Tundra engine recall - interesting news
Discussion in '3rd Gen Tundras (2022+)' started by katekebo, Jul 25, 2024.
  1. Oct 15, 2024 at 2:57 PM
    #1681
    winchester44
    winchester44 New Member
    2016 1794 4WD
    No no, no your daughter had no such experience. As many experts on this forum will tell you a cab off motor swap is completely routine, barley more than an alternator swap and well within the skill set of any certified dealership mechanic. Nothing to lose sleep over, it goes perfectly every time.
    In all seriousness regarding the "long block speculation" Toyota has not promised anyone more than a "replacement engine assembly" No one including the techs knows what that means and no one has received one either. Anyone claiming otherwise is making stuff up.
  2. Oct 15, 2024 at 3:00 PM
    #1682
    winchester44
    2016 1794 4WD
    Wait, what aren't they swapping you out with a brand new engine as we speak like everyone here is claiming. You should be back on the road before the weekend correct?
    Black widow TRD likes this.
  3. Oct 15, 2024 at 3:05 PM
    #1683
    Breathing Borla
    AZ
    spam the board much dude? geez, give it rest
    Squeakythecar, j-utah, Vizsla and 5 others like this.
  4. Oct 15, 2024 at 3:09 PM
    #1684
    winchester44
    2016 1794 4WD
    I correct myself. The 2021/2022 Ford 2.7- and 3.0-liter EcoBoost engines valves does seem to be pretty bad, but seems to be the only one approaching regular catastrophic engine failure.
  5. Oct 15, 2024 at 3:11 PM
    #1685
    winchester44
    2016 1794 4WD
    Curious what you feel he got wrong?
    WNY PAT likes this.
  6. Oct 15, 2024 at 3:11 PM
    #1686
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I see the lying shit stirrer is back, after saying goodbye to us...twice. Oh goody!!
    Vizsla, BlackNBlu, Jackstraw and 2 others like this.
  7. Oct 15, 2024 at 3:12 PM
    #1687
    Breathing Borla
    AZ
    :nuclear:
  8. Oct 15, 2024 at 3:24 PM
    #1688
    AZBaldy
    AZBaldy Bald, James Bald, 000...
    Z
    Kaliforniastan
    2008 SR5 4Runner
    The 3rd gen drama never disappoints!
  9. Oct 15, 2024 at 3:55 PM
    #1689
    Wtundra2023
    Wtundra2023 Bad Weld Aficionado
    2023 Limited Tundra, 2014 Limited Sequoia
    So I take it your valley plate gasket, cam tower seals, timing tensioner, crossover pipe oring, have not had to be replace or repaired leading to extended out of service times?
  10. Oct 15, 2024 at 4:04 PM
    #1690
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    Show us on the troll where Toyota hurt you.
    You are a class act, quoting a guy who’s ‘22 engine failed.
    Breathing Borla likes this.
  11. Oct 15, 2024 at 4:05 PM
    #1691
    SpilledTheSalt
    SpilledTheSalt Fish Lips
    Oregon
    2024 Tundra 4x4 HV Limited TRD
    2" RC Leveling Struts
    You state that like the guy actually knows something. All he does is scour the shit floating around the Internet and re-package into a YouTube video with a giant headline and his dumb face on it.
  12. Oct 15, 2024 at 4:05 PM
    #1692
    AZBoatHauler
    So.Arizona
    I haven’t experienced any of those - and I haven’t seen a single catastrophic failure related to any of those issues either. 3UR might ooze some juices but it keeps churning.
    The valve guide issue is one I haven’t seen before and is cause for concern imo but then again nothing surprises me when you have these small displacement engines making monster torque.
  13. Oct 15, 2024 at 5:02 PM
    #1693
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    None of those issues have happened to you the same as no issues have happened to over 100,000 3.45L Toyotas here. People just love to hate.
    22whatwedo and Tundrastruck91 like this.
  14. Oct 15, 2024 at 5:03 PM
    #1694
    Northern Toyota
    Tires and bilstein
    Click on his name and hit ignore, problem solved.
  15. Oct 15, 2024 at 5:08 PM
    #1695
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Yotas long dick, right across the Pacific.
    hagrid[QUOTED] likes this.
  16. Oct 15, 2024 at 5:16 PM
    #1696
    Wtundra2023
    Catastrophic failure perhaps not in every case. However, they are still issues that leave you without your car for an extend period of time. Worse they will likely happen out of warranty leaving the consumer on the hook for a very expensive repair.
    Neither engine is perfect. If you look at my profile you will see I own one of each and can attest to the imperfections of both. Acting like one is perfect while the other is entirely flawed is pretty short sighted.
    There is no need pile on others misery and its foolish to ignore the problems that exist in both engines.
    DerekinUT and MaineTundy like this.
  17. Oct 15, 2024 at 6:41 PM
    #1697
    Breathing Borla
    AZ
    mmmmmmm…. Monster torque
    j-utah, Vizsla, PermaFrostTRD and 3 others like this.
  18. Oct 15, 2024 at 8:01 PM
    #1698
    winchester44
    2016 1794 4WD
    I’m in Land cruiser now, But my 2.5 gen made it to 150,000 miles with normal recommended service. Zero issues.
    Fobroader and Terndrerrr like this.
  19. Oct 15, 2024 at 8:04 PM
    #1699
    winchester44
    2016 1794 4WD
    Wow…
    I’m not the one trolling him. Others Are saying he’s overreacting and should not be so concerned with a non drivable truck because he can get a new engine “swapped” anytime he wants. I’m literally sympathizing with him because he is right and they are wrong.
    I guess you feel sympathizing with those who are affected by the V-35 recall issue On the V.35 recall issue thread “trolling”.
    Just a reminder it’s V35 engine recall forum. Yet a couple of you are losing your minds over anyone who actually wants to discuss V35 recall. It would seem obvious, but you might try avoiding this thread if it’s driving you to this level of buffoonery.
  20. Oct 15, 2024 at 8:27 PM
    #1700
    winchester44
    2016 1794 4WD
    Seriously trying to equate cam tower leaks to a blown motor?
    You’re comparing a very minor repairable design issue to a catastrophic manufacturing defect . Assuming Toyota is telling us the full story they shipped truck after truck after truck of motors full of loose shards of metal…for years .
  21. Oct 15, 2024 at 8:31 PM
    #1701
    winchester44
    2016 1794 4WD
    I missed you too buddy!
    Been so slow over Land Cruiser world. We’re discussing round versus square headlights. Care to weigh in which one you like better?
    WNY PAT and AZBoatHauler like this.
  22. Oct 15, 2024 at 9:01 PM
    #1702
    FrankG
    FrankG New Member
    Francois
    2022 Lunar Rock Sr5 TRD Off Road
    You have a strange way of showing sympathy.
    Getting annoyed because the peanut gallery are telling us (who actually own the truck!!!), how we should be feeling and reacting, seems like a perfectly natural reaction actually.
    How’s about, you stop trying to discuss the recall or, at least, change your approach because it’s clearly not what it appears you’re doing, and we’ll stop “losing our minds” as you so eloquently put it?
    Breathing Borla and Jackstraw like this.
  23. Oct 15, 2024 at 10:13 PM
    #1703
    winchester44
    2016 1794 4WD
    I get annoyed and you should too when people post false claims that Toyota has brand new engines available for anyone in the current recall who wants one. That is simply not true.
    Others are claiming that this is a very minor issue isolated to a very few trucks.
    They totally dismiss the mountain of Facebook and Reddit posts showing they are dropping like flies…..daily. Then out of the other side of their mouth point to the scope the recall and somehow claim that’s further proof that the vast majority of motors are fine and it’s just Toyota being overly thorough.
    Now we have multiple sources talking about 2024 being recalled, still ignoring hybrids and still no actual remedy for those in the recall.
    As car care nut just said, Toyota is absolutely on this forum watching and listening. Those of you going around saying everything is fine and don’t worry about it are doing nobody a favor.
    As far as claims that only current owners should comment, I would very much like to get into a Tundra for and have for multiple years now, but toyota needs to fix this first.
    DimSum07 and Black widow TRD like this.
  24. Oct 16, 2024 at 3:45 AM
    #1704
    PermaFrostTRD
    Northern NY
    Ugh. Can we please stop the straw man garbage? You’re getting your “p-words” wrong. Nobody has ever said the 5.7* is “perfect” on this forum. Ever. Not once. All anyone has ever referred to them as is “proven”. That’s it.
    *still up in the air as to why I won’t refer to any engine as “VU-FRE55.niner” or whatever that dumb shit is. I’m either stubbornly lazy, or it’s the douchiest thing ever.
    winchester44 likes this.
  25. Oct 16, 2024 at 4:14 AM
    #1705
    Wtundra2023
    You missed the point entirely.
  26. Oct 16, 2024 at 4:18 AM
    #1706
    WNY PAT
    WNY PAT New Member
    So guys like me are here to discuss the problems with the new 3.4TT motor as we are weighing the risks of buying a new 2024/2025. Then there are a couple thin skinned Karens who already own the truck and tell us to shut up because they believe the motor issue is a minor inconvenience. So wait, a few Karens have the truck already, don’t believe they’ll have any issues with the motor, and don’t really care if they do get a new long block…. so what’s the point of hanging around here? Isn’t there a Starbucks employee someplace that needs a lecture?
  27. Oct 16, 2024 at 4:19 AM
    #1707
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Agreed. I just wish mine weren't so thirsty :laugh:
    But cam tower seepage has never stranded anyone. Neither have timing chain rattle or generally noisy operation on 0w20 oil. These things really don't even need to be fixed :notsure: It's mostly the coolant valley leak that'll put your truck on the lift for half a day. Even that gives lots of notice before stranding you. The fuel pump is a problem that I wish were more rare.
    Nearly perfect bill of health for my 185k 3UR here. Would love some of you 100k+ V35A-FTS guys to drop an oil report in this thread. Would be nice to have one spot with high mileage reports for all gens.
    winchester44 and Black widow TRD like this.
  28. Oct 16, 2024 at 4:20 AM
    #1708
    Wtundra2023
    You missed the other two not so minor issues with the timing chain and valley plate leak.
  29. Oct 16, 2024 at 4:53 AM
    #1709
    Northern Toyota
    Tires and bilstein
    seems to me the only “Karen’s” are the ones that don’t own the truck and come on here to whine about how the engine will absolutely grenade. The data doesn’t show that. So buy one or not, either way quit the whining.
    Breathing Borla and 75tranzam like this.
  30. Oct 16, 2024 at 5:21 AM
    #1710
    PermaFrostTRD
    Northern NY
    Nope.
    The crux of your entire post hinges on the 2.5 Gen camp saying our trucks our perfect, while the 3rd Gens are all turds - which as I stated, HAS NEVER HAPPENED.
