Wheel bearing press
Discussion in '1st Gen Tundras (2000-2006)' started by BlueGarden, Oct 15, 2024.
  1. Oct 15, 2024 at 4:34 PM
    BlueGarden
    BlueGarden [OP] New Member
    Paducah, KY
    2002 Tundra Limited 4x4 4.7L
    I am going to be pressing out my front wheel bearings, and then pressing them back into a new steering knuckle. I have a 12 ton press, but have seen online that a 20 ton press is needed. Surely a 12 ton press is enough, right?
  2. Oct 15, 2024 at 5:02 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Replacing the wheel bearings in my truck gave my 20 ton press a workout and it doesn't work quite like it used to. At least with my knuckles, there's no way a 12 ton press would have been strong enough.
    Jack McCarthy and FrenchToasty like this.
  3. Oct 15, 2024 at 8:27 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    20 ton.
    Unless rusty, then 50.
  4. Oct 15, 2024 at 8:36 PM
    I’ll third the 20 ton. It gave mine all it wanted.
  5. Oct 16, 2024 at 2:27 AM
    BlueGarden
    Paducah, KY
    Wow, thanks for the info. I didn't expect that!
  6. Oct 16, 2024 at 4:55 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    I did mine with 12 ton.
  7. Oct 16, 2024 at 6:40 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    call everybody a bitch without calling everybody a bitch LMFAO :rofl:
  8. Oct 16, 2024 at 7:43 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    I did mine with a 20. Certainly gave my 20 some work. A 12 might work, might not. I would try it with a 12 first.
  9. Oct 16, 2024 at 10:22 AM
    whodatschrome
    lots of dents
    What’s more challenging than pressing out the old bearings, is having enough random steel plates and spacers that will be required to support the knuckle during the pressing.
  10. Oct 16, 2024 at 10:34 AM
    kentuckyMarksman
    Very true. Pressing the bearings out I had to be pretty creative to find a way to support the knuckle. It definitely helps to have extra spacers / plates around.
  11. Oct 16, 2024 at 10:43 AM
    100%
  12. Oct 16, 2024 at 3:33 PM
    FishNinja
    Lee
    06DC2wd
    holy shit it's the toolman
  13. Oct 16, 2024 at 3:37 PM
    Sue at 1A auto has the video to replace FGT front bearings
  14. Oct 16, 2024 at 3:51 PM
    30 extra tons to overcome rust? That’s some strong rust. :rofl:
    BroHon likes this.
  15. Oct 17, 2024 at 5:09 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    If it's the video I'm thinking of, they use a big brake disk to support the knuckle. Looks like it's probably from a 1 ton truck. I keep thinking I need to find someone who works on heavy trucks to let me pick one out of their scrap pile.
  16. Oct 17, 2024 at 5:14 AM
    I used a large van disk with the center cut out on the first side. Worked pretty decent. When I used it on the second knuckle it exploded under tension. Fun. Switched to angle iron and 4x4 post we had laying around.
    tvpierce[QUOTED] likes this.
  17. Oct 17, 2024 at 5:21 AM
    tvpierce
    Maine
    Good point! Yeah. it's not going to give any warning -- like bending or flexing -- it's just going go. Maybe not such a good idea after all. Thanks!
  18. Oct 17, 2024 at 7:57 AM
    mthoodbill
    mthoodbill New Member
    Mt Hood, Oregon
    2000 Tundra SR5 Access Cab 4x4, 2012 Mini cooper clubman S
    Bilstein 6112, .5" front lift. 5100 rear. 17" FJ steel wheels Gofast topper
    I had Metal Supermarkets cut me up some different sized plates to use in my press. It wasn't much money and it's handy to have if you are using a press. Also safer. 20 ton is a bunch of pressure, things can go bad fast.
    tvpierce likes this.
  19. Oct 18, 2024 at 6:03 AM
    HeavyWasher
    HeavyWasher New Member
    2005 DC Tundra SR5 4x4
    Front ARB 90004 w/ 2883 springs & poly isolators Rear stock leaf w Firestone RideRite & Bilstein 5100
    This is very accurate. Would not recommend using concrete bricks as they crack and you have to stop replace and adjust. But sometimes you gotta press with the press you’ve got.
    can confirm a 12 ton will get the job done.
  20. Oct 18, 2024 at 6:18 AM
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    Agree it can be done with a 12 ton - PB blaster, heat, BFH. The POP they make when they finally let loose is on par with a cold light beer can crack on a hot summer day after mowing the lawn.
    whodatschrome, Mustanley and KNABORES like this.
  21. Oct 18, 2024 at 6:54 AM
    mthoodbill
    Mt Hood, Oregon
  22. Oct 18, 2024 at 1:09 PM
    whodatschrome
    lots of dents
    Shoot…i DID use heat with my 20 ton press and it still wouldn’t give up without a fight! The loud POP was most definitely unnerving. Installs should be easier than removal. I froze my bearings overnight in the freezer, used a torch to heat the knuckles, and smeared a light coat of anti-seize on the mating surfaces.
    blackoutt[QUOTED] likes this.
  23. Oct 19, 2024 at 12:35 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    https://www.tundras.com/goto/post?id=3736040#post-3736040
