Help address clunk after 6112 install - Not skid plate related
Discussion in 'Suspension' started by akshorts, Oct 15, 2024.
  1. Oct 15, 2024 at 8:54 AM
    akshorts
    akshorts [OP] New Member
    2021 CMAX with 6112/5160s
    2021 CMAX
    6112/5160s installed at 1.9"
    Stock UCAs
    Still on stock tires and TRD OR wheels
    Alignment done right after suspension install
    I need some help addressing a clunk I'm getting post-suspension install. When hitting small bumps at low speeds with wheels straight or only slightly turned, I'm hearing a clunk from the front wheel areas. Figured it was the skid plate (stock TRD OR plate) but the skid plate is so small I can't figure out where it could possibly be hitting, and I don't see any marks or dents on it. I did notice some bent metal on the driver side strut tower housing (see photos.) The passenger side isn't as bad but does show some signs of wear.
    Has anyone had similar issues? My initial guess is I will need aftermarker UCAs, but since I'm still on stock tire size I would be really surprised if I need to go aftermarket UCAs. Anyone have other ideas what it could be? Anything I should recheck with the sway bar maybe?
    Thanks.
  2. Oct 15, 2024 at 9:19 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    When you remove the skid plate, do you hear that clunk?
  3. Oct 15, 2024 at 9:27 AM
    akshorts
    I haven't removed it only because I can't imagine what it would be hitting. It's such a narrow skid plate and far away from any steering/suspension components. I'll give it a try though.
    AZBoatHauler likes this.
  4. Oct 15, 2024 at 9:34 AM
    d33pt
    d33pt New Member
    that strut tower ding does not look fresh.
  5. Oct 15, 2024 at 9:42 AM
    akshorts
    Agreed. The truck only has 42K on it, so I wondered if that was a factory blemish. I didn't notice it or pay attention while I installed the suspension. Also going to re-check torque on LCAs today since another thread mentioned it. Side request, has anyone found a decent resource for torque settings on these trucks? I have to piece meal things from the interwebs.
  6. Oct 15, 2024 at 9:45 AM
    AZBoatHauler
    So.Arizona
    My clunks have always been traced back to the skid plates. Run with the plate off for a bit and see if you can get the noise.
    BillyB and akshorts[OP] like this.
  7. Oct 15, 2024 at 9:49 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    I had a clunk on my old truck as well after installing 6112's. It was hitting in this area, from the ABS bracket (I think) onto the fender.
    crikeymike and AZBoatHauler like this.
  8. Oct 15, 2024 at 10:03 AM
    tundras00
    tundras00 New Member
    I don't see how you can miss or not notice that ding when being around there. Tried tightening up the skid plates? Been around the sway bar lately? Spray some lubricant on the bushings and see if that helps.
    I bought a factory manual USB stick on rockauto for the Tundra.
  9. Oct 15, 2024 at 10:05 AM
    SLOride
    SLOride New Member
    2023 Army Green Limited TRD CrewMax 6.5"
    Check the clearance from the differential to its skid plate. My old Colorado had less than 1mm after installing a lift and it would contact on bumps and when the wheels were fully turned.
  10. Oct 15, 2024 at 10:07 AM
    SLOride
    SLOride New Member
    If it is the skid clearance just add a ~1/4" of washers between the skid plate and frame
  11. Oct 15, 2024 at 12:58 PM
    akshorts
    Well I figured it out. Wasn't the skid plate but an extremely loose LCA nut, as in I could turn it with my fingers loose. I was out driving when I figured it out, tightened it with a wrench I keep in the truck and took it back to the alignment shop. Glad I caught it when I did. Thanks for the help all.
    excelw, BillyB and crikeymike like this.
  12. Oct 15, 2024 at 1:23 PM
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    2019 Toyota Tundra TRD Pro (Midnight Black)
    leather wrap steering wheel, front window tint, ceramic coating, AMP research power steps, Toyo open country at3 35”x11.5x18, Volk Racing te37xt 18 9.5 0 offset, Rays formula II lug nuts Warn fender flares, Coachbuilder +3, bilstein 8112 front and 8100 double bypass rear, Kenwood excelon 996xr stereo +7” speakers Westcott designs front lift, RAS rear leafs, yota leds, NSV Lightbar
    :thumbsup:
  13. Oct 15, 2024 at 2:20 PM
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    Oh WOW!!
    They probably knew that it has to be torqued on the ground, but then forgot to do it. You definitely don't want that nut coming loose and falling off!!
  14. Oct 15, 2024 at 3:34 PM
    akshorts
    Nope, I wasnt happy when I found it. Well, I was happy but then I wasn't.
    crikeymike[QUOTED] likes this.
