  1. Oct 25, 2024 at 8:03 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Right next to the oil filter
  2. Oct 25, 2024 at 8:03 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    :cheers:
  3. Oct 25, 2024 at 8:05 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Right next to the oil filter on the side of that mount. You've stared right at it if you do your own oil.
    Well... I'm speaking for my 2000AC.
  4. Oct 25, 2024 at 8:33 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    Had a few minutes to myself yesterday before my wife and kids got home. I have one of those frame rail spray things that attaches to a garden hose. Used it to rinse out my passenger side frame rail. Will hopefully get the driver side taken care of today. Just prepping to apply fluid film while the weather is still decent.
    G_unit3000, bmf4069, Kimosabe and 2 others like this.
  5. Oct 25, 2024 at 9:06 AM
    TnPlowboy
    TnPlowboy New Member
    2004 Tundra SR5 AC 4.7L 4WD, Tow Package: Blue Marlin Pearl
    What is this frame rail spray thingamabob that you speak of? Pics?
  6. Oct 25, 2024 at 9:51 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Just bought some 6 quarts of Toyota WS ‘gender neutral fluid’ to be politically correct. Plan on doing a drain and fill today while at work helpfully. I’m curious though on two things:
    1. I’ve just swapped out my 2nd bad radiator and I know the trans lines run through it so I’m wondering how much fluid I’ve lost to those two changes or if it’s so minuscule that it doesn’t matter. Will return fluid I don’t use cause it ain’t cheap stuff.
    2. I believe the fsm says to bring trans temp (which should be A/T oil temp #1) on my OBDlink MX+ reader) to 115F before opening check port but even on my drive to work this morning (it was cold at like 35F) the temp only got to like 106F. Would it be higher at idle and switching between Neutral and Drive I assume then?
    G_unit3000, abcinv and bmf4069 like this.
  7. Oct 25, 2024 at 10:04 AM
    1: I wouldn't worry about it if you got the hoses turned up/capped in time.
    2: just drive around the block in 1st gear around 30mph. That'll warm it up!
    Also, it's called gender fluid fluid. Gah.
  8. Oct 25, 2024 at 10:15 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I knew when buying the cheap Chinese eccentric's it was only a matter of time before they would need attention. Hit some speed bumps hard the day before the MERUS crew started showing up and slipped the two rear adjusters.
    Come to find out the rear china adjusters bottom out on themselves before adequately squeezing the LCA mounts. Torqued to spec I could still spin the adjustment cam with just a little force. Actually amazing they didn't slip any sooner.
    I now have probably 12+ hours into different alignment setups over the last few days. I started with salvaging the original setup based on my paint marks, but was unsatisfied. I knew after playing with it that the original alignment left a little under a degree of caster on the table. ITS MY CASTER AND I NEED IT NOW!
    Used this setup to pull all my numbers
    I never calculated a caster value for the final setup, but based on the previous iterations its somewhere above 2.5
    camber set at -.2
    3/32" total toe.
    Truck drives excellent, and probably the best it ever has. Before I would call it somewhat twitchy and reactive due to the lower caster. Now it's smooth, stable and damn near drives itself.
    This should keep things where I want them until I cut some alignment tabs/plates to take a standard grade 8 bolt.
  9. Oct 25, 2024 at 10:26 AM
    kentuckyMarksman
  10. Oct 25, 2024 at 10:37 AM
  11. Oct 25, 2024 at 10:39 AM
    kentuckyMarksman
    My thought was to just flush out anything that might be in the frame rails, let it dry, then shoot fluid film into the holes in the boxed frame rail sections.
    shifty`[QUOTED] likes this.
  12. Oct 25, 2024 at 11:24 AM
    Yes I do have that exact tool. If you want to borrow it, I'm happy to mail it to you. It's decent. I've only used it once and I think it leaked a little at the base, but it did blow junk out of the box portion of my frame.
    bmf4069 and FrenchToasty like this.
  13. Oct 25, 2024 at 11:28 AM
  14. Oct 25, 2024 at 11:39 AM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    Psa if you haven’t cleaned your throttle body and maf lately do it! Truck runs so much smoother mine was filthy. Also replaced sway bar bushings with OEM and the front feels a lot better no more creaky clunk.
  15. Oct 25, 2024 at 1:11 PM
    Outbound
    Aaron
    Northern Alberta
    The old '05 passed provincial inspection today, just needed a foglight bulb and licence plate bulb.
  16. Oct 25, 2024 at 1:51 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I always turn on 4hi in traffic cause it rolls too fast when I left off the brake haha
  17. Oct 25, 2024 at 2:16 PM
    Welcome back to the fray!
  18. Oct 25, 2024 at 3:12 PM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    I had to replace mine as well and tried these LEDs. I've had them in a couple months and they work great. Aliexpress has them for about half the price of AScreenshot_20241025-180741.png mazon
    abcinv and Outbound[QUOTED] like this.
  19. Oct 25, 2024 at 3:57 PM
    tbugnet15
    tbugnet15 New Member
    2001 Access Cab v8 4wd TRD Limited
    Brakes, shocks done. Bed, tailgate back on, bumper and tow hitch too. Drove it around the block for the first time. Rides nice but alignment and a windshield is up next. 5 bulbs need replaced Had to fix the seatbelt buckle and the driver door grab handle. Interior needs seat covers. Body paint will wait till spring
  20. Oct 25, 2024 at 4:10 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Who are your friends?
    whodatschrome likes this.
  21. Oct 25, 2024 at 4:34 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    These on my truck
  22. Oct 25, 2024 at 4:39 PM
    Who’s got 1-4? :monocle:
  23. Oct 25, 2024 at 4:43 PM
    tbugnet15
    Thats my kids. Left to right Jasper almost 2, Stella 9, Sawyer 5, Finn 6
  24. Oct 25, 2024 at 7:09 PM
    Auburn02
    Auburn02 New Member
    AL
    2006 DC 4.7 2WD
    Spoke too soon! I started on the passenger side the other day, which was A-ok.
    Executed the LBJ and tie rod end change this evening and discovered a small hole in the driver side. Guess I’ll hold off on the alignment and get this ordered. Honestly not sure just how bad this is. Just a simple boot replacement or potential rack issues? Seems to drive/steer just fine.
  25. Oct 25, 2024 at 7:13 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    mine was worse. I wrapped it in duct tape & zip tied it on for several months. Nbd, i just didnt want moisture getting in there.
  26. Oct 25, 2024 at 7:21 PM
    kentuckyMarksman
    Probably just a boot. My rack had holes in the bellows, had play in it, and leaking fluid... put a new one in. I think you'll be ok with bellows though.
  27. Oct 25, 2024 at 7:23 PM
    Auburn02
    Auburn02 New Member
    AL
    2006 DC 4.7 2WD
    Ha. I’ll pull the part number tonight and call the parts counter tomorrow morning to see if it’s on the shelf. Leaving the truck on stands with wheels off until I make that call, with any luck they’ll have a boot and a new inner clamp and I can grab it tomorrow.
  28. Oct 25, 2024 at 7:32 PM
    I think I need to zip tie mine back on; it’s been hanging for a month or two now open at one end. At least it’s dry from the weeping fluid drying up unlike the other one.
  29. Oct 25, 2024 at 7:36 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Adorable little pups.
  30. Oct 25, 2024 at 8:52 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Pop the needle off the oil pressure gauge and reposition. Done and done.
