Engine Coolant Not Getting Up to Temp
Discussion in '1st Gen Tundras (2000-2006)' started by rich58, Oct 3, 2017.
  1. Oct 3, 2017 at 12:16 PM
    rich58
    rich58 [OP] New Member
    Rich
    2001 Tundra 3.4 L V6
    My 2001 Tundra with a 3.4 L V6 got rejected for NJ inspection due to having two monitors (EVAP and CAT) not ready (I had recently replaced the battery). I am trying to run the Drive Cycles (according to Toyota TSB) to get them to the ready state. For CAT, a precondition is to warm engine up so ECT is 80C (176F) or higher. Monitoring OBD, my engine coolant temp tops out at around 78C no matter what I do (idle for a long time, drive at city speeds, drive at highway speeds).
    Two questions:
    - how can I get running temp to be higher than 80C so I can run the drive cycle
    - is a low running temperature harmful?
  2. Oct 3, 2017 at 12:29 PM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    Could be your thermostat, if not closing the fluid just circulate. Or to much antifreeze and not enough water.
  3. Oct 3, 2017 at 1:09 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Probably your thermostat.. I’d look there first
  4. Oct 3, 2017 at 2:33 PM
    rich58
    Rich
    Using a scan tool. One of the sensors it monitors is engine coolant temp.
  5. Oct 3, 2017 at 2:46 PM
    rich58
    Rich
    Will definitely check the thermostat and replace if it is stuck open. But if it opens and closes but its just that the set point is just a bit too low, I don't want to replace it if it is not really a problem for the truck to run at an operating temp just under 176F (I understand normal operating temp is more like 190F). Anyone know the expected ECT when warm?
