3rd gen 1” Cornfed front spacer
Discussion in 'Suspension' started by Mavs79, Mar 27, 2023.
  1. Feb 13, 2024 at 1:23 PM
    cvd2312
    cvd2312 New Member
    2023 CrewMax SR5 TRD OR
    It's a collar and top plate spacer combo. Collar does 1.5" and top plate spacer is 1/4" thick so it provides an additional 1/2" lift
    Chomponthis[QUOTED] likes this.
  2. Feb 13, 2024 at 3:11 PM
    cvd2312
    cvd2312 New Member
    Looks great. How's the ride with those tires? Rougher than stock?
  3. Mar 21, 2024 at 7:36 AM
    901tundra
    901tundra New Member
    Memphis, TN
    2023 Magnetic Gray Limited TRD Off-road
    - Color-matched grille and rear bumper insets - 1-inch Cornfed front spaces - TRD grille with light bar and amber marker lights - Debadged
    For those of you who did the install yourself, how bad was it? Just reading through these directions seems like ... a lot.
  4. Mar 21, 2024 at 4:23 PM
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    On a new truck, easy imo. Depends on how mechanically inclined you are I guess. I’m use to everything fighting me coming apart here in the northeast. New truck was easy peezy
    901tundra and Chomponthis like this.
  5. Mar 22, 2024 at 12:20 PM
    901tundra
    Memphis, TN
    My brother-in-law has a shop and is going to do the heavy work. Did anyone dig up torque specs for everything?
  6. Mar 22, 2024 at 3:47 PM
    Northern Toyota
    Tires and bilstein
    I did, it’s on the forums here somewhere. Torque the LCA bolts and maybe a few others, I can’t remember, with the truck on the ground (weight on suspension components)
    901tundra likes this.
  7. Aug 25, 2024 at 4:38 AM
    mbean224
    mbean224 New Member
    Matthew
    2024 Ice Cap Tundra Limited w/ TRD off road
    Hello. i just got this installed and looks great. Ive had alignment issues at factory, then at tire upgrade, and now I still feel it is pulling to the right and I'm seeing from the front looking down this appearance of the tires |--/. Here is picture of my alignment specs and the truck. Anyone have their specs of the alignment after the install of the cornfed 1 in the front. IMG_1293.jpg Cornfed Install Payment page 2.jpg
  8. Oct 16, 2024 at 6:53 AM
    Shapo
    Shapo New Member
    Cesar
    Hello guys, I just installed 295/70r18 Nitto ridge grapplers on my sr5 stock suspension and not rub at all. I have ordered the 1" cornfed as well to make the truck look level.
  9. Oct 16, 2024 at 7:14 AM
    Northern Toyota
    Tires and bilstein
    That’s my setup. No issues in over a year.
    Shapo[QUOTED] likes this.
  10. Oct 16, 2024 at 12:44 PM
    Shapo
    Shapo New Member
    Cesar
  11. Oct 16, 2024 at 2:47 PM
    Northern Toyota
    Tires and bilstein
  12. Oct 17, 2024 at 4:10 AM
    60centenergy
    60centenergy I'm not superstitious, but I am a little stitious
    Zack
    GVL
    2024 Lunar Rock SR5 Tundra TRD Sport
    Anyone install this on the TRD Sport and have pictures? I plan on installing on mine in a few weeks. Eventually will upgrade tires too but will only go there once stock ones are done.
  13. Nov 26, 2024 at 6:04 AM
    NY24SR5
    NY24SR5 New Member
    White 24 SR5
    Looking at the 1” kit for my 24 SR5. Besides the alignment are there any known recalibration issues with all the sensors? I don’t see any mentioned through my searches but i see some lift threads that sound like a disaster with all the safety systems. Would like to level the truck some without opening a can of worms.
  14. Nov 27, 2024 at 12:52 PM
    Sulzy
    Sulzy New Member
    2023 Black Tundra 1794 TRD
    Hey @mbean224 - your setup looks PERFECT (imho). My local shop just installed toyo open country at3's (285/65/r20) on stock trd 20's and the cornfed 1" front lift. They let me know today that their alignment machine does not have the correct specs to align my truck? They scheduled the alignment with my local toyota dealer instead. Picking it up here in a little bit. Did you get your alignment sorted out? Also, can you tell me what side steps you've got? Thanks!!
  15. Dec 1, 2024 at 5:55 PM
    60centenergy
    Zack
    GVL
    Hoping this will help anyone out looking at this level lift. I just installed if over Thanksgiving and I am loving it. My truck sits up much better. I have the Sport model and like how the front end is raised back up some and still has rake.
    Nomoredomestics likes this.
  16. Dec 7, 2024 at 10:27 AM
    Duckinatruck
    Duckinatruck New Member
    I’m looking at 295/70/18 tires and have the same level as you. However, I have aftermarket wheels with +18 offset. Looking at your setup/wheel articulation, do you think my offset will help that fitment or make it worse?
  17. Dec 7, 2024 at 4:41 PM
    Northern Toyota
    Tires and bilstein
    I honestly couldn’t tell you. I know the further you push a wheel out with offset the wider the arc the wheel will turn and increases chances for rubbing. But not sure if that’ll matter in your specific case
    Duckinatruck[QUOTED] likes this.
