How the blue blazes do the relays come out?
Discussion in '1st Gen Tundras (2000-2006)' started by CC80guy, Oct 23, 2024.
  1. Oct 23, 2024 at 10:13 AM
    CC80guy
    CC80guy [OP] New Member
    Larry
    Lehighton, PA
    I've got a 2001 AC 4WD and the A/C light started blinking so, of course, the first thing I check is the ground wire (ok), next are the fuses, they be fine, and next it's the relay(s). Now I have spare relays so easy peasy right (?) just pop it out and stick a new one in and see if that fixes it. How in the H-E-double LL do you get em out, these are not your ordinary looking relays!? In all my 65 years of working on every kind of vehicle on the road I have never run into a situation where you couldn't just pull a relay. Even my 01 4Runner you can just pull em so what's up with this beast?
  2. Oct 23, 2024 at 10:18 AM
    They pull out.....they are just tight as hell.
  3. Oct 23, 2024 at 10:26 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    I've only had to remove a relay once. Can't remember why.
    What I do remember is using needle nose pliers.
  4. Oct 23, 2024 at 11:57 AM
    CC80guy
    Larry
    Lehighton, PA
    Well I tried pliers and ripped the cover right of it but it's still stuck. :confused:
  5. Oct 23, 2024 at 12:21 PM
    Time to lever it with a screwdriver? I’d pull the negative battery cable, then try and get under it with a door card popper tool (trim tool, whatever)
    RobertD likes this.
  6. Oct 24, 2024 at 12:33 PM
    CC80guy
    Larry
    Lehighton, PA
    Finally got it out and this puppy has clip retainers. What doofus thought this was a good idea!?
    FiatRunner and shifty` like this.
