Replace timing belt due to age alone?
Discussion in '1st Gen Tundras (2000-2006)' started by BabyBlue, Oct 24, 2024.
  1. Oct 24, 2024 at 5:17 PM
    BabyBlue
    BabyBlue [OP] New Member
    Win
    2000 Silver Tundra AC, V8 4WD, SR5
    Stock
    Finally joined the club. With the help of the pre-purchase guide on here I just bought a well maintained 2000 4WD Access Cab. Utterly in Love. It came with the full maintenance records.
    Question:
    The timing belt was replaced at 90k miles in 2016. The truck currently only has 124k miles. Obviously the new belt is well under its 90k but it is coming up on nine years.
    Does it need to be replaced based on age alone? It looks fine to me, no cracks etc, but should I take the truck to a mechanic to take a better look?
    Thanks folks.
    BroHon and Weagle like this.
  2. Oct 24, 2024 at 5:26 PM
    Belts stretch with time. You won’t see that physically, only feel it when it’s off by a tooth.
    You could probably go longer. My belt hasn’t been changed since 2010, BUT I haven’t taken a look under there and I’m overdue. :anonymous:
    G_unit3000 and Weagle like this.
  3. Oct 24, 2024 at 5:28 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I will defer to the others however I would suggest doing it. New radiator, good flush all new pulleys water pump, serpentine belt etc. a chance to get the front end in good shape and the cooling system
    Here is mine I just replaced just shy of 100,000 miles. it was about 6 years old. I took a peek at it, and I thought it was in excellent shape even when I took it off, but I looked at it again today and there were some minor cracks in it.
    I mean it was probably still good for a while but one little peek at one little section of the timing belt does not tell the full story
  4. Oct 24, 2024 at 6:02 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Would it be fine for a while longer? Yeah, probably. My original belt lasted 200k and 23 years. Is it worth the risk? NO!
    Are you considering having a mechanic do it? Or are you considering doing it yourself?
    G_unit3000, Weagle and FrenchToasty like this.
  5. Oct 25, 2024 at 5:12 AM
    There was an excellent comment on one of the groups recently, I think for a person with a 15yo belt but under the mileage threshold. Something to the effect of: Timing belts are rubber, tires are rubber. Would you trust 9-10 year old tires under your truck before taking a long road trip? If not, why would you trust the rubber belt responsible for ensuring your engine doesn't turn into a potato?
    Edit: Actually found the comment. Man the search over there is better. "Not the miles for you. The age is the problem. If rubber on your tires cracks after 8 or 10 years, why the hell would you trust a 20 year old belt? Think about that for a sec. Belt can look visually OK after 20 years too. But rubber is rubber. It oxidizes. It loses elasticity. It cracks or tears without warning. Would you trust this truck on 20 year old tires?"
    G_unit3000 and FrenchToasty like this.
  6. Oct 25, 2024 at 5:20 PM
    BabyBlue
    Win
    Stock
    Ok thanks for the help folks.
    No I’m planning on having someone else do it.
    Anyone have any shop recs in SoCal?
    Weagle likes this.
  7. Oct 26, 2024 at 7:12 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
  8. Nov 11, 2024 at 5:10 PM
    BabyBlue
    Win
    Stock
    Ok great! Thank you all for the advice. I’ll check that guy out. Might be worth the drive down. I’m in Los Angeles.
  9. Nov 11, 2024 at 5:46 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Before I bought my 2006 DC in 2020 the previous owner had the TB (with water pump etc. ) done at the dealer with only 50K miles on it.
    So it was 14 years old at the time. As a 'buyer' this was huge piece of mind for one aspect of the truck purchase. I have limited income and didn't want the specter of a timing belt possibly grenadeing a toyota motor known for their longevity.
    I'm not saying I would or wouldn't go 'longer', but I would 'think' a belts life could be shortened in extreme weather conditions, either hot or cold.
    I'm certain there are PLENTY of folks out there who've gone well beyond the 10 year 100K mile recommendation with zero problems.
    I guess it's just a matter of how important the truck's life is to you, and how much peace of mind makes you comfortable driving & owning your truck.
    Some say F-it send it. . . . others mark their calendar when a TB change is due.
  10. Nov 11, 2024 at 5:50 PM
    :anonymous::anonymous::anonymous:
  11. Nov 11, 2024 at 7:05 PM
    Upshot Knothole likes this.
