1st Gen camper shell buying info
Discussion in 'Tonneau Covers, Caps and Shells' started by shifty`, Mar 26, 2021.
  1. Oct 9, 2024 at 10:48 PM
    #1801
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    racist. reported.
    Tlar25 and CodyP like this.
  2. Oct 9, 2024 at 11:02 PM
    #1802
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Well, as I'm fully aware this thread is about camper shells or whatever, I'd rather hear about the time you shit your pants while shooting at a fawking bear.
    455h0le_dachshund likes this.
  3. Oct 13, 2024 at 6:50 PM
    #1803
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
  4. Oct 14, 2024 at 9:22 PM
    #1804
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    AC near DFW DC near Houston
  5. Oct 16, 2024 at 8:16 AM
    #1805
    CORNELIUSGUN
    CORNELIUSGUN New Member
    2006 DC SR5 TRD 4x4, Blue
    EZ Lift ARE High-rise Camper Topper
    My new tundra w/the EZ Lift & tent combo. 178k miles
  6. Oct 16, 2024 at 9:26 AM
    #1806
    shifty` [OP] Just like witches at black masses
    Damn, and windoor sliders on the mid-rise cap. You've got like $2k sitting on the back of your truck :rofl:
    (I doubt you'd get that much, but ... in an ideal market that's probably what it'd be worth, too bad it's an unusual color cap, else you'd have a larger buying segment.)
    G_unit3000 likes this.
  7. Oct 19, 2024 at 3:23 PM
    #1807
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Can't decide if I wanna go with a softopper or a hard shell. Would be nice to fold the softy and storage would be way easier and a one person job but I feel the hard shell would look better. Just so hard to find a decent one with good paint and glass that actually fits the DC.
    87warrior likes this.
  8. Oct 19, 2024 at 5:53 PM
    #1808
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    I picked up a used softopper about 6 months ago that was in near mint condition. I love the thing for all the reasons you just mentioned. I can't find anything I don't like about it honestly, and I like the way looks. But I was never interested in getting a hard shell so maybe I'm just biased towards the softoppers.
    87warrior and CodyP like this.
  9. Oct 20, 2024 at 11:35 AM
    #1809
    This Leer 100R AC shell in Western NC is in pretty rough shape, needs brake light, has no key, absolutely needs paint, has the typical front corner damage, and seller admits a bad window seal. Should be priced closer to $200, but maybe it's interesting to someone.
  10. Oct 21, 2024 at 12:45 PM
    #1810
    Not a camper shell, but it is a bed cover. ARE brand, you can buy a replacement key, the price is stupid cheap and it looks like the struts and linkage is intact. Waaaay up in the northeast corner of TN. These normally go for a couple hundo more.
    G_unit3000 and FiatRunner like this.
  11. Oct 27, 2024 at 1:53 PM
    #1811
    87warrior
    Kansas
    2004 DC 2uz 4x4
    I waited over a month to contact the seller and this topper was still available. Got it for two Benjamin's which seemed like a fair price. Now the Tundra looks like a real paw-paw truck!
  12. Nov 2, 2024 at 10:29 PM
    #1812
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    What kind of weather stripping y'all use between the shell and the bed? Adhesive foam strip?
  13. Nov 2, 2024 at 10:30 PM
    #1813
    Double bubble
  14. Nov 2, 2024 at 10:31 PM
    #1814
  15. Nov 2, 2024 at 10:36 PM
    #1815
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I also use the double double. Have for decades and happy with the seal.
  16. Nov 2, 2024 at 10:53 PM
    #1816
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
  17. Nov 2, 2024 at 10:59 PM
    #1817
    OldGuy03
    Jay
    CO
    12 MGM DC RW
  18. Nov 2, 2024 at 11:04 PM
    #1818
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Good to know thanks.
    Buying some double bubble now.
    OldGuy03[QUOTED] likes this.
  19. Nov 2, 2024 at 11:05 PM
    #1819
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Last dumb question: Do y'all stick the adhesive side to the cap or the bed?
  20. Nov 3, 2024 at 1:50 AM
    #1820
    Cap
  21. Nov 3, 2024 at 6:07 AM
    #1821
    Yup and adding to this, after you apply it to the bulkhead part of the cap rail, make sure, when installing the cap, you lift the cabside end of the cap up onto the bedrail, to avoid peeling back or otherwise doing bad shit to the double bubble. The weight of the cap on the double bubble should help set the adhesive. Also, be aware of your double bubble width, and how it’ll sit between the side rail caps. It’s easy to create a leak spot I. The corners. Some people will drop a line of weather strip foam like you’d use on a window ledge along the plastic rail cap to plug the right angle corner there.
    G_unit3000 and 455h0le_dachshund like this.
  22. Nov 3, 2024 at 7:03 AM
    #1822
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    ESI has instructions for when to use the different product for the front rail. The front rail is often (always?) a slightly different height than the side rails. If there's a large enough difference, they recommend that other product. My Tundra (and so I'm guessing yours) has a large enough gap that at least if you follow their instructions, you'd need that different seal for the front rail. I used it. I still have a very slight leak but I haven't tracked it down...
    But I'd say people's actual experiences with their Tundra should count for more than ESIs generic, universal instructions.
  23. Nov 3, 2024 at 5:19 PM
    #1823
    Dook55
    Dook55 RCLB Guy
    Montana
    I like to sprinkle talcum powder all over the bed rails when I set the cap so that it will slide to make minute adjustments without pulling the gasket off.
  24. Nov 3, 2024 at 5:22 PM
    #1824
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Awesome life hack!
    G_unit3000, FrenchToasty and OldGuy03 like this.
  25. Nov 3, 2024 at 5:56 PM
    #1825
    Nice black leer 100R supposedly for a DC in Tallahassee, only $175. Needs struts. Has roof rails.
  26. Nov 3, 2024 at 6:01 PM
    #1826
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I forgot I need new struts, do y'all order generic ones or from the makers of your cap or what?
    OldGuy03 likes this.
  27. Nov 3, 2024 at 6:03 PM
    #1827
    Scamazon struts
    these:
    C16-09209 16 inch 38 Lbs (169 N)... https://www.amazon.com/dp/B096VZB737?ref=ppx_pop_mob_ap_share
    they were however slightly skinnier than the ones on my 2019 and the prop rod switch wouldn’t work on them.
  28. Nov 3, 2024 at 6:08 PM
    #1828
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I'll have to take one of mine apart and measure it before ordering anything. I also need to order keys for the locking latches.
    Unfortunately Jason's website is not very helpful and I can't find a way to contact them.
  29. Nov 3, 2024 at 6:27 PM
    #1829
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Genius.
  30. Nov 3, 2024 at 6:32 PM
    #1830
    Yeah, skip them. Reach out to these guys: https://truckoutfittersplus.com/truck_topper_parts.html
    They don't list Jason as a brand, but Ranch is really similar to Jason, and they'll be able to tell you how to measure the struts and get you some good reliable ones. They have literally every seal and shit you need too.
    These guys have a ton of stuff too, but I've never bought from them. Truck Outfitters+ is where I bought nearly everything to rehab my shell.
    Note there is a Jason dealer that may not be horribly far from you. I plugged in rando zip code that's at least within 60 miles of where I think you may be, but here's the locator for them: https://jasoncaps.com/dealer-locator/?find=find&info=dealers
    Houston Truck Accessories & Auto Repair
    8810 Cypress Creek Pkwy,
    Houston, TX, 77070
    281-469-8900
    Htaaar1960@gmail.com
