Question about a part on alternator.
Discussion in '2nd Gen Tundras (2007-2013)' started by Omaha419, Oct 10, 2024.
  1. Oct 10, 2024 at 1:31 PM
    Omaha419
    Omaha419 [OP] New Member
    2007 Tundra 5.7 CrewMax
    First post here:
    First of all, replacing this alternator was a pain in the ass, but if you have some mechanical ability and some patience, you can do it. I also followed a youtube video and it was a great help, even though the mechanic in the video made it look too easy and was obviously dealing with a newer truck with less rust. I'll put the link in this post as well.
    This is where I'm stuck.
    I removed the old alternator, and these two bushings (spacers?) are stuck in the old alternator. I can't find any reference to them on google. Even the parts diagram (link below) on a Toyota parts website has no reference to this.
    Do I really need them? I'm thinking the 4 bolts holding this to the engine block should suffice, right?
    My next thought is taking an angle grinder to the old alternator to get them out, but I was hoping to rebuild this alternator. Any help would be appreciated.
    https://parts.lakelandtoyota.com/sh...1647&ukey_driveLine=6799&ukey_trimLevel=18361
    https://www.youtube.com/watch?v=izy-tZXn5Jc&t=288s
    Cruiserpilot and Leo's first like this.
  2. Oct 10, 2024 at 1:56 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Looks like in the video you posted, they easily feel out for him and he did say to make sure you put them back on the block.
    Maybe hit em with some oil n let em sit for a while. :monocle:
    Omaha419[OP] and Leo's first like this.
  3. Oct 10, 2024 at 2:02 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    They're alignment/shear sleeves. If they're impossible to get out I frankly wouldn't sweat it and I highly doubt you'll have any issues with just the bolts.
  4. Oct 10, 2024 at 2:13 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Those dowel pins are part number 90253-13017, two required. They can be found in the timing cover diagram.
  5. Oct 10, 2024 at 7:19 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Just tap them down with a hammer, they should just slide in.
    That YT video is for a 4.6 is it? Does anyone know - are the alternators in the same location for each engine?
    4.6 and 5.7 the same?
  6. Oct 10, 2024 at 9:39 PM
    lr172
    lr172 New Member
    07 DC
    Yes, you need those. some heat and a hammer / punch from the inside shoul get them out
  7. Oct 11, 2024 at 5:27 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    The 4.6 is the same as the 5.7, just has a shorter deck height.
    There’s a shoulder at the bottom of the dowel bore in the alternator, so while not impossible, getting behind the lip of the dowel might be more of hassle than it’s worth. Toyota uses this part everywhere on dozen of models, so it should be readily available, and at $4 or $5, install new.
    Cruiserpilot[QUOTED] likes this.
  8. Oct 11, 2024 at 5:31 AM
    koditten
    Kirk
    Midland of the Mitten
    Mine were froze in. The steel bushings chemicaly weld themselves to the aluminum ears in the housing.
    I ended up cutting mine out with a portable band saw. It destroys the used alternator as a core, but I didn't care.
    You are correct. The replacement job is a real pain. Took me 5 hours.
    Fobroader and Omaha419[OP] like this.
  9. Oct 11, 2024 at 7:04 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    That's a good video, I like a guy who just does the work. Lays out all the tricks and torques specs. 5 Stars!
    Omaha419[OP] likes this.
  10. Oct 11, 2024 at 10:10 AM
    Omaha419
    Yeah, no doubt. Made it look a little easier than it actually was.
  11. Oct 11, 2024 at 10:12 AM
    Omaha419
    This is what I ended up doing. Without the sleeves there was a very minimal amount of play. I picked the middle of the movement and tightened it in there.
  12. Oct 11, 2024 at 10:38 AM
    Fobroader
    Fobroader New Member
    Alberta
    2020 Platinum
    Thats what we had to resort to on my buddies 2009, foul language, hammers, penetrating fluid, a torch and a press were doing nothing. A sawzall blade and ta daa, came right off. We smeared the ever loving bejesus out of them with anti seize. I agree, alternator replacement on these things is a nightmare compared to any other truck/SUV I've done.
    koditten[QUOTED] likes this.
  13. Oct 12, 2024 at 3:51 PM
    Omaha419
    Well, no dice. Belt is shifting on the alternator so it is likely out of alignment. I'll use the part numbers listed above and see if I can get it right. :(
  14. Oct 12, 2024 at 3:55 PM
    Omaha419
    Well, I hope you're right. I ordered two. Belt shifted forward on the alternator pulley so I guess you need these.
  15. Oct 12, 2024 at 4:11 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    koditten likes this.
  16. Oct 12, 2024 at 5:02 PM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
  17. Oct 19, 2024 at 11:11 AM
    Omaha419
    That's the one! Ordered two. :thumbsup:
