OEM head unit swap
Discussion in 'Audio & Video' started by Duval7, Oct 15, 2024.
  1. Oct 15, 2024 at 10:21 AM
    Duval7
    Duval7 [OP] New Member
    07 SR5
    I have an sr5 non jbl system. Is the oem screen head unit a plug and play swap? I am not concerned with the GPS working but would like to add a backup camera.
  2. Oct 15, 2024 at 10:25 AM
    Limited-07
    Limited-07 New Member
    2007 MGM limited crewmax
    Canopy, nothing crazy.
    I think you can find what you need on https://www.crutchfield.com/, they are a good resource. you can get adapters to go from factory harness to the deck wiring as well as install kits to fit the hole, modules so you don't lose the steering wheel controls and add cameras.
