  1. Oct 12, 2024 at 3:44 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    I have a wood divider there like you have more rear. Wasn't sure if it was a brace or something for off-roading. Thanks!
    BrandonL812[QUOTED] likes this.
  2. Oct 12, 2024 at 5:02 AM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    Love this. I undercoat my vehicles annually now. Also now undercoat multiple others for friends and family. Lol
  3. Oct 12, 2024 at 5:49 AM
    RobertD
    Robert
    DFW, Texas
  4. Oct 12, 2024 at 5:58 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Also added the go rhino RB20 running board.
    Took the oem predator boards off because we have a toddler. It is so much easier for him to get in and out.
    Before
    After
  5. Oct 12, 2024 at 6:19 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    Holy shit
    CaptRussia253 likes this.
  6. Oct 12, 2024 at 7:17 AM
    jakane916
    jakane916 New Member
    2019 Tundra Limited
    ReadyLift 8 in lift Hardrock 22in on 37's RDJ fender flares DB grille
    Are those fenders custom made?
  7. Oct 12, 2024 at 7:33 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    That’s not a tundra, it’s a ford raptor.
    HulkSmurf14, BreyTundy and reywcms like this.
  8. Oct 12, 2024 at 8:14 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Rey’s truck identifies as a Raptor
  9. Oct 12, 2024 at 8:30 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :ohsnap:
    CaptRussia253 and reywcms like this.
  10. Oct 12, 2024 at 8:32 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  11. Oct 12, 2024 at 9:14 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Tacoma
  12. Oct 12, 2024 at 9:15 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    LP9 and harness bar testing early this morning. Can confirm all working as intended.
  13. Oct 12, 2024 at 12:03 PM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    Did the chalk bag cup holder mod(so my wife can bring her owala 32oz water bottle and not complain there is no place to put it.). pulled the skid plate so I can mod it with the oil filter trap door, put on my fumoto valve. Truck came from Chicago so I had some surface rust on the frame and suspension, sprayed rust remover all over underneath, let it sit for a few hours and rinsed it thoroughly. When I reinstall my skid plate I'll give it another once over
  14. Oct 12, 2024 at 6:02 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Oil change and tire rotation for the ole girl today, and added a fomoto valve while I was at it. Not that it means anything, but the Motivx oil change kit gets my stamp of approval. I snapped off a cheap extension in the end of the filter wrench but then just slapped on a 24mm socket and buzzed it off with an impact. Looking back I probably should have just started with the socket, but hey, you live and you learn. Hopefully I’ll get to both diffs and transfer case tomorrow, then transmission drain and fill next weekend. Gonna feel like a whole new truck here pretty soon!
    Motivx Tools Oil Filter Wrench,... https://www.amazon.com/dp/B0791MWXDC?ref=ppx_pop_mob_ap_share
  15. Oct 12, 2024 at 6:21 PM
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Just finished designing a TRD pro garnish
  16. Oct 13, 2024 at 6:08 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Hit a milestone this morning!
  17. Oct 13, 2024 at 9:55 AM
    NorthShore
    NorthShore New Member
    2014 SR5 TRD Offroad Crewmax
    Got the RCI skid installed with a little help from my nephew. Excited to have some actual protection and quick oil filter access.
  18. Oct 13, 2024 at 1:39 PM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    Took the truck to the beach at Port A. I towed our 264bh camper down there, averaged 6.5mpg.
  19. Oct 13, 2024 at 3:36 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Didn’t get any pics, but changed the rear diff fluid today. It was pretty chocolate milkshakey so I’m glad I got it swapped out. Not sure what witchcraft the last guy did, (probably just tilted the axle) but almost 1/2 a quart came out of the fill plug when I spun it off. Oh well, a little saw dust on the garage floor to soak up the oil and we’re good to go
  20. Oct 13, 2024 at 4:01 PM
    bfunke
    bfunke Tundra Curmudgeon
    Recommend new breather valve and if you tow a boat or ford streams relocate the vent into your left taillight housing. Milkshake = water in the oil.
  21. Oct 13, 2024 at 4:01 PM
    koditten
    Kirk
    Midland of the Mitten
    After that, go after the oil stain on the concrete with starting fluid or brake clean by spraying the shit out of it. Scrub with a plastic bristle brush and soak up the residue with an old shop rag. You will have to look hard to find the stain after this trick...
    Or it will clean the area better then the rest of the stained floor and you will have a faded area to remind you of the job.
  22. Oct 13, 2024 at 4:58 PM
    centex
    centex New Member
    566 mile road trip. 13.4mpg on the way there and 15.8mpg on the way back. Both at 75mph with cruise.
    TacomaTRD4x402, bulldog93 and Tunrod like this.
  23. Oct 13, 2024 at 5:57 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    69 mph nice dude :thumbsup:
  24. Oct 13, 2024 at 6:11 PM
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    Finally knocked out a fluid change on the front differential. It took two trips to HF and a few attempts, but I found an easy out that fit the mangled fill plug the prior owner left for me.
    PSA, the Icon HF easy out set is really nice for the $
  25. Oct 13, 2024 at 6:21 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Yeah I actually already have my diff breather relocated, I think the water has been In there from one of the first outings with the truck before I had the relocation done. We should be good now!
    Heck yeah, I’ll give that a shot! And I’ll get to sniff brake cleaner, my personal favorite flavor of cleaner
  26. Oct 13, 2024 at 6:47 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    I agree, HF's Icon sets are really nice. I got their tap n die set for dirt cheap and that extractor set is on my list. :thumbsup:
  27. Oct 13, 2024 at 7:54 PM
    ikarus
    ikarus New Member
    2021 TRD Sport
    Got out to the desert to test out my King 3.0s. Still gotta dial them in but I'm impressed
  28. Oct 13, 2024 at 8:35 PM
    AZBoatHauler
    So.Arizona
  29. Oct 14, 2024 at 4:07 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Killer pictures, the truck is looking mean!
    Jesus, 97 in October is insane! I hope you were out on the water
  30. Oct 14, 2024 at 8:21 AM
    RustyShackle323
    Stewart
    NC
    Totally on accident ;):D
