Do Tundras come with Atrac?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Andhon, Mar 22, 2022.
  1. Mar 22, 2022 at 2:43 PM
    Andhon
    Andhon [OP] 2014 Platinum MGM CM
    Andy
    2014 Tundra Platinum MGM CM
    I've been getting mixed answers on whether tundras have A-trac and if so in 4wd? I went offroading the other day and turned off my "nannies" but realized that I couldn't get up this hill due to one of my tires being in the air. I have a 2014 Tundra Platinum 4x4
  2. Mar 22, 2022 at 2:51 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
  3. Mar 31, 2023 at 4:13 PM
    Coppertune
    Coppertune New Member
  4. Mar 31, 2023 at 9:23 PM
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Bakflip, Bedstep, Gulfstate stuff
    Compared to the ATRAC on my FJ Cruiser, the TRAC function on my 2020 tundra is nothing like it and only works in 2WD mode. So as far as I'm concerned, the Tundra does not have ATRAC. You can search the 2020 Tundra owners manual and the word "ATRAC" does not appear.
  5. Mar 31, 2023 at 11:37 PM
    18" TRD Off Road Wheels
    It is, because it's in the 2.5 gen section. Not sure if a similar list has been built for the 3rd gen.
  6. Apr 1, 2023 at 12:59 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    See post #2's link for a very detailed answer to your question....
    But, simply put, no our trucks do NOT have 'A-Trac' (My 2019 4Runner Limited did have A-Trac, but it's a different system)
    Our trucks do have Traction Control and Hill Start Assist. Both of these systems are active in 2WD models or 4WD models (in 2WD mode). When you turn off the Traction Control it will also turn off Hill Start Assist, and this is indicated by a warning light on the instrument cluster "TRAC OFF" .
    If you look for a section within your owner's manual titled 'Using the Driving Support Systems' you will find more information on the above assists as well as the Auto LSD system, Brake Assist, Trailer Sway Assist and VSC (vehicle stability control)....
    Jackstraw likes this.
  7. Apr 1, 2023 at 4:55 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    2007-2021 Tundras:
    They do. It’s automatically on in 4Hi and 4Lo without turning off other nannies. The earlier 2nd gen manuals call it TRAC in 2wd and A-TRAC in 4wd, and the later 2nd gen manuals just call it TRAC. It’s not activated by a button push like the 4Runner, but it is on automatically until you turn it off.
    Get hung up on rough terrain with diagonally opposed wheels hanging in the air. In a fully open part-time 4wd system, you’re stuck. Push the ATRAC button in your 4Runner, and crawl right out. Similarly, your Tundra will do the same brake grab to send power to the other wheel on each axle. It’s just on automatically. Mine kicks in quite a bit and is very useful offroad if I pick a good line.
  8. Apr 1, 2023 at 6:00 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    To be fair, you turned off all the aids then ask why the aids didn't help you...
    Andhon[QUOTED][OP] and GaryinAZ like this.
  9. Oct 14, 2024 at 1:31 PM
    GaryinAZ
    GaryinAZ New Member
    Gary
    Phoenix AZ
    '19 Tundra SR5 CrewMax; Cavalry Blue; Shortbed; 5.7L, TRD 4x4 Offroad
    Four section tonneau, Air-lift rear levelers, left & right rear bed swing storage boxes and running board steps; 2" front lift, folding mirrors, catalytic converter shield, tailgate pop n lock and next considering a roof rack
    Excellent answer and hadn't seen it in the Owner's Manual. I made a copy of the table with notes to keep handy as a reference when I forget what the selectable controls mean. Like the OP, when I'm doing abnormal things such as off-roading conditions, I tend to want to limit the auto features. The table tells me what I'm disabling. THX, Mr T! :bowdown:
  10. Oct 15, 2024 at 4:49 AM
    DCRB4X4
    DCRB4X4 New Member
    BLACK 2015 DCRB SR5 4X4
    5100's front, spacer rear
    In my 2015 manual it clearly states that there is ATRAC in 4WD automatically.
    Andhon[OP] likes this.
  11. Oct 15, 2024 at 10:04 AM
    Andhon
    Andy
    Haha yeah I realized that now but that's why I came here to ask, not sure how it worked! but getting some good answers now! Thank you everyone!
    _none_[QUOTED] likes this.
