Why.... why why why why.
Discussion in '3rd Gen Tundras (2022+)' started by Battousai, Oct 25, 2024.
  1. Oct 25, 2024 at 2:14 AM
    Battousai
    Battousai [OP] New Member
    OC
    2024 iforcemax tundra limited
    Ordered a borla atak delivery April 2!!
    16k miles on it, bought in March 2024...
    woods likes this.
  2. Oct 25, 2024 at 4:01 AM
    Taikowaza
    Taikowaza New Member
    So sorry to hear this OP. Does your truck fall under the engine recall? As a new ‘24 not sure that it does, you should check w/your dealer right away. So sorry this is happening, at 7 months and 16K miles it’s practically brand new. Should never happen. Toyota will make it right but may take a while. Good luck we’re all here to help.
  3. Oct 25, 2024 at 4:36 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Hopefully it is just that glitch in the matrix and they can just right fast and in a hurry reflash the Hal 2000 (computer) and send you on your way. Good luck
  4. Oct 25, 2024 at 6:23 AM
    Battousai
    OC
    And this person, same issue as me.
    "They said they will need to do a full short block rebuild. Apparently they are still waiting on some parts which they hope to have in another week, and then saying about 3 weeks to do the repair. So still hoping 1-2 months. Because mine is not on any recall list they will not do the crate motor. "
    Its on reddit... a rebuild...
  5. Oct 25, 2024 at 6:31 AM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    I am sorry to hear about this OP.
    There is a thread stickied to list your blown up motor and resolution.
    I’m so glad I dodged the V35A-FTS bullet with this 3rd Gen Tundra. What a debacle.
    CringyDad and stevesgraytundra like this.
  6. Oct 25, 2024 at 7:02 AM
    Black@Blue19
    Ken
    SE Texas
    Have they diagnosed the issue?
    Hella Krusty likes this.
  7. Oct 25, 2024 at 7:15 AM
    BlackNBlu
    BlackNBlu Cranks Nickelback in Target order pickup lane
    Rich
    MN
    I'm also sorry for OP's misfortune.
    Until he/dealer confirms it's bearing related engine failure, I'll go with the "ghost in the machine" explanation. Innocent until proven guilty? Eternal optimism? Whatever.
    Now if it IS confirmed engine failure, and if, like the other hybrid owners with engine failure, he's only getting a shortblock/rebuild instead of an entire crate motor, that is BS of the highest order on Toyota's part.
  8. Oct 25, 2024 at 7:16 AM
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    I do believe Toyota will end up recalling all motors that have that original part #
  9. Oct 25, 2024 at 7:34 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    you can get this message due to anything...what happened?
  10. Oct 25, 2024 at 7:50 AM
    Battousai
    OC
    Should I remove all my mods? put all the stock exhaust and air intakes before I take it in? Or you think you'll be all right.
  11. Oct 25, 2024 at 7:52 AM
    Zudrick
    Zudrick New Member
    2024 Tundra Lunar Rock Limited
    None….so far
    Personally I wouldn’t give them any ammo to document. Go back to stock. Dealer tried to mark my Tacoma as aftermarket because it had trd. Made them correct it
  12. Oct 25, 2024 at 8:08 AM
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    I got these same messages when I disconnected my battery jump point on my fuse block to install my Diode Dynamics light bar. After I hooked up the light bar and put the truck in drive I got all 3 messages and my heart sank. I also got the "visit the dealer for service" message. For S&G's I hooked up my very basic code reader and I had no codes and the messages went away. That was 6 months ago and I haven't seen any more warning messages.
    If you have access to a code reader I'd try that and erase all codes if even it doesn't show anything before removing all the mods you've made and scheduling service. Modern cars are so sensitive to any electrical drops or surges weird things can happen.
    LimitedLuck, bulldog93 and BlackNBlu like this.
  13. Oct 25, 2024 at 9:17 AM
    Battousai
    OC
    So apparently one of the charge pipes got loose and I just plugged it in and retightened it now all I have is a check engine light and my car goes vroooooom!!! For now..
  14. Oct 25, 2024 at 9:29 AM
    Coal Dragger
    Kung Fu Dick
    Outstanding.
    Battousai[OP] likes this.
  15. Oct 25, 2024 at 12:01 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    That's good news for sure. I hate to see the engine issue spill into 24's
    Battousai[OP] and Ausfahrt like this.
  16. Oct 25, 2024 at 12:18 PM
    Great to hear. Had me concerned for a sec.
    I like to check my boost tube clamps every 3rd oil change to see if they need to be tightened.
    Battousai[QUOTED][OP] likes this.
  17. Oct 25, 2024 at 12:27 PM
    Black@Blue19
    Ken
    SE Texas
    Easy peasy
  18. Oct 25, 2024 at 12:31 PM
    LionsFan20
    Josh
    24 Tundra
    But....but....but...it has to be a bad motor, these trucks are trash...sarcasm, I love my truck. Glad it was an easy fix
  19. Oct 26, 2024 at 12:20 AM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    Long Blocks have started arriving at dealerships
  20. Oct 26, 2024 at 11:07 AM
    Guys keep saying its fixed...its technically not ....."all I have is a check engine light"
  21. Oct 26, 2024 at 11:07 AM
    Hella Krusty
    Hella Krusty New Member
    If you undo the battery for 15 minutes it should clear all codes.....then just fire it up and see if the warnings return
  22. Oct 26, 2024 at 11:32 AM
    Battousai
    OC
    The check engine light was just a bank lean. Cleared.
  23. Oct 26, 2024 at 11:41 AM
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
    All this drama for a self-inflicted wound...
    LimitedLuck and Hella Krusty like this.
  24. Oct 26, 2024 at 12:59 PM
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    CAN-bus systems are beyond my skills with a multimeter. A little thing like a wrong gauge wire or bad joint connection can lead to gremlins.
  25. Oct 26, 2024 at 1:06 PM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    I had the same errors. My issue was the positive post in the fuse box under the hood was loose. Caused all the issues apparently. Also I’ve been told it isn’t an uncommon issue with other Toyota hybrids.
  26. Oct 26, 2024 at 2:37 PM
    Battousai
    OC
    The guy had the same exact error messages 5 days before mine on Reddit and he had to get a short engine block rebuild. that freaked me out. Same month he bought his car almost the same mileage, not covered under the recall they gave him a Camry as a loaner for approximately 2 months
  27. Oct 27, 2024 at 3:39 PM
    steveh
    steveh New Member
    '24 Tundra Limited
    Nothing Yet!
    The subject of this thread is not very descriptive. Please try to be more on point.
    hagrid and Hella Krusty like this.
  28. Oct 27, 2024 at 3:53 PM
    Outbound
    Aaron
    Northern Alberta
    Why?
  29. Oct 27, 2024 at 6:51 PM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    …made us all click
  30. Oct 28, 2024 at 4:08 AM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    oh the drama
