Grease for Polyurethane Bushings
Discussion in 'Suspension' started by Cruiserpilot, Oct 19, 2024.
  1. Oct 19, 2024 at 11:39 AM
    Cruiserpilot
    Cruiserpilot [OP] New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Got into a discussion with a guy. Reads that new poly bushings should use a lithium grease.
    I've always used the red'n tacky Lucas stuff. It hardens over time, kinda ugly. The bushings do too and crumble. So curious if anyone is technical know of which grease is best?
  2. Oct 19, 2024 at 11:49 AM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Prothane Super Grease is what Dirt King told me to use on their poly bushings.
    In the past, I used SuperLube. The super grease is thicker and seems to last better than superlube.
    Cruiserpilot[OP] likes this.
  3. Oct 19, 2024 at 12:07 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Prothane's Super Grease is a silicone based grease with a PTFE additive which means it's water-proof, reduces friction, and sticks to polyurethane bushings. Prothane's Super Grease was designed specifically for their bushings, to prevent the polyurethane from squeaking.
    So silicone base. I might not be able to get that brand specifically at home. I'll see what we have.
