LED strip under tailgate
Discussion in 'Lighting' started by Jmitchellfly, Sep 11, 2017.
  1. Sep 11, 2017 at 4:57 PM
    Jmitchellfly
    Jmitchellfly [OP] New Member
    2017 Limited
    i have a '17 Limited and am interested in installing a LED strip light below the tailgate. Has anyone found one that doesn't block the hole that allows you to lower the spare tire?
  2. Sep 11, 2017 at 5:05 PM
    Opt-7.com
    16 blue crewmax and sf319 like this.
  3. Sep 11, 2017 at 5:07 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Yes I have he line of fire and ice LED bar by recon under the tailgate. It stays on with running lights, brightens for brake light, splits in half for turn signals and changes white for reverse lights. It comes with a plug to go into your trailer harness. I cut that off mine and direct wired it into the trailer harness. IMG_6769.jpg
  4. Sep 11, 2017 at 5:08 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Mine does block the spare tire hole but it does come with metal clips so you can remove it if you need to get to the spare tire without any additional tools.
    NewImprovedRon likes this.
  5. Sep 11, 2017 at 5:10 PM
    BayRunner
    BayRunner I’m here, except when I’m not
    2017 Tundra Platinum
    Just had the Putco Blade installed and has pics in the thread listed below. It is a rigid strip and can be mounted with the included 3m tape or brackets. Mine was installed with the brackets which allows the lite to be removed if necessary, however it was mounted low enough to still have access to the hole.
    https://www.tundras.com/threads/rear-led-conversion-complete.16376/
  6. Sep 11, 2017 at 5:21 PM
    Jmitchellfly
    2017 Limited
    That looks great 1UPPER. Do you sell those?
    1UPPER likes this.
  7. Sep 11, 2017 at 5:24 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Thanks! No. I just bought mine online.
  8. Sep 11, 2017 at 5:28 PM
    Jmitchellfly
    2017 Limited
    Thanks for the replies. This site is great for getting answers about my truck.
    FlashCulprit, 040Tundra and 1UPPER like this.
  9. Sep 11, 2017 at 5:28 PM
    Let's see your ride....
  10. Sep 11, 2017 at 5:37 PM
    Jmitchellfly
    2017 Limited
    IMG_1257.PNG.jpg Not the best picture but I'm really enjoying it so far!
    040Tundra likes this.
  11. Sep 11, 2017 at 5:46 PM
  12. Sep 11, 2017 at 5:52 PM
    pbryant44
    pbryant44 New Member
    Panama city florida
    2016 tundra 4wd sr5 tss
    I bought one off Amazon. Wired it up to the tail lights the wiring diagram was easier to read. Haha
  13. Oct 3, 2017 at 6:37 AM
    mlucas555
    mlucas555 New Member
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Still rocking the stock height.
    I'm looking at getting this for my truck. How did you wire into the trailer harness? Did you use posi taps? Sorry, I have never done wiring before and want to make sure that I do it right. I did not even think about the fact that it might block the hole for the spare. I guess I just have to watch how high I install it. Thanks for your help!
  14. Oct 3, 2017 at 6:47 AM
    BayRunner
    I had the Putco Blade installed which allowed room for the spare tire rod. It was also tapped into the trailer harness with an adapter. The adapter plugged between the harness and the trailer socket behind the bumper. Very clean install. Another thing I prefer the Blade over is the LEDs are smaller and close together creating a more solid light instead of larger separate LEDs.
    xando, Bones2012, 1UPPER and 4 others like this.
  15. Oct 3, 2017 at 7:01 AM
    1UPPER
    TEXAS
    Flux capacitor!
    I actually used the Opt7 60" LED. It's only $49 now! If you look at your rear harness it tells you on the cover which wires are left signal, right signal, running lights and brake lights. I did cut my wires under the truck solder the new wires into the stock wires. I then covered them with heat shrink tubing to make them sealed from the elements.
    http://www.opt-7.com/redline-led-tailgate-light-bar-with-reverse/
  16. Oct 3, 2017 at 3:10 PM
    LKSR5-14
    LKSR5-14 New Member
    Chicago Northwest suburbs, Illinois
    2016 Tundra SR5 DC
    Tundra SR5 DC 2016 Upgrade: pro wheels, headlights retrofit, head unit Kenwood 694s, bed cover, lineX, Viper security and starter system, pro grille, tinted windows, LED lighting, black wrap on all end chrome corners, ceramic coating
    What's the length you got? 48" or 60"
  17. Oct 3, 2017 at 6:31 PM
    1UPPER
    TEXAS
    Flux capacitor!
    60"
    LKSR5-14[QUOTED] likes this.
  18. Oct 3, 2017 at 6:52 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    17' Tundra SR5, 12' Tacoma TRD offroad
    I like the looks of that, very nice!
  19. Oct 4, 2017 at 4:57 PM
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    I have just placed the order. Thank you!
    1UPPER[QUOTED] likes this.
  20. Oct 8, 2017 at 1:58 PM
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Where did you tap reverse light? Also does the colors match to the wiring with the led strip or not.
    On stock harness there are:
    Blue
    Green
    Black
    Brown
    White/black strip
    Yellow
    Green again
    Supplied plug:
    Green
    Yellow
    Brown
    White
    Where each wire i should tap? 4 total plus reverse white wire? 9c45136508e2c6394a5e6ff3101288a9_3a93d9bf94b9263b554f45d4000efac6863e3158.jpga85fb98d0ba809a128821b4d6de4e090_9169b8c4d8407f0ce4061446070d1f791d974178.jpg
  21. Oct 8, 2017 at 2:48 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Look at your trailer harness cover and it shows you which wires goes to what.
    Fishman57 and LKSR5-14[QUOTED] like this.
  22. Oct 8, 2017 at 2:50 PM
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    I got it already. Thanks for quick response.
    1UPPER likes this.
  23. Oct 8, 2017 at 4:26 PM
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Here you go... ☺
    Reverse
    Left turn
    Lights d30d39e5fef6a7f56850435072d56484_488173cb01a72b62ee0f53f26879d928ae90f697.jpg3fb97f09f444d799f9a4fee148a089a3_502cccd704e1379fc89a698164ec3aa98de1dd5d.jpga91aeafe7a27ede2a5704a91a6ca369d_e60bbe5e64ab08ed2df55ccfb5739b61584cb34a.jpg
  24. Feb 22, 2018 at 7:01 PM
    Lee Carman
    Lee Carman New Member
    Lee
    2010 tundra limited
    I am thinking of purchasing the Putco switchblade (92009-60) for my 2010 Tunbra Limited Crew Cab but am concerned about the spare tire release hole. Will this tail gate light bar block this hole.
  25. Feb 22, 2018 at 8:47 PM
    Bones2012
    Bones2012 2012 CM
    Windy City
    2012 Black Crewmax
    Step Tubes BakFlip VP Dee Zee Bed and Tail gate mats Pop A Lock tailgate lock Smitty Built M1 Rear Bumper Weather Tech mats Interior LEDS Remote control Bed Lights Cabelas seat covers
    Do you know which adapter was used? This would make for a much cleaner and durable install.
  26. Feb 23, 2018 at 11:13 AM
    dugfur
    dugfur New Member
    doug
    2016 limited DC
    I would like to know about this adapter thing also............................
  27. Feb 23, 2018 at 12:01 PM
    BayRunner
    Since I had it installed by a local shop, I do not know. I assumed it was in the box but I'll crawl under this evening and see if I can snap some pics.
    Bones2012[QUOTED] likes this.
  28. Feb 23, 2018 at 2:52 PM
    Jrfor0
    Jrfor0 New Member
    James
    I've got a Putco on my truck as well and there is a decent amount of room for the spare tire release. In addition, the Putco mounts to the truck through the use of clip in type brackets. the brackets mount to the truck and the light bar clips into the brackets, which allows the light bar to be removed relatively easily to get to the spare tire release. My Putco came with a 4-pin wiring harness, which I cut off and wired it myself into the trailer hitch wiring. Below are photos of the spare tire release and the brackets.
    Ely010606 and NewImprovedRon like this.
  29. Feb 23, 2018 at 3:42 PM
    Bones2012
    Bones2012 2012 CM
    Windy City
    2012 Black Crewmax
    Thanks.
    I looked around online and couldn’t find anything. I did figure out that I should possibly hook it to the 4 pin connector instead the 7 pin.
  30. Feb 23, 2018 at 4:40 PM
    JerseyTundra1260
    JerseyTundra1260 08 Silver streaking!!!!!
    Marc
    New Jersey
    08 Silver Tundra DC Limited 4x4
    Too many to list.....
    Have the same here...:thumbsup:
