  1. Oct 20, 2024 at 7:13 AM
    Refinishing some brick on the house to match the shopartment we did. It’s white mortar, not paint.
    FirstGenVol, JMB, ATV25 and 7 others like this.
  2. Oct 20, 2024 at 8:00 AM
    NWPirate
    Zach
    WA
    Nice install.
    Looks like a dedicated RV sub-panel, is that twisted feeder wire #4?
    TomC843[QUOTED] likes this.
  3. Oct 20, 2024 at 12:57 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Done. 12 and 24k Bluefin (restickered Midea) units from SupplyHouse. Whole project was just about $5k with the HRV included.
    It's been in the 70s during the day and low 30s the past couple days and these are keeping the house pretty much right at 72 in auto mode.
    Only thing I'd do differently is buy different linesets. The pre insulated ones were a bitch to route correctly.
  4. Oct 20, 2024 at 1:00 PM
    Almost all the line sets come pre insulated, and I agree they suck. The worst one I’ve done is where both lines were insulated together. I usually peel off the insulation, make the bends and cuts, and then slide it back over before final connection
    Florida AF and TaquitoBandito like this.
  5. Oct 20, 2024 at 1:12 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Yeah the 5/8 and 3/8 set were insulated together and was absolutely awful. Trying to bend the 5/8 coming out of the wall was even worse.
    We just use bulk copper at work and it's a lot easier to work with but considering I don't have a bender at home I figured this would be alright.
    It does have a fancy app though :rofl:
  6. Oct 20, 2024 at 1:17 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    It's that time of year in AZ:
  7. Oct 20, 2024 at 1:21 PM
    The out of the wall bends are always the worst, even with a bender. The spring benders are ok, but I’ll usually use the die off the bender and gently shape the pipe around the die to avoid kinks
    TaquitoBandito and T-Rex266 like this.
  8. Oct 20, 2024 at 8:11 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    https://www.amazon.com/dp/B0BMKDQ3T1
    Gone up. I ordered during Prime Days or something. Like $75 ish. Liked the write on this one for some reason. Think it was supposed to be deeper, more space for plugs while closed.
    TaquitoBandito likes this.
  9. Oct 20, 2024 at 8:21 PM
    TomC843
    Tom
    Charleston, SC
    Wondered if I would get any questions on that. Yes that's #4, I has access to some underwater cable that used to power a 3 phase 70 amp pond fountain that shit the bed at work. The outside jacket was so thick that I was didn't have a shot getting it thru the 1'1/4 hole. When I pulled the jacket off it had the cool twist.
    Florida AF and NWPirate[QUOTED] like this.
  10. Oct 20, 2024 at 8:38 PM
    TomC843
    Tom
    Charleston, SC
    Reluctantly dusted off my HVAC life at work to throw in 4 3 ton mini splits so auto mechanics had ac in the class rooms when the HVAC contractor quoted 70k in repairs. Hardest thing for this old timer to wrap his head around is BOTH lines sweat. Mini splits are weird.
  11. Oct 20, 2024 at 8:45 PM
    I need one of those in the master.
  12. Oct 20, 2024 at 8:52 PM
    NWPirate
    Zach
    WA
    Perfect! Freebies are the best.
    I just scored a couple hundred feet of #10 brown, orange, yellow and green :D
  13. Oct 20, 2024 at 8:59 PM
    TomC843
    Tom
    Charleston, SC
    Just updated the 30 amp Gen cord with donated 10/4 SO. But had to make my new 50 amp 6/4 generator cord, no pics cause non-code but perfectly safe electrical has triggered some people in the past.
  14. Oct 20, 2024 at 9:25 PM
    NWPirate
    Zach
    WA
    Copy that :thumbsup:
  15. Oct 20, 2024 at 9:59 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    And just to show the finished product got the table moved inside. 7ft diameter top barely fit through the exterior door at an angle (base unscrews and and can move separate). Excited to try this out!
    rob1208, CodyP, RobertD and 16 others like this.
  16. Oct 21, 2024 at 3:56 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    You can pick up a 9k Mr Cool unit for under $1,000 and you don't even need a vacuum pump or gauges. They've even got a 115v 20a version to make it even easier.
  17. Oct 21, 2024 at 4:44 AM
    Work of art. Well done!
  18. Oct 21, 2024 at 7:30 AM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Yeah for sure!
    The top is frigging B E A U T I F U L:hattip:
  19. Oct 21, 2024 at 8:15 AM
    shifty` You can call 1 (800) PP5-1-DooDoo
    Onto my next unemployed-life-is-fun-can't-wait-to-find-my-next-and-final-job project...
    Could use some community input from anyone who knows windows, specifically picture windows. I've installed plenty of exterior windows, but this one is new on me. Don't get me wrong, the TOH video I found was insightful, but ...
    Short story long, hitting the 21 year mark on the house. The [roughly 4'x5'] picture window in main floor bathroom popped its seal between the panes a few years ago. Need to replace it. Had a glass company out to look at just replacing the glass, they were willing, with a $1,500 price tag attached (!!!) but mentioned the stops the manuf'er used (a local mill made it) aren't something they carrry, and they won't be able to get reasonably, and when I called around, nobody else had them. Thus I figure the best course of action forward is to get a new custom sash made for half what they were asking and pop it in. The local mill that originally made it got bought up, closed up the mill, and I can no longer source anything from them, including all of our door & window trim, crown, and baseboards. Thankfully I already have a lot from other remodel projects.
    Can't measure the sash without pulling window trim, so I spent time to carefully remove it this AM. That's one thing I have very limited amount of. And that leads me to my question, where I need some knowledge/pointers...
    Questions:
    1. I'm assuming the sash is flat, and the 1¼" wide strips that are crown nailed in (see 1st pic below) are simple stops to hold the window in, is that right?
    2. If so, am I correct to assume the sash itself will be the same width as the stops, so measuring the stops edge-to-edge (W x H) will give me the size of sash I need to order?
    3. Given this window is 10ft off the ground, is it also safe to assume the window was installed from inside?
    4. If so, I assume all I really need to do here is score where the exterior trim/paint meets the outer stop, then come inside and pop off the inner stop, and push the window in from outside to remove it?
    5. Or do I jut need ot attempt removing what I think are the stops to inspect what's under it? (I can't imagine they're using anything more than simple door/window shims between the sash and window opening, 1/8" max!)
    If it helps, you may notice numbers written on the wall, 47-5/16 at the top of the opening, and 57-1/4 written on the side. The measurement of edge to edge of the sash and what I believe are its stops is roughly 2" larger, i.e. 47¼" x 57¼", +/- roughly 1/16" from top to bottom from top to bottom, which is why I'm thinking those strips are stops.
    Input appreciated. I have a window guy I can call who'll help with this, but I'd really love to tee it all up and have things ready to drop in, shim/install/stop the new window, then I can seal, re-hang all trim, and paint.
    (Apologies for the small pics, I think the forum settings were either changed to enforce smaller pics recently, or I've somehow hit a storage limit ... with all the photos I post helping other 1st gen owners on here, I wouldn't doubt if it's the latter!)
  20. Oct 21, 2024 at 8:17 AM
  21. Oct 21, 2024 at 8:27 AM
    daveeasa
    That high and that location I’d want a vertical slider w frosted lower pane and your choice on upper pane. So you can vent in warmer months. Then you get some ROI on the spend.
    Dunno about Atlanta but in San Diego on the stucco homes there are heaps of companies doing retrofits installed from the outside and fastened to the sash then foamed and trimmed on the inside.
    shifty` likes this.
  22. Oct 21, 2024 at 8:44 AM
    I've definitely thought about options to retrofit with something that opens. My only thing is, that'll likely double the cost, or even more than double b/c it's liable to be a custom build.
    We'll also want the glass acid-etched. This window was originally clear, which is stupid b/c houses in our area are built 15ft apart. My neighbor's back LR/Kitchen looks directly into this shitter, so we didn't use it for anything other than washing hands for the 1st month or two until I laid film.
    Anyway, TMI on the extra info here. More than anything, I just wanna understand what I'm up against.
    I can clearly see along the outer edge of the 1¼" wood border/framing (what I'm calling a "stop") which is stapled to the window sash.
    I see the sash is the same width as that border/framing, at least within 1/64".
    I can see at least one interior stud along the right-hand side of the window, so I'd speculate the framed window opening is ballpark 47.5 x 57.5 plus or minus 1/8".
    The absence of a visual interior "stop" is what makes me think the window was installed from inside, and I'd expect it must be stopped on the outside for safety reasons, so if anybody were to trip and fly into the window, it wouldn't pop out.
    daveeasa[QUOTED] likes this.
  23. Oct 22, 2024 at 5:38 PM
    Florida AF
    Logan
    North Florida
    So, learned something new today and did not enjoy the lesson....
    I went to build some screens for the windows missing them and decided to cheat by pulling out this screen to measure off of....
    Turns out, the windows have a lock in them that remind me of a child lock. They wont open far enough to access this little locking mechanism that caused me to damage the screen pulling it out.... fun... I said f it and built my new screen.... This kit was a lot different than what I used in the past. So not I need to figure out why the spline pops out on its own while working it in. Or why the screen wont pull tight...
    I made far less progress than planned...
    JCBerb and TaquitoBandito like this.
  24. Oct 23, 2024 at 7:03 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Chicken run fence stretching with the
    Tundra.
  25. Oct 26, 2024 at 1:51 AM
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    Finally got the outside trim done on my mud room.
  26. Oct 26, 2024 at 11:00 AM
    Florida AF
    Logan
    North Florida
    Man, I love this thread...
    Side note, about to start a bunch of small projects that I have all the things laying around for that I have been putting off. Should be good for the mental health factor as well as preparing for the cooler months. I hope everyone has a safe and fun weekend! Keep posting pics, I for one love seeing what everyone is working on!
  27. Oct 26, 2024 at 11:03 AM
    Same. It gives me ideas, and the wealth of knowledge here when I have a question.
  28. Oct 26, 2024 at 11:06 AM
    Florida AF
    Logan
    North Florida
    there are some seriously skilled people in this forum... I get both inspiration and "nope, cant do that."
  29. Oct 26, 2024 at 11:07 AM
    ahah same!
  30. Oct 26, 2024 at 11:28 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Scribing butcher block counter tops today. Makes me wish I would have paid someone to finish my drywall instead of doing it myself, but oh well, you live and you learn
