08' Tundra Blinking VSC, 4Lo and Check engine lights
Discussion in '2nd Gen Tundras (2007-2013)' started by JAM_03, Oct 11, 2020.
  1. Oct 11, 2020 at 8:24 AM
    JAM_03
    JAM_03 [OP] New Member
    Tony
    2008 Tundra 4x4 Crew Max
    On my 08' Tundra i started her up yesterday and the VSC, 4Lo and Check engine lights are constantly blinking. Tried to reset everything by disconnecting battery and no dice. Tried engaging/disengaging 4WD and again no dice. She seems to drive fine, but a bit uncomfortable when lights that are supposed to be dummy proof are going off. LOL Any suggestions or ideas on issue would be appreciated.
  2. Oct 11, 2020 at 8:26 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Gotta have the code for the CEL...
  3. Oct 11, 2020 at 8:28 AM
    JAM_03
    Tony
    sorry not sure I follow you....
  4. Oct 11, 2020 at 8:32 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    You will need to find out what the code is that is set which turns on the Check Engine Light. Sometimes the local auto parts store with do this at your request free of charge. That's the real determination, the other lights come on as a matter of course to let you know that those functions are disabled due to the Engine Code. Many manufacturers do this as a matter of course.
  5. Oct 26, 2020 at 6:15 PM
    Kubeanie
    Kubeanie New Member
    2007 tundra 5.7 milwaukee mile pace truck
    Secondary air injection pump is going bad putting you in limp mode. Google pump bypass kit easy fix
    Leo's first likes this.
  6. Oct 28, 2020 at 1:21 PM
    Dr. Goesinya
    Dr. Goesinya New Member
    2011 Tundra 4x4 Crew Max
    N/A
    What Kubeanie said.....
    Kubeanie likes this.
  7. Oct 28, 2020 at 1:34 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    He said it drives fine so not in limp mode but still more then likely an SAIP issue
    Stop by a parts store ( AZ, OR, Advanc ) most all of them will pull codes for you then come back here and order the Hewitt Tech bypass kit
  8. Oct 28, 2020 at 11:26 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I vote for codes before buying anything... chances are something got loose or a rodent bit something that may trigger something..
    Wynnded and Leo's first like this.
  9. Oct 28, 2020 at 11:42 PM
    DjScoop
    DjScoop New Member
    2013 Red Rock Warrior/Limited double cab
    I had the same problem once and it turn out to be a broken ABS wire
    Leo's first and blackdemon_tt like this.
  10. Oct 29, 2020 at 4:27 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    This may help narrow it down in conjunction with the codes.
    Lrc1960 likes this.
  11. Oct 29, 2020 at 4:10 PM
    Kubeanie
    Kubeanie New Member
    Lrc1960 likes this.
  12. Nov 4, 2020 at 1:01 PM
    Gto7419
    Gto7419 New Member
    2010 Tundra
    Just got the same lights yesterday. Tranny felt like it was going into neutral while driving. Pulled codes and a solenoid wasn't activating when the tranny was cold. Works fine when warm. You need to get the codes pulled. This could be so many different things.
  13. Mar 30, 2021 at 4:22 PM
    Clintotron
    Clintotron New Member
    Clint
    Wwwytte Wwwyzzerdd 2008 DC SR5
    LED projector headlamps/LED taillights, mud guard delete, EGR delete, 35x12.50x18 on black dipped capless stockers, no lift (yet), aftmkt sound system, other forgotten mods.
    I ordered and installed an AIP bypass kit. I’m getting these codes again. Anything I should check? Are there any fuses related?
  14. Mar 30, 2021 at 5:33 PM
    Gto7419
    Gto7419 New Member
    2010 Tundra
    Mine ended up being tranny fluid level. What codes are you getting?
  15. Mar 31, 2021 at 5:03 AM
    Clintotron
    Clint
    I haven’t had it checked yet. I’m working 7 12s. May be a minute until I’m free to have that analyzed.
  16. Apr 2, 2021 at 7:24 AM
    Clintotron
    Clint
    I got the following codes:
    P0302
    P0125
    I looked them up. Cylinder 2 misfire (ran kinda rough once for about 30 seconds at ~50 mph). The 2nd code is for low coolant. And I know I have a radiator leak. About to purchase a new one. Is there a way to reset without going to a dealer?
  17. Apr 2, 2021 at 9:49 AM
    Ricos
    Ricos New Member
    Ricardo
    2010 Tundra SR5 White Widow
    Never stopping ...
    Fill up your coolant & Swap your coil pack from the 2nd cilinder to another one and visa versa , erase the codes and see what comes back up ... how did you get the codes ? You’re better of buying a obd reader so you can read/erase yourself.You could always try taking of the negative battery side.
    Clintotron likes this.
  18. Apr 2, 2021 at 11:07 AM
    Clintotron
    Clint
    I sought the unending wisdom of the employ of the local O’Reilly after work. Any recommendations on an OBD-II reader?
  19. Apr 2, 2021 at 1:38 PM
    Ricos
    Ricos New Member
    Ricardo
    Never stopping ...
  20. Mar 30, 2023 at 3:01 AM
    Cghelton
    Cghelton New Member
    Curtis
    2008 Silver Tundra Limited TRD
    Back from the dead. Have had the truck for about a year or so and all of a sudden these lights came on including the 4 LO light.
    Had my buddy who’s a mechanic scan my 2008 Tundra with the 5.7 and 173k miles.
    Brought up these codes. I’m guessing it’s an Saip problem? Do I need the Hewet bypass kit?
    Would that also cause it not to go into 4wd?
    Runs good like it is. Just hate all the lights and would rather fix it.
    Thanks!
  21. Mar 30, 2023 at 3:18 AM
    Cghelton
    Cghelton New Member
    Curtis
    I did replace the MAF several days ago. Was getting these codes before that. Not sure it would help any of these other codes/lights. Definitely helped the MPG. Went from distance to empty from 300 to 439 after I filled up.
  22. Jan 16, 2024 at 8:11 PM
    keryxon
    keryxon New Member
    2013 Tundra Platinum Crewmax
    Hi Cghelton,
    Were you getting the Engine, Trac Off, and blinking 4Lo? If so, did replacing MAF rid of those dreaded 3 lights?
  23. Oct 17, 2024 at 12:09 PM
    Jaycamp_92
    Jaycamp_92 New Member
    This was my results. Anyone come up with a solution?
