 25, 2017 at 12:16 PM
    #1169
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    6 of 'em? Can't wait to see this project completed :spy:
  30. Oct 25, 2017 at 12:24 PM
    #1170
    csuviper
    Broomfield, CO
    Only using 2. They just made extra for me.
