Sig Sauer X-RAY3 Enhanced Visibility 3-Dot Tritium Square Notch Day/Night Sight
Discussion in 'Marketplace - Other' started by Musicmasterd12, Oct 20, 2024.
Thread Status:
Not open for further replies.
  1. Oct 20, 2024 at 5:07 AM
    Musicmasterd12
    Musicmasterd12 [OP] New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    Just picked up a used P220. Ordered these sights to replace the dead tritium sights on the gun. Turns out this model is a dark elite which has a different dovetail cut and these sights won’t work. They’re brand new in box, my loss is your gain.
    $85 shipped
    High-Contrast Green #6 Front Sight & Blacked-Out #8 Rear Sight, Compatible Pistols
    RainMan_PNW, Jeff_1974 and j-utah like this.
  2. Oct 20, 2024 at 5:19 AM
    Damie Street
    Damie Street New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    Will Amazon not take it back? I'm curious why you just don't return it and get your money back?
  3. Oct 20, 2024 at 5:22 AM
    Musicmasterd12
    Southern Louisiana
    Bc they have tritium they don’t accept returns for them
    1lowlife, Damie Street and bulldog93 like this.
  4. Jan 8, 2025 at 2:15 AM
    beeowengee
    beeowengee New Member
    Bobby
    QUEENS NYC
    2019 tundra TRD
    Just LEDS for now
    what compatible pistols will it fit on ?
  5. Jan 11, 2025 at 1:42 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    MOST Sig P-series use the same standard front and rear dovetails (except for a few specific releases, as OP found out with the Dark Elite).
    As a “standard” Sig used the #6 front/#8 rear combination (which this set is) for the 40SW and 45ACP pistols - most P220, P226, P229, and P320 chambered in these two calibers used this combination (while 9mm and 357SIG used 8F/8R).
    It has also been found that a lot of the shorter 3.1” barrel P365 pistols in 9mm also used this 6F/8R sight combination.
    If swapping sights on an existing Sig - if it currently hits where you want it but you’re just looking for new or upgraded sights - you should use a good magnifying glass and check the sights in your pistol. The sight number will usually by stamped very small on the horizontal flat of the dovetail piece on the front sight, and on the side or top of the rear sight. Confirm the numbers and order accordingly.
    OP - you can call Sig customer service and arrange to send that slide in to be serviced and have the sights upgraded since the original sights are no longer available. It will cost a little bit more than just the sights, but they’ll usually strip and clean and replace other parts (springs, pins) as part of the service.
    Edit:
    Found a more recent chart of common sight numbers for various Sig pistols with based on model and caliber. It isn’t gospel, but it’s what is most commonly seen.
    blenton likes this.
  6. Jan 11, 2025 at 2:27 PM
    Musicmasterd12
    Southern Louisiana
    Thanks. I did call them and they told me they didn’t offer sights for that model anymore. They directed me to Dawson Precision who sells a set of fiber optic sights for the Dark Elite model, so that’s what I ended up purchasing.
    These are now sold.
    thanks for the interest/help gents!
Thread Status:
