Question for those with ESP underseat storage CrewMax
Discussion in '2.5 Gen Tundras (2014-2021)' started by Shadowfax1, Oct 18, 2024.
  1. Oct 18, 2024 at 8:31 PM
    Shadowfax1
    Shadowfax1 [OP] New Member
    San Francisco Bay Area
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
    I’m leaning towards the three-bin plastic version. Partially because of the huge price difference from the metal but largely because it’s a full 4-4.5” deep; the metal is only 3-5/8.
    A few questions.
    I understand there’s no road noise with these. But what about noise from items moving around in the bins? Do you find they slide around and make noise over bumps or when driving?
    As long as I’m cutting the carpet and the styrofoam under it to install this (yeah, that’s not at all terrifying…), is it at all worthwhile to insert any sound deadening material under there? I mean after all, the whole point of Toyota including that styrofoam is as a sound barrier…and we’re literally removing four inch deep sections of it.
  2. Oct 18, 2024 at 9:14 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    There is a piece of carpet padding that gets cut and works well below the bin. Seems like that is in the instructions? Like you, I was concerned about increased road noise, but I did not notice any. The back seat bottom seems to insulate that pretty well.
  3. Oct 19, 2024 at 1:55 AM
    NyCSnEaK
    NyCSnEaK New Member
    Yaq
    Tundra AG CM TRD
    smokint, bulldog93 and Shadowfax1[OP] like this.
  4. Oct 20, 2024 at 6:05 AM
    Glockman2018
    Glockman2018 New Member
    I didn't notice any more noise when I installed mine.
    Shadowfax1[OP] likes this.
  5. Oct 20, 2024 at 6:11 AM
    PermaFrostTRD
    Northern NY
    No noticeable noise difference for me either. I think I put the carpet under it because it’s in the instructions but I don’t remember
  6. Oct 20, 2024 at 8:12 AM
    JrJrOffroad
    JrJrOffroad Somewhere in the west
    Anthony
    Monument, CO // Cave Creek, AZ
    +1 for no noise. I do have the entire cab floor lined with Kilmat so that may attribute to my case but sounds like others saw no noise.
    easily the best mod ever.
  7. Oct 20, 2024 at 8:23 AM
    centex
    centex New Member
    No noise here.
  8. Oct 20, 2024 at 8:41 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    No noise; use the piece of carpet that you cut out to put on the cab floor and the bin goes on top of that. Insulates and prevents any rattles.
  9. Oct 21, 2024 at 12:00 PM
    smokint
    smokint New Member
    2017 1794 2002 Tacoma
    I love mine, should’ve come with it from the factory!
  10. Oct 21, 2024 at 12:03 PM
    smokint
    smokint New Member
    It doesn’t make any noise. The only downside for me, is that I always bring way too much stuff when heading into backcountry, and you can’t lift that seat to get down there when the seat is covered in a bunch of junk
  11. Oct 21, 2024 at 12:06 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    These storage systems designed by ESP @havasubud are the best.
    SAGE63 and Shadowfax1[OP] like this.
  12. Oct 22, 2024 at 12:25 PM
    GoJo
    GoJo New Member
    UTAH
    2019 Tundra SR5 CM Silver Sky
    Same as the rest, no noticeable road noise difference. I also don't notice anything sliding around in the bins either, but I lined them with the cut out carpet during the install, so helps to keep things in place, that and the bottom of the seat sitting right down on the top of everything helps keep things in place too.
