General Supercharger Thread
  1. Oct 9, 2024 at 7:58 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    why?
  2. Oct 9, 2024 at 8:34 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    no loss in low end
    HulkSmurf14 likes this.
  3. Oct 9, 2024 at 9:09 PM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub, Rokblokz XL, AVS visors
    You're totally right. It's kinda funny when you think of it this way: Boost is essentially a measure of restriction, so less restriction on intake equals more restriction (boost) haha
  4. Oct 9, 2024 at 10:10 PM
    NatesNightMare
    Pinetop Az
    hows that? not sure how you would know with all your goodie add ons lol. im still on stock mag injectors and pump :rofl:
    cant be because of "equal length" if so i still have pipe to do that too :rofl:
  5. Oct 9, 2024 at 10:17 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Let it flow...open it up!
    Seems going from 200 cell cats to 400 may have increased pressure. Looks like I'll have to take a few runs and compare data.
  6. Oct 10, 2024 at 12:09 AM
    blenton
    blenton New Member
    An aside: I did 400 miles today pulling my enclosed trailer. It was one of three days a year that there isn’t much of a wind to speak of. 55-70 mph speed limit and a little more than 3000’ elevation change each way. This thing is a towing ANIMAL. I’m sure you guys all know that, but sometime I just have to say it out loud (or type it out loud…?). Pretty much locked in 5th the whole way home with a few spurts of 6th gear just to see if it would do it. Only regret is not adding boost sooner. Haha.
  7. Oct 10, 2024 at 3:14 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    <scratching down notes to make sure I do it right>
  8. Oct 10, 2024 at 3:16 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I am the poster child for "measure of restriction":ballchain:
    stock intake
    stock (TRD) exhaust
    77mm pulley (Harrop)
    11psi (sea level)
  9. Oct 10, 2024 at 3:30 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    It’s weird I have the same setup except a less restrictive intake and I never see more than 8 or 9 psi. My peak boost didn’t really change from the 80mm to 77.5mm pulley. It just came on faster at lower rpm.
  10. Oct 10, 2024 at 3:50 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    When I get into PE, I am generally @ 8psi. scary.
    then, if I keep the pedal down, it climbs to 11psi quickly.
    I've only done it once.
    here's the rub....all my shit is working (knock on wood).
    no engine codes
    no leaks.
    smooth hwy cruising
    this, alone, makes me leery about adding more stuff.
    I'll probably hold my position for the foreseeable future, as the truck is perfect for me right now.
    and, truth be told, there ain't a whole lot of comparable options out there!
    Tripleconpanna and e30cabrio like this.
  11. Oct 10, 2024 at 5:24 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I support what Rey says, I wanted SPD system but had to do a custom because my headers, so my exhaust guy more or less duplicate the design but with 3" and some added touch.
    There's no loss of low end, improved mpg by almost 10%, and with my racelogic v box it shows 0-60 improved by 2 tenths, and it sounds very un-truck-ish.
  12. Oct 10, 2024 at 6:01 AM
    JaxJacket
    JaxJacket New Member
    21 DC
    SPD downpipes neck down to 2-3/8" I.D. at the exit flange. Maybe that helps with the low end. I didn't notice any loss either.
    e30cabrio and HulkSmurf14 like this.
  13. Oct 10, 2024 at 7:55 AM
    kos221
    kos221 New Member
    2007 4X4 DC
    That is how mine is too. It starts timing when you start going. You dont need to worry about reaction time.
    e30cabrio likes this.
  14. Oct 10, 2024 at 9:06 AM
    NatesNightMare
    Pinetop Az
    same as i couldnt afford the SPD kit but i didnt do equal length and i went with Carven mufflers. maybe its just me with the combo of all the extra sound lol
  15. Oct 10, 2024 at 9:20 AM
    kos221
    kos221 New Member
    2007 4X4 DC
    I spent a little time looking at the numbers on draggy and noticed a few trends. You can clearly see the 1-2 shift unless your 0-60 time is under 3 seconds and all 4 tires are spinning @ViktorG .
    Distance to 60 is about 235 feet for trucks that can go 0-60 in 4.5 seconds, 5.5 second trucks need another 30 feet, however, the newer model Tundra that ran a 5.49 0-60 needed another 24 feet to get to that speed. It also had to shift one more time.
    @e30cabrio Click on your times to get more details about the run. IMG_0774.png What is the distance needed to get to 60 MPH with a 8 second time? Also, what is your 0-60 (1ft) time? Some folks who launch the vehicle really easy can se over a half a second difference. You need to do a few more runs to get some consistent numbers.
  16. Oct 10, 2024 at 9:37 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    That makes more sense since they weren't measuring boost.
    Silver17[QUOTED] likes this.
  17. Oct 10, 2024 at 9:50 AM
    NatesNightMare
    Pinetop Az
    building race trucks are we? lol
    j_supra likes this.
  18. Oct 11, 2024 at 3:39 AM
    BlackSunshineYYC
    BlackSunshineYYC New Member
    Black TRD Pro
    HoneySeal - what did they charge you for the clean and coat?
  19. Oct 11, 2024 at 4:10 AM
    Silver17
    Eastern PA
    Yeah, tell us more HoneySeal.
  20. Oct 11, 2024 at 6:55 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Have you been consistently getting 10% better mileage or was it just the first tank?
  21. Oct 11, 2024 at 7:01 AM
    Downytide
    GTA
    We are special................
    The price depends on how much cleaning is needed, I keep my truck relatively clean, I power wash weekly in winter and had krown treated since new, but I was having surface rust showing on the frame and small parts, so that took almost full 5 days to do it, on avg they charge about $600 CAD per day, that gives you an idea.
    If it's a super clean vehicle/new, it can be done in one day.
    is that AI? it looks so nice yet so fake.
    consistent, I hand calculate each tank, last long trip with trailer I had 11mpg, which blew me away as same trip before new exhaust I was only able to get 9.5-10mpg, it's a hilly area.
    If it's empty, and I leave the transmission alone it'll get as high as 16mpg.
  22. Oct 11, 2024 at 7:04 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    It looks awesome but as I am in Az, there is no salt on our roads so like 90% of my mods no need.....
    Where do I sign up.. :p
  23. Oct 11, 2024 at 7:33 AM
    ZPhilip
    Philip
    West Chester, PA
    FINALLY broke into the 4s!
    Harrop 77.5 pulley, DW650 and that SSS tune. Thanks Sniv!
    35s and stock gears, 6400 pounds.
  24. Oct 11, 2024 at 7:34 AM
    Silver17
    Eastern PA
    Yeah, seemed like a prime time to see what it would spit out for the username honeyseal. :rofl:
    Saltyhero13 and Mdl like this.
  25. Oct 11, 2024 at 8:16 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    I wish they would include temp and elevation in the dragy results.
    Land Bruiser and HulkSmurf14 like this.
  26. Oct 11, 2024 at 8:34 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Badass!! That's a healthy, fast time on those shoes and diet!! Woot woot!!
    ZPhilip[QUOTED] likes this.
  27. Oct 11, 2024 at 8:36 AM
    HulkSmurf14
    2014 Tundra Limited
    Mine seems to:
  28. Oct 11, 2024 at 9:10 AM
    kos221
    kos221 New Member
    2007 4X4 DC
    That is quick! What a brutal launch, you pulled over a G when you took off!!!
  29. Oct 11, 2024 at 9:39 AM
    Saltyhero13
  30. Oct 11, 2024 at 12:17 PM
    helidave
    flagstaff
    2015 DC 4x4
    I see it now, hiding up there on some of them.
    HulkSmurf14[QUOTED] likes this.
