2018 CM 4wd Trans fluid change?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Baja1000, Oct 7, 2024.
  1. Oct 7, 2024 at 9:30 AM
    Baja1000
    Baja1000 [OP] New Member
    Andy
    SOCAL
    2018 TRD 4X4 Cement CM
    At what mileage are you guys flushing and changing the trans fluid?
    Thank you
  2. Oct 7, 2024 at 9:53 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 1997 FZJ80, 2003 Tacoma SR5 V6 5Spd
    Drain and fill every 30k. Don't bother with a flush
  3. Oct 7, 2024 at 12:35 PM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
  4. Oct 7, 2024 at 12:41 PM
    grant.ducckk
    grant.ducckk New Member
    Grant
    2019 DC Cavalry Blue Limited 4x4
    I did a flush because I bought mine at 100k miles and wasn't sure when/if the previous owner ever did drain-and-fills. I will be doing drain-and-fills from now on, though.
    Baja1000[OP] likes this.
  5. Oct 11, 2024 at 9:07 AM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
  6. Oct 11, 2024 at 9:21 AM
    d33pt
    d33pt New Member
    What fluid is everyone using?
  7. Oct 11, 2024 at 9:22 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    Toyota ATF WS
    Noob here and AZBoatHauler like this.
  8. Oct 11, 2024 at 9:27 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Whatever has the most signatures on the bottle.
  9. Oct 11, 2024 at 10:47 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    I bought my '18 at 23k miles last November. I'm just about to hit 35k miles on it.
    I'll probably start looking into doing a drain n fill on my transmission soon. Gotta start collecting the items needed.
    What does the "flush" consist of vs. drain n fill?
  10. Oct 11, 2024 at 11:56 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    Flush would remove all or nearly all of the fluid and involve a machine that you won't have in your garage.
    Simply drain the pan, and refill what comes out, or there's a common practice of adding about an extra half quart over what drained out and then doing a fluid level check procedure outlined in this video:
    https://youtu.be/NUAuGmDGntY?si=MNxm2Fp9O2jQtgeQ
    I'd suggest just sticking with the drain and fill method and doing so approximately every 30k miles or so
  11. Oct 11, 2024 at 6:29 PM
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    What ever WS compatible synthetic is on sale.
    texasrho83 likes this.
  12. Oct 11, 2024 at 7:25 PM
    blenton
    blenton New Member
    30k miles and WS ATF - either Toyota or Aisin, but mostly Toyota WS straight from the dealership. At 212k miles, it's still holding up great with lots of towing and hauling. I did an ATF oil analysis with Blackstone Labs last year and they suggested I move up to about 24k mile intervals, with an extra changes with every engine oil change over the next year. As noted, I do a lot of towing and hauling so I have no qualms with the recommendation for additional drain and fills at this mileage.
  13. Oct 20, 2024 at 8:24 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The only signature I look for on everything from oil to ketchup.
    blenton and Red&03Taco like this.
