Remote Start
Discussion in '3rd Gen Tundras (2022+)' started by Woocawachie, Oct 11, 2024.
  1. Oct 11, 2024 at 4:12 AM
    Woocawachie
    Woocawachie [OP] New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    My subscription expired to remote start about half a year ago, but starting the truck with the physical remote still worked using the 3 click and hold method. Recently got a new phone and was re installing the TOYOTA App. After glancing over the terms and conditions I did not agree to any of them. Within a few minutes got an email from AT&T that they are canceling my Cars WiFi (even tho i haven’t been paying for it) and also now my remote start with the key fob doesn’t work anymore. I guess we are in the age where your data is worth more than gold to corporations. Even cutting you off from starting your vehicle just cause you don’t want to share info about it. I’m sure it’s not just Toyota. GMCs death grip on your data is even scarier.
  2. Oct 11, 2024 at 6:02 AM
    War Machine
    War Machine SSEM # 5 3MW
    Weird. I haven’t paid for the remote connect in either of mine since they expired a year ago and the fob still starts them.
  3. Oct 11, 2024 at 6:18 AM
    Woocawachie
    Dickens
    Philadelphia
    Once you agree to the terms it stays in “agreement” regardless of your subscription is active or expired. Bet you if you decline all the data gathering clauses the fob remote start will stop working
    Jymbeux and cartage1 like this.
  4. Oct 11, 2024 at 6:19 AM
    DRP
    DRP Old Member
    Dave
    But did you opt ot of everything else?
  5. Oct 11, 2024 at 6:30 AM
    Woocawachie
    Dickens
    Philadelphia
    Yes. Everything else also involves data collection
    Why do they need my data for me to start my car when I’m 10 feet away from it
    Tundrastruck91 likes this.
  6. Oct 11, 2024 at 6:36 AM
    Wtundra2023
    Wtundra2023 Bad Weld Aficionado
    2023 Limited Tundra, 2014 Limited Sequoia
  7. Oct 11, 2024 at 6:36 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
  8. Oct 11, 2024 at 6:37 AM
    JRS
    JRS New Member
    2012 DCLB
    Based on another thread, and what you're describing, it's because the remote start is likely being sent as an MQTT message. Completely different mechanism than RF remote starts of old.
  9. Oct 11, 2024 at 6:49 AM
    Wtundra2023
  10. Oct 11, 2024 at 7:05 AM
    eddiefromcali
    Eddie
    100% Stock
    Been about 1.5yrs and it's been flawless. I have the long range 2 way remote version. No complaints, truck doesn't shut off when I rs and open the door.
    Woocawachie[OP] and TakiEvo like this.
  11. Oct 11, 2024 at 8:08 AM
    steveh
    steveh New Member
    '24 Tundra Limited
    Nothing Yet!
    Does the bypass work when not in cell phone range?
  12. Oct 11, 2024 at 8:28 AM
    eddiefromcali
    Eddie
    100% Stock
    The one I used? Yes. It doesnt use cell phone signal...its like an old school alarm.
  13. Oct 11, 2024 at 8:37 AM
    Woocawachie
    Dickens
    Philadelphia
    Hmmm never heard of it. Will look into it. Could be a possibility.
  14. Oct 11, 2024 at 12:54 PM
    GREENPUS
    GREENPUS New Member
    Scott
    2024 Black Tundra Limited TRD Off-Road
    Was it difficult to install? Description seems to make it possibly difficult for some inexperienced with wires
  15. Oct 11, 2024 at 1:18 PM
    eddiefromcali
    Eddie
    100% Stock
    very easy. One wire does get cut and you tap into another. Rest is plug and play. No need to send off the module, I was given a login to download the programming and get it going...took 5 mins. Hardest part was running the antenna wire nice and tucked away. 2hr job for a rookie....30mins-1hr for a shop
  16. Nov 21, 2024 at 10:40 AM
    Korj26
    Korj26 New Member
    Vitalii
    Manitoba,Canada
    ‘25 Tundra 1794 CrewMax
    Hello. Please tell me, does the truck work for 10 minutes and then turn off, or does it work as long as you like after remote start? Or does it just not turn off when you open the door, and everything else is unchanged? Thank you.
  17. Nov 21, 2024 at 11:03 AM
    eddiefromcali
    Eddie
    100% Stock
    I'm not sure if the truck will keep running for a set time, I'd have to verify
  18. Nov 21, 2024 at 11:24 AM
    Korj26
    Korj26 New Member
    Vitalii
    Manitoba,Canada
    If there is a possibility, please check it out for me it is important, I live in the north. thank you
  19. Nov 21, 2024 at 12:08 PM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    Ah, the days of -40 and needing Command start and timer activated block heaters and interior heaters in Gillam,MB.
    I really don’t miss them.
    Winters in Oregon are so much better.
    Don’t have to shovel rain. ;)
  20. Nov 21, 2024 at 12:17 PM
    Korj26
    Korj26 New Member
    Vitalii
    Manitoba,Canada
    Yes :)it gets very cold here in the winter I live in the Snow Lake .I was wondering if the truck would run longer than just 10 minutes after installing the REMOTE START KIT:confused:
  21. Nov 21, 2024 at 12:37 PM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    I don’t know how long it will run as I don’t have/need an additional one as described in this thread.
    Only just tried the factory remote key fob start sequence a couple of weeks ago after almost 2 years of ownership just to see if it worked (it did).
    I was just responding due to your location. :)
    Korj26 likes this.
  22. Nov 21, 2024 at 3:15 PM
    manapiko
    manapiko New Member
    Patrick
    Soon to own 2023 TRD Pro
    We dont pay for the subscription and remote still works from the FOB
  23. Nov 21, 2024 at 3:47 PM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    Either do I
  24. Nov 21, 2024 at 4:32 PM
    onehundredLL
    onehundredLL New Member
    2025 Tundra Limited
    How much is the subscription?
  25. Nov 21, 2024 at 6:19 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    I'm very interested in this remote start. Their website only has one review for our model truck, which is a bit disappointing, however it appears you have had a good experience? The website says you have to send in a module from your truck, however that was not what was recently stated on this site for a complete install. Are they just bad about updating their website?
  26. Nov 21, 2024 at 6:41 PM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    After your free year, $15 a month.
    This is for the Toyota remote start app.
  27. Nov 21, 2024 at 7:21 PM
    onehundredLL
    2025 Tundra Limited
    That kit is $475 not installed (for the version that works with your phone). Equivalent to 2 1/2 years subscription.
    I think I'll just keep it simple and will become a subscriber.
    TundraDan723 likes this.
  28. Nov 22, 2024 at 7:27 AM
    eddiefromcali
    Eddie
    100% Stock
    I guess so. I was happy to see I could program it myself. It's been flawless so far
    TundraDan723[QUOTED] likes this.
  29. Nov 22, 2024 at 7:39 AM
    pillie3
    pillie3 New Member
    DFW, Texas
    Hey eddie, you mentioned in a previous post about this unit that there's an antenna that comes with the kit. How/where did you end up running the antenna and wire? Looking into getting this kit for the truck since its 24% off for black friday
  30. Nov 22, 2024 at 7:41 AM
    eddiefromcali
    Eddie
    100% Stock
    There's an antenna like most aftermarket alarms. I ran it up the A-pillar to the top left corner of the windshield.
