Lost acceleration
Discussion in '3rd Gen Tundras (2022+)' started by Cheerio915, Oct 13, 2024.
  1. Oct 13, 2024 at 1:30 PM
    Cheerio915
    Cheerio915 [OP] New Member
    2023 Sr5 TRD off-road
    Last night I was getting on the freeway, as I went down the ramp and merged in, I was At about 55 mph and all of a sudden it felt like I had a flat tire but couldn’t accelerate. Then the check engine light came on, so I got off at next exit and it just coasted at about 20 mph. It didn’t completely die, but I couldn’t go past 20mph. I could brake and accelerate back up to 20mph. I pulled over, shut off the truck. Checked oil, air filters- looked normal. I turned back on and revved up fine. After about 15 mins I tried again and it worked just fine. I filled up with gas yesterday. Normally I use Valero or Costco which is top tier- but yesterday I filled up with circle k.
    Any idea what could be
  2. Oct 13, 2024 at 1:48 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    No mechanical noises (clanking/knocking) coming from the engine huh?
    Is your truck part of the engine recall?
  3. Oct 13, 2024 at 1:55 PM
    Cheerio915
    No clanking noise. Just like a womp womp womp noise like a flat tire
  4. Oct 13, 2024 at 1:56 PM
    Cheerio915
    No, Im not part of recall
  5. Oct 13, 2024 at 2:05 PM
    Danman34
    Danman34 New Member
    Danny
    Sounds like it could be a transmission issue. Possibly torque convertor. If it’s doing it continuously, it’s definitely a mechanical issue that needs to be checked out.
  6. Oct 13, 2024 at 2:11 PM
    Cheerio915
    A buddy that has a third gen said his did same thing when he first got his , and never did it again. Apparently it was an ECU issue
  7. Oct 13, 2024 at 6:31 PM
    Cheerio915
    So according to couple friends, the truck may have gone into limp mode
  8. Oct 13, 2024 at 6:43 PM
    Danman34
    Danman34 New Member
    Danny
    It did. That’s usually not something you want to leave unattended to. It can put you in a bad situation, for instance trying to merge and you come to a halt on the highway
  9. Oct 13, 2024 at 8:00 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Happens sometimes. Check your codes. Your gonna see Cyclinder Misfire codes. Reset them and drive on. Another on here just posted the same issue and thought he’d lost his engine.
  10. Oct 13, 2024 at 8:55 PM
    Cheerio915
    These are the codes I got..
