AWD Error and Flashing Yellow 4H/4L
Discussion in '3rd Gen Tundras (2022+)' started by raulz888, Oct 8, 2024.
  1. Oct 8, 2024 at 6:47 AM
    raulz888
    raulz888 [OP] New Member
    Looks like I need to make an appointment with the dealership, but was wondering if anyone has seen it. Don't notice anything amiss other than the error warning and the flashing lights that will go on and off intermittently.
    Any ideas?
    Thanks!
  2. Oct 8, 2024 at 7:02 AM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    From a dead stop, have you tried a sharp turn and noticed it bucking as if the transfer case is actually engaged?
    If it doesn't feel like it is in fact engaged I would guess a sensor has gone a rye.
  3. Oct 8, 2024 at 7:08 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    You don’t have AWD. How are you getting an AWD error?
    PNW Tundra Mike likes this.
  4. Oct 8, 2024 at 7:14 AM
    raulz888
    Great question. Here is the screenshot.
    Tundrum74 likes this.
  5. Oct 8, 2024 at 7:36 AM
    Danman34
    Danman34 New Member
    Danny
    Probably need a dealership visit.
  6. Oct 8, 2024 at 1:56 PM
    raulz888
    So probably should have done it before posting, but putting into and out of 4h seems to completely have resolved it at least for now. Not sure if something was stuck partial way or if a sensor is going on the fritz, but going to watch it for a bit.
    Sirfive likes this.
  7. Oct 8, 2024 at 2:45 PM
    KuehnMK
    KuehnMK New Member
    2023 Tundra Crewmax 4X4 Platinum
    My Transfer case went bad in my Tundra at 500 miles on the ODO....Once it was replaced, I went to put it into 4H and got the same error!...Then mine was stuck into 4L and WOULD not come out. After a tow into the dealer, turns out the "master Toyota tech" that replaced the transfer case forgot to plug in a sensor....So my guess is a sensor in unplugged and or bad....Id get it checked ASAP because you don't want to be stuck in 4LOW....NOT street drivable.
    Tundrastruck91 likes this.
  8. Oct 8, 2024 at 4:42 PM
    Talkin_Tundras
    Talkin_Tundras New Member
    ‘22 Tundra Limited
    Mine was doing that. I read somewhere it could be related to the gas cap not being on tight enough. Also, you likely know this, but the manual suggests driving with it in 4H once a month or so for a several miles. Not sure if it’s related to the warning, if you don’t, but I’m going to plan on doing that from now on.
  9. Oct 8, 2024 at 9:11 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    You haven’t mentioned what you’re driving (yr, model, edition, pkg )
  10. Oct 8, 2024 at 9:51 PM
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    It’s most likely the transfer case actuator, super common on the early 24’s in particular
  11. Oct 9, 2024 at 9:46 AM
    raulz888
    Oh haha sorry. 2023 Limited.
  12. Oct 10, 2024 at 2:40 PM
    daverxa
    daverxa New Member
    Dave
    2024 White Tundra Limited TRD Offroad & TRD Lift
    Leer 100xl, ggoffroad DRV camera relocation, Decked drawer system, BF Goodrich TKO3 275/65R20, Diode Dynamics Fog lights, Go Rhino Dominator D6 Running Boards,
    Are there Tundras with AWD? Which model?
  13. Oct 10, 2024 at 2:45 PM
    Danman34
    Danman34 New Member
    Danny
    No. Doesn’t exist.
    daverxa[QUOTED] likes this.
  14. Oct 10, 2024 at 5:25 PM
    DRP
    DRP Old Member
    Dave
    Nope. His truck is having an identity crisis....
  15. Oct 11, 2024 at 3:34 PM
    GREENPUS
    GREENPUS New Member
    Scott
    2024 Black Tundra Limited TRD Off-Road
    My BMW is full time AWD. When there is an issue the error message on my screen says “Drivetrain error 4x4 system limited” lol
  16. Oct 12, 2024 at 11:20 PM
    PNW Tundra Mike
    Southern Cal
    When mine was new in and out of 4WD was as long as 20-30 secs at times while slow rolling and slightly swerving to change wheel speeds between left and right. I did this weekly for the first year and after that its in/out in about 3 seconds. I think the sliding collar on the front axle and the forks in the xfer case just loosen up a bit once they wear in.
