Mis-aligned passenger doors
Discussion in '3rd Gen Tundras (2022+)' started by 20Tundra24, Oct 11, 2024.
  1. Oct 11, 2024 at 7:16 AM
    20Tundra24
    20Tundra24 [OP] New Member
    Bob
    I purchased a 2024 Tundra a couple of months ago. Brought it in for service today because of mis-aligned passenger doors. Dealer told me there is no adjustment and they are made from the factory this way! Service writer showed me a new Tundra on the sales floor with the same flaw. I looked at a whole row of new Tundras outside and yes, same problem. They all look like the rear passenger door is too low. Seems to me this is a manufacturing problem and should be recalled!
    Has anyone had experience with these doors?
    Thanks
  2. Oct 11, 2024 at 7:40 AM
    Observer
    Observer New Member
    having trouble telling which way your truck is facing and is this passenger or driver side? Driver side of mine appears ok. On the rear passenger door it's slightly lower but not as much as yours appears to be if i'm looking at it right.
    20Tundra24[OP] likes this.
  3. Oct 11, 2024 at 7:44 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum..
  4. Oct 11, 2024 at 8:26 AM
    Frogman32
    Frogman32 New Member
    What the dealer is telling you is BS. The doors are bolted on, not permanently welded on. They can be adjusted, its just hard to do. Take it to a dealer's body shop and ask them if they can fix it under warranty.
    20Tundra24[OP] and Hella Krusty like this.
  5. Oct 11, 2024 at 8:37 AM
    Observer
    Observer New Member
    Pulled the truck out of the garage and checked again. Mine are not like that.
  6. Oct 11, 2024 at 9:07 AM
    20Tundra24
    Bob
  7. Oct 11, 2024 at 9:09 AM
    20Tundra24
    Bob
    Thanks,
    I do find it hard to believe they can adjust these doors! I’ll escalate this issue!
  8. Oct 11, 2024 at 9:12 AM
    scarecrow87
    scarecrow87 New Member
    Shane
    Silver 2023 Tundra SR5 TRD
    The front passenger door was making a clicking/popping noise. Told the dealership about it at my last service (when they over torqued the skid plate after oil change) and they fixed it
  9. Oct 12, 2024 at 12:09 AM
    elysian1
    elysian1 New Member
    2024 Grey Tundra Limited TRD
    I have this issue on my '24 Limited TRD that i just picked up last week. Right rear passenger door sits just a bit lower than the others. Will be taking this in and seeing what they say
  10. Oct 12, 2024 at 12:36 AM
    Oolypoolay
    Oolypoolay Meh
    Virginia
    2015 Limited Crewmax
    Bilstein 6112/5160 Method 702 0 offet Toyo open country 285/75 17 Form led headlights OEM Toyota led fog lights Morimoto 3rd brake light Morimoto tail lights Amp Research power steps
    Body shop can definitely adjust that.
  11. Oct 12, 2024 at 8:40 AM
    Hella Krusty
    Hella Krusty New Member
    I adjusted my 2012 in my garage by watching you tube videos. Unless you have gull wing doors, doors all bolt on the same. I get it that it’s under warranty and not your problem, but understand it is fixable regardless what that bozo mechanic told you.
  12. Oct 12, 2024 at 3:30 PM
    iScramble
    iScramble New Member
    2023 Tundra SR5
    Hopefully it’s a simple adjustment. I’ll be checking mine later.
