loud tapping when trying to start after fixing hole in fuel tank
Discussion in '1st Gen Tundras (2000-2006)' started by cynophile, Oct 20, 2024.
  1. Oct 20, 2024 at 11:16 AM
    cynophile
    cynophile [OP] New Member
    Mark
    2006 SR5 DC TRD
    Someone decided to drill a hole in my truck's gas tank, presumably to steal gas, about two and a half weeks ago. After a lot of research I decided to use a Tech-Bond patch to repair it and it's now (hopefully) fixed.
    Anyway, I filled the tank with 3 gallons of gas, and when I tried to start it today I heard a very loud tapping. I assumed it would take a bit to prime the system since it had been dry this whole time, but the loudness of the tapping sound, which seemed to be coming from under the hood, definitely surprised me.
    Is this normal and just a case of cranking until the system is primed, or possibly a sign of a larger concern? Thanks.
  2. Oct 20, 2024 at 11:22 AM
    This is one of those times where hearing the noise would help tremendously. I think many of us with the V8/4.7 have a tapping sound under the hood when running. Almost like a sewing machine.
    ATBAV8 likes this.
  3. Oct 20, 2024 at 1:29 PM
    bfunke
    bfunke Tundra Curmudgeon
    Did they also try to get your cats? Check for exhaust leaks
  4. Oct 20, 2024 at 1:31 PM
    Mine did the same after changing injectors
  5. Oct 20, 2024 at 4:43 PM
    cynophile
    Mark
    2006 SR5 DC TRD
    Okay, turns out I'm a dumbass - the battery was just a little low. Thanks for the view/replies, and apologies for the false alarm.
    shifty` likes this.
