  1. Oct 17, 2024 at 7:26 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
  2. Oct 17, 2024 at 7:34 AM
    Arebt they like $80 a piece though
  3. Oct 17, 2024 at 7:34 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    UGH. Thanks for the heads up. The solo stuff is nice, but way overkill for my needs.
    An oem shaft with a 930 joint would be tits.
    Plenty of boot options, but no joints!
    THIS KIT from All Pro Offroad is probably sufficient for my needs.
  4. Oct 17, 2024 at 7:39 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Maybe. I had a set I scored used but ended up playing em forward
  5. Oct 17, 2024 at 7:43 AM
    I am appalled at your statement, sir. You have not been drinking a true Kona blend to make that remark! (Too many cheaply made overpriced imitations floating around to get confused about) Jamaica Blue Mountain is good though.
  6. Oct 17, 2024 at 7:43 AM
    des2mtn
    SW
    Tonto cover
    455h0le_dachshund and shifty` like this.
  7. Oct 17, 2024 at 7:51 AM
    I was talking about aftermarket Moogs now and other aftermarket makers.
  8. Oct 17, 2024 at 7:56 AM
    Gorilla duct tape should fix that. Maybe. Probably. Oh, hell I don’t know. :rofl:
  9. Oct 17, 2024 at 12:00 PM
    Think I’m going with the aftermarket $20 Moog inner tie rods. OEM @ $178/each with 25% off isn’t even close and it makes more sense to just buy a new steering rack while I’m at it. Just hope they last at least a few years at such a low price.
  10. Oct 17, 2024 at 12:08 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    *Looks at parts pile, with parts sitting well over a year*
    Preach brother.
  11. Oct 18, 2024 at 7:12 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
  12. Oct 18, 2024 at 10:03 AM
    Someone else posted up a person doing the rears recently and they used a similar trick. I’ve see a lot of shit in my time, as I know you have. I had never seen anyone do that before.
    BroHon[QUOTED] likes this.
  13. Oct 18, 2024 at 11:45 AM
    I've been looking at various front bumper options and have come across some laughable stuff. Here's a ridiculous photo shop fail
  14. Oct 18, 2024 at 12:03 PM
    Anyone here know if I can potentially damage my steering rack by taking a cheater pipe to an oversized adjustable wrench to get the outer tie rod nut off?
    I’m not sure how sturdy the rack is if I’m twisting against it with the inner tie rod turning 1/8-1/4 turn in an attempt to break that nut free. Those alignment bastards always crank it on too hard.
    I know I won’t be able to hold the outer tie rod in place with another wrench if I try to use a cheater. I figured the outer tie rod joint should stop me by 1/4 turn at the expense of that tie rod which I’m replacing.
    I’d like to at least give it a shot before I just unscrew the inner and outer tie rod together.
    Suggestions? Yay or nay? :monocle:
  15. Oct 18, 2024 at 12:19 PM
    TnPlowboy
    TnPlowboy New Member
    2004 Tundra SR5 AC 4.7L 4WD, Tow Package: Blue Marlin Pearl
    There's a flat on the OEM OTR and also the ITR to keep it from twisting the rack. I've got the measurements somewhere...
    whodatschrome and Jack McCarthy like this.
  16. Oct 18, 2024 at 12:38 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Jam nut? It'll be fine.
  17. Oct 18, 2024 at 12:44 PM
    Oh, yeah I forgot about that. Got to pull back the boot and take a look. Hopefully it’s accessible with the boot still on it and pushed to the side.
  18. Oct 18, 2024 at 12:45 PM
    I take it you’ve dealt with that on our Tundras before?
  19. Oct 18, 2024 at 12:46 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    I used a big pipe wrench and a cheater pipe. My rack doesn’t leak more than it did before, so I’m thinking it’s fine.
  20. Oct 18, 2024 at 2:14 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
  21. Oct 18, 2024 at 2:57 PM
    Dakillacore
    Georgia
    Those big brush guards are great for smaller impacts, but a large hit transfers all of the kinetic energy straight to the frame. I have seen a few trucks that ended up totalling out because of this. The vehicle is designed to absorb energy and move it around certain crush zones while brush guards circumvent the crush zones by bolting directly to the frame, in most cases. This can also end up causing injuries in the event of an accident. The law of unintended consequences.
    shifty` likes this.
  22. Oct 18, 2024 at 3:15 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Yep and many others.
    Most of the torque is a twisting motion, the inners twist freely in their ball socket. The remaining load isn't enough to harm the inners, at least that I've found.
  23. Oct 18, 2024 at 4:15 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Well work shituation got the best of me. Merus staff left at 5:30 so not able to hit the road and join the tx boys tonight. Not sure if it’s worth having to come back on Sunday early in the morning. 5.5 hours each way without stops.
  24. Oct 18, 2024 at 4:44 PM
    Boooooo
  25. Oct 18, 2024 at 4:59 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Jobs get in the way of so much fun...
    Bummer :facepalm:
  26. Oct 18, 2024 at 6:51 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Supplier delivered wrong material at 10am. Correct ones weren’t on site until 3ish. I had 11 guys and they would have finished before 3 if the supplier didn’t goof it up.
  27. Oct 18, 2024 at 7:19 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I swear the incompetence level out there now (people in jobs they have no right to be in) is insane.
    If you don't hold their effin hands through everything.. and know MORE than them about about details of a product or process.... shit gets sideways.
    I think a HUGE brain drain happened when a ton of older (Knowledgeable/experienced) people who could retire, but were still working, just pumped and dumped out of the workforce because of covid.
  28. Oct 18, 2024 at 8:12 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Hey man bare minimum still collects a paycheck. lol
    shifty` likes this.
  29. Oct 19, 2024 at 5:46 AM
    Sadly there isn’t a lot of option these days. Opting for a warm seat versus an empty one. Even if they piss off the other staff and all your customers with their incompetence.
    And that’s not to blame the incompetent. This is a failure of their parents and senior staff (now retiring) failing to do the “Three Ts”: teach, train, transfer.
    Older folks find it funny as hell to joke about how tour average employee “doesn’t want to work”. Sad truth is, wages are shit and completely divorced from the value of the dollar as it was when I was in high school 30-40 years ago, it hasn’t tracked with inflation in decades to the point a minimum wage job can’t afford you a minimum sized apartment and minimal amount of food to eat, much less a car and gas + insurance for it unless you find 2-3 trustworthy people and cohabitate. Someone show me the motivation for Gen Y and beyond to do beyond the bare minimum…
    You’ll start seeing the impacts soon, as Gen Y and all to follow won’t have children, birth rates will drop, and along with the loss of knowledge you’ll see a loss of citizens to go with it. You know what sucks about that more than the domestic population decline? A rise in selfishness that goes along with fewer parents. Childbearing is a humbling experience, and if you can’t manage to adapt and become more selfless, it typically goes to shit, your kids either detach or end up f’ed up. Last thing we need is more selfishness on the planet. Quite the opposite, actually. Would be massive changes in no time flat if more people actually gave a shit about their fellow human. But that’s not where the most vocal on the planet are trying to steer us right now.
    808basswolf, Dakillacore and Festerw like this.
  30. Oct 19, 2024 at 6:36 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    literally happening as I type this
