My 00, 4.7 Tundra won't start.
Discussion in '1st Gen Tundras (2000-2006)' started by Andy76, Oct 16, 2024.
  1. Oct 16, 2024 at 1:22 PM
    Andy76
    Andy76 [OP] New Member
    00 Toyota Tundra 4.7 , 2WD
    E.
    Hello, my Tundra won't start unless you floor the gas pedal. When is start won't idle either. Replace coils, plugs, throttle and still doing it. Any idea? Will gladly appreciate any help.
  2. Oct 16, 2024 at 2:23 PM
    Define “won’t start”. Like, it won’t turn over? Or it won’t fire?
    if it turns over but won’t fire, what happens if you spray a shot of starter fluid in the throttle body? Does it fire right away? Or still need to hold the pedal down? This is the first inexpensive test I’d do.
    Does the inside of the throttle body look clean?
    Are there any codes stored? (Don’t rely on the check engine light, 2000-2004 trucks bulb can burn out).
    BroHon likes this.
  3. Oct 17, 2024 at 12:41 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Must be a bot. 2000 tundras always start:)
    BroHon likes this.
