  1. Oct 14, 2024 at 9:33 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I replaced the steering rack on thee ol goat. Steers like a champ again :D:burnrubber:
    Although it’s less for burnies and more for plowies
    MTRock, dondino, Stainlesst and 3 others like this.
  2. Oct 14, 2024 at 9:54 PM
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    Any suggestions for clear coat damage? Roof of my 2012. No issues elsewhere and first body shop quote was $1900 :eek:
    dondino, Mountun Goat and Wynnded like this.
  3. Oct 15, 2024 at 5:35 AM
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    Same issue on my ‘08. Wrap it was the best choice I found, don't like any shops locally monkeying around with the headliner and 3rd brake light, not to mention the quality of work doesn’t meet the price charged.
    Wynnded and OldGuy03 like this.
  4. Oct 15, 2024 at 6:10 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    My roof is experiencing the same issues, although not quite as extensive as your is at the point. I also plan on wrapping mine eventually.
  5. Oct 15, 2024 at 6:19 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    My roof and hood look like this. Wrapping is what I'm going to look at, some day.
  6. Oct 15, 2024 at 7:10 AM
    Bigblueintahoe
    Bigblueintahoe New Member
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    My roof is starting to do this too. I was also going to run down to the vinyl wrap shop nearby and get a quote
    ACDC2ZZTop[QUOTED] likes this.
  7. Oct 15, 2024 at 7:11 AM
    Bigblueintahoe
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    Did you get a quote for the vinyl?
  8. Oct 15, 2024 at 7:46 AM
    rphass17
    rphass17 New Member
  9. Oct 15, 2024 at 7:57 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Have you thought to paint it yourself? It's not that hard. Lots of quality 2 part paints and clear. I did my bed sides. Eastwood 2k or spray max 2k.
    D4x4TRD, Medicineman, Deaner and 4 others like this.
  10. Oct 15, 2024 at 9:55 AM
    Tundra1D6
    I found a guy in south Louisiana that’s at 400 for just the roof of a crewmax. Haven’t seen any of his work nor do I know the type of material he will use.
    If I had the same job done in Houston it’s likely half the price for a better quality material.
  11. Oct 15, 2024 at 10:02 AM
    Bigblueintahoe
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    At least that gives a general ballpark. That’s not a bad price if it’s somewhere in that range. I wish my paint imperfections were contained to just the roof. My upper pillars have some clear damage as well
  12. Oct 15, 2024 at 4:57 PM
    Bigblueintahoe
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    Installed new wheels and tires today. Modco 17s
  13. Oct 15, 2024 at 4:59 PM
    ACDC2ZZTop
    Travis
    Oregon
    I have watched several YouTube videos for sanding and applying clearcoat. Still debating that vs. line-x and other options.
  14. Oct 15, 2024 at 6:44 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I had some paint peel on my hood. Patched it with some paint and clear. I didn't blend sand and is ok from 8ft. Haha
    Been thinking of black hood/roof once I install functional louver vents on the front of the hood.
  15. Oct 15, 2024 at 7:05 PM
    Deaner
    Deaner New Member
    Dean
    The Mac
    2010 Rock Warrior
    Did you have any directions to follow?
    Mdl[QUOTED] likes this.
  16. Oct 15, 2024 at 7:13 PM
    Bigblueintahoe
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    That actually looks pretty good. I might follow that template minus the hood
  17. Oct 15, 2024 at 7:55 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Not really. Just youtube videos. The best results come from good prep and sanding.
    Cruiserpilot and Deaner[QUOTED] like this.
  18. Oct 15, 2024 at 9:39 PM
    Bigblueintahoe
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
  19. Oct 16, 2024 at 6:13 AM
    rphass17
    rphass17 New Member
    For less than $150 you could wrap your entire roof? Not sure the dimensions on the roof but its gotta be less than 5'x7'.
    ACDC2ZZTop[QUOTED] and Mdl like this.
  20. Oct 16, 2024 at 6:48 AM
    Bigblueintahoe
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    Yeah that’s not bad at all!
  21. Oct 16, 2024 at 5:58 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    All I've done is drive mine home and when pulling into the driveway noticed a flashing 4Lo
    Into the house for the scanner and I've got P0705 & C1247. Small amount of reading & I found to check some fuses under the dash. All those are good. Further research & t/shooting necessary..
  22. Oct 16, 2024 at 7:48 PM
    MattFromPNW
    MattFromPNW New Member
    2010 Tundra
    Rotors and pads done today.. happy birthday to me
    OldGuy03, Mdl and ACDC2ZZTop like this.
  23. Oct 16, 2024 at 7:56 PM
    ACDC2ZZTop
    Travis
    Oregon
    That’s on my to do list.
    OldGuy03 likes this.
  24. Oct 18, 2024 at 3:20 PM
    Hilandr
    Hilandr New Member
    2011 Tundra SR5
    It's not perfect, but I peeled the bubbling chrome from the grille surround and painted it. And yes, I like the old man eyebrow :D
  25. Oct 19, 2024 at 7:46 AM
    Bigblueintahoe
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    That looks great!
    Hilandr[QUOTED] likes this.
  26. Oct 19, 2024 at 5:43 PM
    82nd Airborne
    82nd Airborne New Member
    2012 SR5 DC
    2012 Bed floor rust repair. Bed off. Still in progress. Using JB weld seamweld and rivets.
  27. Oct 19, 2024 at 5:58 PM
    82nd Airborne
    2012 SR5 DC
  28. Oct 19, 2024 at 6:03 PM
    82nd Airborne
    2012 SR5 DC
    Front corners cut out. Patches made but not riveted in yet
  29. Oct 19, 2024 at 6:21 PM
    Bigblueintahoe
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    Installed OEM style skid plate and led fog lights
  30. Oct 20, 2024 at 3:45 PM
    tahoe
    tahoe New Member
    2013 RW, 6112 @1.9” front, 5100 rear
    I ordered a new wiper linkage. Hopefully it won’t be too painful to replace. It wasn’t fun driving home 2 hours in a rainstorm with 1 wiper working half way.
