  1. Oct 16, 2024 at 1:37 PM
    #7501
    AND
    AND New Member
    Washington, PNW
    I payed $120 delivered.
    BabyMoose[QUOTED] and SoCal_Erik like this.
  2. Oct 17, 2024 at 11:35 AM
    #7502
    maldo012
    maldo012 23 tundra hybrid
    Eric
    Chicago
    23 Tundra Hybrid-Limited
    3inch dobinsons ims struts w/Rough Country 1.5inch spring/M1 shocks in the rear— Icon Uca — Hostile maniac 20inch w/general grabber atx tires — Perry parts front bumps - alpharex luxx headlights— swapped many parts with trd body components— race off-road trd grill etc
    Anyone know what the actual torque should be for upper control arms? For the long bolt? I’m seeing some say 135lbs and some saying 175lbs? I have a limited 23 hybrid with icon tubular uca’s. The icon instructions says to torque to factory specs. But I’m seeing conflicting numbers. Any help would be appreciated
  3. Oct 17, 2024 at 12:31 PM
    #7503
    akira
    akira 25 Tundra Limited TRD OffRoad
    San Diego
    Removed the Limited and Tundra door badges. Next up for removal is the TRD OffRoad bed stickers.
    Raven67 likes this.
  4. Oct 17, 2024 at 12:38 PM
    #7504
    akira
    San Diego
    Those flares look good on a Celestial Silver Metallic (CSM) truck! I have a Limited CSM and looking for a set of color matched flares to replace my stock black one's. I missed your for sale ad by a few months. Nice truck.
    Goobax[QUOTED] likes this.
  5. Oct 17, 2024 at 12:39 PM
    #7505
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Yes, I like the "less is more" clean look. Please post a pic.
  6. Oct 17, 2024 at 12:55 PM
    #7506
    akira
    San Diego
    Paul499, Raven67[QUOTED] and Goobax like this.
  7. Oct 17, 2024 at 3:37 PM
    #7507
    Esoto787
    Esoto787 New Member
    holy smokes that seems expensive. i got mine in 37x12.5x17 for $1346
  8. Oct 17, 2024 at 4:02 PM
    #7508
    Savagesawyer
    Savagesawyer New Member
    Beaverton, OR
    Where??
  9. Oct 17, 2024 at 4:11 PM
    #7509
    donia
    donia New Member
    Miss’ippi
    2023 Celestial Silver Tundra 1794 4x4
    20’s are always higher.
  10. Oct 17, 2024 at 5:22 PM
    #7510
    ramnj
    ramnj New Member
    NJ
    ‘24 Platinum
    Installed the Twin Arb Air Compressor.
  11. Oct 18, 2024 at 6:15 AM
    #7511
    Esoto787
    Esoto787 New Member
    Tirerack.com
  12. Oct 18, 2024 at 7:48 AM
    #7512
    Savagesawyer
    Beaverton, OR
  13. Oct 18, 2024 at 7:49 AM
    #7513
    brutalitybob
    brutalitybob New Member
    Are these compressors small enough to fit in Double Cab storage space or that only Crew Max these are design for?
  14. Oct 18, 2024 at 11:00 AM
    #7514
    Woodrow bangs
    Woodrow bangs New Member
    Baltimore
    2023 MBM Platinum
    Curious to why you installed this in the cab? I kind of like this accessory to be honest but - under the hood or in the bed (hey I found a reason for those stupid molle racks!) seem to be more ideal options?
  15. Oct 18, 2024 at 11:36 AM
    #7515
    Brian422
    Brian422 New Member
    Birmingham, AL
    23 Limited 4x4
    No room under the hood in the 3rd gens for a dual. I created a bracket for a single but thats all you can fit.
    ramnj and Woodrow bangs[QUOTED] like this.
  16. Oct 18, 2024 at 11:41 AM
    #7516
    Woodrow bangs
    Baltimore
    2023 MBM Platinum
    Wait you have two compressors? Thanks for the pic
  17. Oct 18, 2024 at 12:17 PM
    #7517
    Brian422
    Brian422 New Member
    Birmingham, AL
    23 Limited 4x4
    no only 1.
  18. Oct 18, 2024 at 12:56 PM
    #7518
    Cmaccullen
    Cmaccullen New Member
    2022 Tundra Limited
    Installed black tundra letters, rough country trifold hard cover and put on predator steps.
    Twin2turbo, Ausfahrt, kirkb and 4 others like this.
  19. Oct 18, 2024 at 5:10 PM
    #7519
    Jgalla11
    Jgalla11 New Member
    2024 1794 limited edition #719
    24 1794 limited edition over the past month wescott design lift to take me to 3in level. Took it to a shop to have it done. sitting on 295/65/20. Trd pro grill with diode dynamics light bar. Just finished the wiring for light switch today. Grill and wiring done by myself.
    Ncousins1, mikev25, Kerktam and 9 others like this.
  20. Oct 18, 2024 at 6:32 PM
    #7520
    ramnj
    ramnj New Member
    NJ
    ‘24 Platinum
    It’s a small compressor and the mount is from SDHQ made specifically for the Crew Max.
  21. Oct 18, 2024 at 6:33 PM
    #7521
    ramnj
    ramnj New Member
    NJ
    ‘24 Platinum
    It’s the only mount I found and is made to be mounted inside the cab.
  22. Oct 18, 2024 at 10:26 PM
    #7522
    TwiZtedBiker
    TwiZtedBiker New Member
    2024 limited TRD Off-road
    Well it was a few days worth but did a few changes to the Limited after bambi busted up all the plastic. Fab Four Vengeance bumper, a Platinum grille and few other little odds & ends like a screen behind the grille to keep things from hitting those nice soft radiator & intercoolers, noticed two had taken hits when I was cleaning the bugs out. Oh, a heads-up, that bumper will not just bolt up with the platinum grille, you either make 3/8'+ spacers or trim the lip on the bumper. Now need to figure how to tie into the canbus for the auto high beams.
    image_123650291(1).jpg IMG_20241018_134933130_HDR.jpg IMG_20241018_180105652.jpg
    Mr Rick and ramnj like this.
  23. Oct 19, 2024 at 7:11 AM
    #7523
    Paul499
    Paul499 Large Member
    Paul
    Sarasota, FL
    2024 Platinum Hybrid
    Weld 20x9, Toyo 285/60, RC N3 level, ceramic tint
    One of the sweetest looking trucks I've seen. Really nice OEM+ look and those black center caps on the LE wheels are the cherry on top. Bravo
  24. Oct 19, 2024 at 1:19 PM
    #7524
    Helped my buddy do a 50k service on his 22’
    We did the transmission fluid as well.
    Tundrastruck91 likes this.
  25. Oct 19, 2024 at 4:08 PM
    #7525
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    Painted my fog light bezel to match and added Rigid amber fogs.
    MAC25Tundra, ytank1, kirkb and 7 others like this.
  26. Oct 19, 2024 at 4:40 PM
    #7526
    Raven67
    Kentucky
    Getting things ready to do the Heritage grille swap on my limited. Went with the flea bay version of light bar & amber marker lights. Had I known I'd have to make my own bracket for the marker lights I would have ordered OEM instead. The kit was nice other than no bracket. Grille will go in next weekend (I hope).20241019_121802.jpg 20241019_121844.jpg 20241019_121902.jpg 20241019_121908.jpg
    Twin2turbo, SoTex-Tundra and RatPanda like this.
  27. Oct 19, 2024 at 5:20 PM
    #7527
    ManUtdFC28
    ManUtdFC28 New Member
    Looks amazing. What size are those tires and do they rub?
    drewpweinerMD[QUOTED] likes this.
  28. Oct 19, 2024 at 5:25 PM
    #7528
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    Got the Fire Hazzard final fix recall done! Just going to continue to enjoy the ride!
  29. Oct 19, 2024 at 5:36 PM
    #7529
    ReCKzX
    ReCKzX New Member
    2023 Tundra TRD Pro Ice Cap
    White Knuckle Off-road Sliders
  30. Oct 19, 2024 at 5:41 PM
    #7530
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    Thanks man. They’re cooper 285/65r20’s with zero rub. I do have a fabtech 1.5” level
