Tmat install, very cool product
Discussion in '3rd Gen Tundras (2022+)' started by matth66, Oct 23, 2024.
  1. Oct 23, 2024 at 4:42 PM
    matth66
    matth66 [OP] New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    What’s happening guys, i wanted to do a review of the tmat bed mat system I just installed. I’m guessing some of you like me saw it on instagram or some other social media account. It comes as 12”x12”& 1”x12” tiles that you piece (hammer) togethe to fit your bed.
    It goes together super easy and slides out just as easy. Took about 20 minutes to put together.
    the way the blockers work is pretty cool for holding cargo and tools in place
    there are even feet that you can attach to almost anything so it can lock into the tmat
    so if any of you guys are on the fence about it, it’s actually a really cool system Works as advertised. I’ll keep you posted on how well it Holds up.
  2. Oct 23, 2024 at 4:43 PM
    I like your table cloth
    Kap1, Huckwheat, OldGuy03 and 7 others like this.
  3. Oct 23, 2024 at 4:47 PM
    matth66
    matt
    Nor cal
    Sorry here’s the other pics
  4. Oct 23, 2024 at 4:48 PM
    matth66
    matt
    Nor cal
  5. Oct 23, 2024 at 4:49 PM
    matth66
    matt
    Nor cal
  6. Oct 23, 2024 at 4:55 PM
    Pretty cool system
    ScottieBones likes this.
  7. Oct 24, 2024 at 11:59 AM
    KuehnMK
    KuehnMK New Member
    2023 Tundra Crewmax 4X4 Platinum
    I like it!!
  8. Oct 24, 2024 at 1:25 PM
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    That tablecloth is where it’s at!! Thanks for posting!!!
  9. Oct 24, 2024 at 4:27 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Unfortunately, that system wouldn't work in my area. All those X shaped holes would fill with dust and be brutal to clean out. It's bad enough with just the factory bed liner.
    Hella Krusty and msubullyfan like this.
  10. Oct 24, 2024 at 4:44 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    How much would it weigh once complete? Rubber? Polyurethane? Plastic? I like the locking
    blocks to stop stuff sliding around
  11. Oct 24, 2024 at 7:41 PM
    matth66
    matt
    Nor cal
    Not heavy at all, it feels like abs plastic.
  12. Oct 24, 2024 at 7:56 PM
    Hella Krusty
    Hella Krusty New Member
    I know right!! Cool table cloth
  13. Oct 24, 2024 at 8:00 PM
    Looks cool. My only concern would be debris, like leaves, getting stuck in there all the time.
    75tranzam likes this.
  14. Oct 24, 2024 at 8:09 PM
    matth66
    matt
    Nor cal
    I was thinking the same thing , but it’s so lite I’m just gonna slide it out, lean it and hose it off
  15. Oct 25, 2024 at 7:45 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Looks pretty slick.
    Do all the sections stay together tight once assembled?
    That is, if you slide it out for hosing off, will you be reassembling sections that came apart?
  16. Oct 25, 2024 at 7:50 AM
    matth66
    matt
    Nor cal
    When I was configuring it I pulled it out and spun it over head and non of the sections came apart. For install I used a rubber mallet. They go together pretty tight
    BlackNBlu likes this.
  17. Oct 25, 2024 at 10:57 AM
    ArcticFox
    ArcticFox New Member
    California
    It's a great idea, but it starts getting costly quickly. I feel you can get a perfect commercial mat for way less money that will do 80% of the sliding prevention of what Tmat can do. Or go with horse mat and it will be very cheap.
    Does inserts also need to go in with the hammer? If so, that makes it pain in a but to adjust.
    But it is an interesting product if somebody has free money to burn.
    PS. Maybe if one would design and 3d print their own inserts it would make it more cost effective.
  18. Oct 25, 2024 at 11:24 AM
    matth66
    matt
    Nor cal
    Ok, so the other benefit over a rubber mat is it slides out for easy reach. No the attachments just plug in by hand. If you look at the pic with my hand in it , that piece is designed to be added to almost anything to make it attach to the mat.
  19. Oct 25, 2024 at 11:31 AM
    TexasCabledawg
    I wouldn’t normally be such a fan of a cobweb forward tablecloth, but they really nailed it with that one!!
    Hella Krusty[QUOTED] likes this.
  20. Oct 25, 2024 at 12:13 PM
    Breathing Borla
    AZ
    how much bed depth is that costing, hard to tell in the pic but 1.5"?
  21. Oct 25, 2024 at 1:02 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Tell us more about the table cloth.
  22. Oct 25, 2024 at 1:14 PM
    matth66
    matt
    Nor cal
    3/4”
  23. Oct 25, 2024 at 1:15 PM
    matth66
    matt
    Nor cal
    It’s an off white rectangle with gold spider webs.
    TexasCabledawg and Hella Krusty like this.
  24. Mar 7, 2025 at 10:56 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    @matth66 any feedback after several months of use. I just ordered this as I have been on the fence for awhile but my birthday is coming up and am getting it as a gift. Looks pretty slick and functional but interested in hearing anyone's real world feedback
  25. Mar 7, 2025 at 1:16 PM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield, AMP power boards
    For me that would be another big "why?". But if it works for you....
  26. Mar 7, 2025 at 1:42 PM
    shawn474
    MoCo, Maryland
    we camp a lot. I have propane tanks, tool buckets, bins, etc that I always have to bungee and secure. This seemed like a pretty easy way to get everything secured so it wouldn’t roll around and is a cool product. To each their own I suppose
  27. Mar 7, 2025 at 8:14 PM
    matth66
    matt
    Nor cal
    So far it’s been working great! I did get the jig for drilling drain holes. Other than that it has worked as advertised. Keeps my dive tanks and gear nice and secure. I use collapsible bins and use the blocks and they stay put. I would definately buy it again. Any specific questions shoot me a message.
    shawn474[QUOTED] likes this.
  28. Jun 27, 2025 at 6:38 PM
    aelarson
    aelarson New Member
    AZ
    2021 1794 Tundra (Silver Sky Metallic)
    I came across t-mat a while back in my search for trying to make the best possible bed solution. My new 2.5 gen. arrived and decided to give it shot! Sorry in advance for the long post - it's long winded.
    Here are my thoughts:
    1) Assembly was quick, went together in 15 minutes tops. A monkey could do this install.
    2) It was packaged well and showed up in a timely manner. It's US made, always glad to support US companies. They had a nice postcard of all the employees, you can tell that they care about their product!
    3) It's modular, so it'll work for most situations. You can pull it complete out if need be (its light), use the blocks to create storage space, make it however you want and plan to use it.
    4) The plastic tiles are a nice material, but they don't lock together very solid. When you pull the whole system towards the rear so you can access the items on the mat, the tiles seem to want to come apart when they go over the tailgate. I keep everything in the back of the bed, so there is no weight on the mat when it pulls out over the tailgate. They recommend plywood under the mat for rigidity, I might have to try that at a future date.
    5) It does not slide very easily. My Milwaukee boxes are about 40lbs. a piece, so I have decent weight on the mat. I might have to try the plywood with some furniture sliders on the bottom or something of that sort to mitigate this. You really have to yank on it to get it sliding. I also don't have the handles yet (shipped separate), maybe having better handles will help as well.
    6) There are male and female connections to snap everything together, but they don't make any smooth edge pieces, so there are male connections sticking out on one side (not good for the OCD/type "A" crowd like me).
    7) The blocks that hold all your accessories in place are the biggest disappointment. They feel super chintzy. They don't lock into the mat very securely, they have the tendency to pop out if try to snug up your items against the block. The adjustable blocks are much better, the solid blocks shouldn't even be an option in my mind - I would only sell this with the adjustable type.
    Overall, my first impression might sound a little harsh, but I'm not one to mince words. The product is alright, but I really hope and want to warm up to it. The concept is great, the execution feels like it fell a little short. It wouldn't take much to make it excellent (make the tiles lock together more permanently, add some slider attachments on the bottom, make the adjustable blocks in different sizes and ditch the non-adjustable blocks, and make trim pieces for smooth edges). This was $370 out the door, but it "feels" like a $175 plastic product. I certainly don't want to bash their company, I just want to provide some honest feedback, as I haven't seen many of these floating around. I think the product in current form would be great for folks who use their pickup trucks lightly (parents throwing kids sports equipment in the bed, guys who like having a truck for a truck, but don't use the bed much, etc., etc.), but may fall short for the heavy duty users (contractors, weekend warriors with heavy gear, hunters, etc.).
    This is all based on the initial install and playing around with it for 45 minutes and trying to get my gear organized. I will come back and update my thoughts after spending some real time with it. Hunting season is coming up, and that always test my gear to limit. We'll see how it holds up and functions in the field!
    shawn474 likes this.
  29. Jun 27, 2025 at 6:46 PM
    TFTJ
    TFTJ New Member
    Sorta want
    aelarson likes this.
  30. Jun 27, 2025 at 9:01 PM
    MAC25Tundra
    MAC25Tundra New Member
    2025 Limited Crew Max 4x4
    Appreciate the thorough and honest feedback. Please update again as you use them further.
    aelarson[QUOTED] likes this.
