2004 crew cab 4.7 V8 electric fan recs?
Discussion in '1st Gen Tundras (2000-2006)' started by janderscu, Oct 17, 2024.
  1. Oct 17, 2024 at 6:02 PM
    janderscu
    janderscu [OP] New Member
    Just had my fan clutch go out and before replacing with OEM, is there a comparable quality cheaper after market? or recommendations for an electric upgrade?
    Thanks,
  2. Oct 17, 2024 at 7:07 PM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    There's really no substitute for OEM. Buy once, cry once.
    janderscu[QUOTED][OP] likes this.
  3. Oct 17, 2024 at 7:15 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Nope. Oem
  4. Oct 17, 2024 at 7:28 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Aisin Brand makes a lot of the OEM cooling parts for the 1st gen
    check rockauto for your correct part number
  5. Oct 18, 2024 at 1:14 AM
    I would love to run electric personally. Would free up some power, and remove another major source of noise which would be welcome. I’ve seen people on here use setups I think @FrenchToasty is one of them?
    Anyway, I usually went with Permacool or Flex-A-Lite setups for LS/LM/LQ swaps. They probably still have a system that lets you zip-tie through the fins for install. I usually bought or built or repurposed a shroud, sometimes if the inlets and outlets are right on the donor vehicle, you can simplify modify shroud from any other vehicle and use its fan.
    But yeah. If you decide to go electric, it needs to be high CFM (3k+) fan and you should probably double up, you will want to exceed the OEM mechanical fan’s air volume by at least 50% if not double it IMHO. If you replace the assembly, stick with OEM part as advised already. And be ready to fight some of the bolts, or if in the rust belt, be prepared to hack some off … start penetrant sooner than later.
    janderscu[OP] likes this.
  6. Oct 18, 2024 at 4:10 AM
    bfunke
    bfunke Tundra Curmudgeon
    AISIN from Rock Auto.
    janderscu[OP] and jerryallday like this.
  7. Oct 18, 2024 at 4:16 AM
    Danman34
    Danman34 New Member
    Danny
    Electric fans are noisier than our mechanical. Especially if you want a high cfm fan. That completely negates a quiet fan. You would also need to figure out how to wire the fans to communicate with the coolant temp sensor to know when the thermostat is open, as well as kick into high when you turn the ac on, and go from low to high based on engine speed and temperature when unloaded and loaded. It’s not just plug and play when the vehicle isn’t designed for it. I’ve had more issues on vehicles with electronic fans than mechanical. Plus, it’s not going to free up as much power as you think it will.
  8. Oct 18, 2024 at 5:31 AM
  9. Oct 18, 2024 at 8:53 AM
    janderscu
    Thanks for the feedback. Going with the Asin clutch. Is it worth or good idea to do the bracket also? The shop I took it to that diagnosed the issue wants to do the clutch and bracket, but I think the noise, issue is more in the clutch itself .... the clicking noise comes and goes. Seems like the bracket problem would be consistent. I want to do this myself and save the cost on labor. But swapping the bracket is a bit more involved to remove some stuff out of the way. is it recommended to do both together?
  10. Oct 18, 2024 at 9:50 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    If you got the room in the engine bay
    Clutch fans > electric fans
    for simplicity and efficiency.
  11. Oct 18, 2024 at 10:01 AM
    if I recall, the bracket has a bearing. If true, yes, do the bracket also. Someone else recently did this, and the wobble they were having was from the bracket itself, I’m quite certain.
  12. Oct 18, 2024 at 3:43 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I originally installed electric fans on my jeep CJ7 (that i swapped in a GM Ramjet 350 crate engine). I hated everything about electric fans. The noise was #1. The poor cooling was also #1. The extra amp load on the alternator was #2. After i swapped to a mechanical fan and clutch (and a somehow perfectly fitting fan shroud that was out of a mid-80’s ford ranger 4.0 v6), i did notice quite a bit of performance loss. The engine didn’t have the same quick snap that it did prior. That being said, i still wouldn’t go back to electric fans…ever.
  13. Oct 18, 2024 at 5:50 PM
    janderscu
    yes, actually after looking at it more, there is wobble and noise even when the clutch is not engaged, so seems to be the bracket bearing. once it warms up and the clutch engages and loads the bracket bearing more, it gets worse. going to do the bracket and then see what I got since the clutch is much easier to remove and replace later if I need to.
    shifty`[QUOTED] likes this.
  14. Oct 18, 2024 at 5:58 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Ford Taurus (like mid 90s?) electric fans absolutely slap. They're like $90 on rock auto and include the whole fan shroud and pump a ton of air, they also have two speeds. Just to throw out there as food for thought. They draw a lot of juice, 30+ amps, but are really good and really cheap. Pretty common in the off-road/custom vehicle world. I have 3x of them spread across various setups.
    For wiring you can get a temperature switch, but you would have to add the sensor in somewhere (not a huge deal). Electric fans are very doable, cheap, and you shouldn't overheat if done right. With that said, just replacing the clutch is a lot simpler and probably more reliable.
    Mdl likes this.
  15. Oct 18, 2024 at 6:53 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Also the jeep grand Cherokee efan from 1999-2003, CBG4F250, put out about 4000cfm.
