Tech12volt / Hertz door speaker install
Discussion in 'Audio & Video' started by BlueBottle, Mar 2, 2019.
  1. Jan 15, 2022 at 8:37 AM
    #121
    Pishta2020
    Pishta2020 New Member
    Hertz tweeter install? Do I need to modify sail panel? I have non JBL and I just can't figure it out. Thanks guys!!
  2. Jan 15, 2022 at 8:46 AM
    #122
    jaflynn738
    jaflynn738 New Member
    Virginia
    yes, I ended up cutting holes in my panels so the tweeters could sit in it. I used a socket to trace the circle and used dremel tool to make the holes. I hope this helps.
  3. Dec 13, 2022 at 9:42 AM
    #123
    zasdds
    zasdds New Member
    2021 Platinum Crewmax
    I reached out to James, but he has not responded yet...
    I installed the front door hertz speakers/tweeters this weekend but am having some issues. Rear door speakers are still stock because I ran out of time. Here is the rest of my set-up on a 2021 Tundra Platinum with JBL all from tech12volt:
    - JBL Amp Replacement
    - JBL sub replacement
    - audiofrog dash speakers x3
    When I turn the volume above 36 on stock headunit, sound pops in and out, almost like some sort of safety limiter. Did I do something wrong? Do amp settings need to change? Don’t think any wires are loose/pinched. Any suggestions?
  4. Jul 9, 2023 at 7:24 AM
    #124
    Riskyguy
    Riskyguy New Member
    Stewart
    2018 Tundra SR5 Crewcab
    The easiest way is to mount them from the back of the tweeter, not the front. I used a little dish soap to lube the ring. It went on in about 10 seconds.
  5. Jul 9, 2023 at 7:26 AM
    #125
    Riskyguy
    Riskyguy New Member
    Stewart
    Mount the ring from the back of the tweeter. Use a little dish soap as a lubricant and it will go on easily.
  6. Jul 9, 2023 at 7:35 AM
    #126
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I put the ring on the panel first then pushed the tweeter into it. Snug fit but that's what ya want.
  7. Mar 8, 2024 at 3:00 PM
    #127
    Jeff Spicoli
    Jeff Spicoli New Member
    2019 Platinum
    Dual Magnaflow exhaust, Bakflip MX4, Taylor's Audio amp, speakers and subwoofer for Tundra JBL.
    Thanks for the great info! I’m doing this same install Sunday.
  8. Jun 23, 2024 at 8:16 PM
    #128
    2015TundraRoy
    2015TundraRoy New Member
    2015 Tundra CM SR5
    I'm confused on what I am supposed to do with the y-adapters concerning the amp and the loc. Amp is JL RD9005. LOC is simple 4 channel.
  9. Oct 19, 2024 at 11:39 PM
    #129
    tja1080
    tja1080 New Member
    TJ
    Whidbey Island WA
    2016 Platinum
    Has anyone replaced the hertz rear component speakers out with a 2-way speaker and had issues with them working afterwards? I recently installed kicker 6 3/4 and after I wired the drivers side, I tested and it worked. Installed passenger side and now neither of the rear speakers work.
  10. Oct 20, 2024 at 12:11 AM
    #130
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    You sure you didn’t blow a fuse? Double check the connections and make sure they’re tight.
  11. Oct 20, 2024 at 6:55 AM
    #131
    tja1080
    tja1080 New Member
    TJ
    Whidbey Island WA
    2016 Platinum
    which fuse? Front speakers and sub still work
  12. Oct 20, 2024 at 1:14 PM
    #132
    tja1080
    tja1080 New Member
    TJ
    Whidbey Island WA
    2016 Platinum
    Fixed it by removing the harness with the inline crossover and reinstalling the factory tweeter connector.
    TXTundra2722 likes this.
