Vibration at ~40mph
Discussion in '1st Gen Tundras (2000-2006)' started by KNABORES, Oct 10, 2024.
  1. Oct 10, 2024 at 5:08 PM
    KNABORES [OP] Sarcasm incoming
    So I first noticed this when towing the camper for a few hours. I get this vibration around 40mph or so, feel it most in the seat.
    Starting to feel It now even when unloaded. Assuming something driveline related, maybe U-joint? They’ve never been replaced. I have replaced carrier bearing with a spicer unit about 5 years ago. Haven’t gotten under the truck yet to inspect. Feels like a rumble. Changes when I let off the gas.
  2. Oct 10, 2024 at 5:11 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    That's weird; is it 40 and over? Or just at 40? I figure a bad joint would be noticeable regardless of speed.
  3. Oct 10, 2024 at 5:15 PM
    Right around 40, goes away over about 44mph
  4. Oct 10, 2024 at 5:21 PM
    You sure it's not a tire issue?
    des2mtn likes this.
  5. Oct 10, 2024 at 5:23 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Is it every time you hit 40 or above? I'd pull the rear driveshaft and go for a spin in 4-HI to see if anything changes.
  6. Oct 10, 2024 at 5:25 PM
    Tires are usually a 55-60mph thing, but can’t rule out tires as they are new
  7. Oct 11, 2024 at 1:23 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    When I had this problem, first I had the tires re-balanced (didn't fix) then rotated (didn't fix). I replaced the carrier bearing (didn't fix) then all 4 u-joints (didn't fix). Had the drive shaft balanced (didn't fix). The double cardan joint is not serviceable (no parts available), but the drive shaft guy said it was fine. Finally took it to my trusted mechanic who diagnosed the problem as a bad right front hub bearing. Fooled me because it was silent (I thought a bearing failure would sound like two cats screwing in a dumpster). Had it replaced (fixed!)
  8. Oct 11, 2024 at 3:58 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    If it’s vehicle speed dependent and only present at certain speeds it’s probably a wheel bearing.
    My RR wheel bearing went bad on my 2021 this summer and it got to the point where it sounded and felt like a Honda Civic with a fart can exhaust at exactly 59 MPH. Above/below that it went away, and it seemed to get worse during engine braking.
    The vibration/noise always got progressively worse with increasing vehicle speed any time I’ve had a bad u-joint in a vehicle.
  9. Oct 11, 2024 at 4:22 AM
    I’ve replaced both front wheel bearings with OEM Koyo bearings in the last couple months.
  10. Oct 11, 2024 at 4:37 AM
    FishNinja
    Lee
    06DC2wd
    I hate that this fits my current situation.
    Weagle likes this.
  11. Oct 13, 2024 at 2:38 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I'm almost positive that's what mine did when a u-joint failed. Because I would leave work and was on a highway that you usually only went no more than 50 or 55 miles an hour. so it would go away once I got up to full speed and then once I hopped on the interstate I didn't hear it at all
    KNABORES[QUOTED][OP] likes this.
  12. Oct 14, 2024 at 2:30 AM
    I think this is everyone’s biggest fear, throwing parts at stuff, doing all that xtra work/. Knowing the better driveline shop in town, south of ATL, does free diagnostic, if I ever get a vibration and it’s not blatantly clear what it is (like U-joint or carrier, all look fine), they’re the first place I’m going and I’ll kick ‘em a $50 or something to run a full diag. Beats busting out the parts cannon. Not that I wouldn’t love to refresh my entire driveline, I just don’t like throwing away money.
    Weagle likes this.
