LBJ bolts thread size?
Discussion in '1st Gen Tundras (2000-2006)' started by BlueGarden, Oct 10, 2024.
  1. Oct 10, 2024 at 1:11 PM
    BlueGarden
    BlueGarden [OP] New Member
    Paducah, KY
    2002 Tundra Limited 4x4 4.7L
    Anybody know the thread size for the 4 LBJ bolts that thread into the steering knuckles? I am wanting to try to clean up the threads on the knuckle with a tap. One of the new bolts isn't wanting thread into the knuckle. I pulled the LBJ to the side and just tried to get the bolt straight into the knuckle to see if it would go, and the bolt won't thread into it.
  2. Oct 10, 2024 at 2:14 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    FrenchToasty and JasonC. like this.
  3. Oct 10, 2024 at 8:33 PM
    BlueGarden
    Paducah, KY
    Awesome, thank you!
  4. Oct 11, 2024 at 6:29 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    Hey and let us know if that fixes your issue please. About to do this job on mine and am anticipating some squirrely threads too.
  5. Oct 11, 2024 at 9:45 AM
    BlueGarden
    Paducah, KY
    I ordered an M10x1.25 thread chaser that should be here tomorrow, so hopefully I can let you know by Sunday.
    JasonC. and Jack McCarthy like this.
  6. Oct 13, 2024 at 8:50 AM
    BlueGarden
    Paducah, KY
    No luck on cleaning up the threads on the knuckle. I started the ball joint bolt by hand and continued with a ratchet, so I don't know how I managed to mess up the threads on the one hole. Ordered a new knuckle today.
  7. Oct 13, 2024 at 9:04 AM
    Is it not possible to run a bolt in reverse thru the knuckle? Maybe there's not enough space, but this is a common tactic to use with other stuff, like bike cranksets.
  8. Oct 13, 2024 at 12:30 PM
    BlueGarden
    Paducah, KY
    Not sure. Threads are buggered up pretty good. They're removing the threads from the bolt when I try to put them in normally.
